Vector triple product proof: why set A equal to C?
Decimal
Hello,
I am having trouble understanding a proof presented here:
http://www.fen.bilkent.edu.tr/~ercelebi/Ax(BxC).pdf
This is a proof of the triple product identity, but I don't understand the last step, where they calculate ##\lambda##. Don't you lose all generality when you state ##\vec A## equals ##\vec C##?
Thanks!
No. You do not loose any generality. The number ##\lambda## is a constant that should be independent of what vectors you use. Hence, it is perfectly fine to use ##\vec A = \vec C##. When you do this you get a relation for ##\lambda##, but ##\lambda## is independent of what the vectors actually are. Hence, since it is equal to one for a particular choice of vectors, it must be equal to one for any choice of vectors.
Ah I see, for some reason I interpreted the ##\lambda## to be dependent on the choice of vectors, but of course there is no reason for doing so. Thanks a lot!
