Verilog Display Module: Moving Ball & RGB Image Solutions
  • Thread starter Thread starter Drao92
    module
The discussion revolves around creating a Verilog display module for a moving ball on a 640x480 display using RGB values. The user initially faced issues with the ball moving too quickly across the screen, leading to a plan to implement a frame counter to control the movement speed. There were also concerns about RGB values not displaying correctly, with the user noting that without an explicit else statement, the screen defaults to black. Suggestions included simplifying the RGB module to isolate color issues and ensuring proper synchronization with the VGA controller. Overall, the conversation emphasizes debugging techniques and the importance of setting default values for RGB outputs.
Drao92
Hello,
I have to make a Display module in verilog and first time i want to create a ball which is moving and i have a question, the vertial/horizontal synchronization module is done, the question is about displaying the image using RGB. So, i use 640x480 display and 25Mhz clock frequency and first time when i created the module i didnt took in consideration that the fpga displays 60 frames in 1.15 second and i wrote somthing like move evreytime when x=? and y=? with 2px and then i realized that i wouldn't be able to see the image because it will be moving too fast. Aint i am right? I was thinking to implement a counter which counts the number of frames and makes the ball to move every 20, 30, 40 frames. So first of all i want to ask if it is right what i am saying and in this case what is the best delay to chose?
Also, i will have acces to the the FPGA to test the modules in a few days, i don't know what`s happening in reality :D. I only simulated the HV signals in modelsim and they look good.
I would look at the final result. There is probably no issue. 480p updates at 60Hz, movies at 24Hz, 480i at interleaved 60Hz. Let's say you moved 5 pixels every frame. That will move a ball across the screen in 640/5 or about 150 frames which is over 2 seconds. 1/2 second isn't unreasonable which is over 20 pixels per frame.
I want to ask 1 more thing. What is happening if i don't give a specific value to a pixel? its black by default?
For exemple:
if(x>30&&x<80&&y>30&&y<50) begin
R=3b`111;
G=3b`000;
B=2b`00;
end
The pixels of the specified area in if statement will be red, but what is happening with the others? Do i have to make an else and to give them a color or its automatically black?
Depends on the surrounding code. What do you set R, G, B to for other values of x and y. For example if you set R,G,B to 0 before you enter the "if", then they would be 0 by default if the "if" was not entered.
Question: What value do you think they would be if you didn't set them to a default value? Where would that value come from?
Question: What happens when you don't define all possible states for a case statement (or a sequence of if-else statements)?
Hello, I have some problems with implementing a vga controller on a nexys 2 fpga board.The HV synchronization module works fine at first view, monitors says it displays the right resolution 640x480. The problem is that the RGB module doesn't display what i write to do. For exmple for the folowing code it displays black instead of green and purple instead of white.
if(posx<=60&&posy<=100) begin
red<=3'b000;
green<=3'b111;
blue<=2'b00;
end else begin
blue<=2'b11;
red<=3'b111;
green<=3'b111;
end
Also for the next code it displays for 60x100 area green and if posy<100 and posx>60 it displays blue and rest of the screen is black... and it should display in 60x100 green and the rest of the screen must be blue.
red<=3'b000;
green<=3'b111;
blue<=2'b00;
end else begin
blue<=2'b11;
red<=3'b000;
green<=3'b000;
end
Does anybody had such problems and know what its wrong?
This is the UFC file.
net "clk50" loc = "B8";
net "HS" loc = "T4" ;
net "VS" loc = "U3";
net "red[0]" loc = "R9";
net "red[1]" loc = "T8";
net "red[2]" loc = "R8";
net "green[0]" loc = "N8";
net "green[1]" loc = "P8";
net "green[2]" loc = "P6";
net "blue[0]" loc = "U5";
net "blue[1]" loc = "U4";
first just display 1 color at a time on the whole screen to debug the color channels. Then once that is sorted out the rest will be easy.
If i don't put an if or else statement it doesn't display anything. Ill try to create another sync module. I think the one i use at this moment its buggy.
I have no idea what your code does overall.
If you just set red, green, blue in the always block, it should drive those pins to what you set them, which should be easy enough to probe.
I will display the code. It makes me crazy, it works like a paranormal thing :D.
The problem is the following. In RGB module in the always block if i say red<=x value, green <=y value etc it doesn't display anything, i must use an if-else statement to display anything. With the current code from RGB it displays a black rectangler for the positions posx<=60, posy<=100 only what is above posy=100 is magenta, the rest of the screen is black. So in this case if i combine green with red or blue, green it doesn't work. On the other hand, if i don't combine green with anything, it displays the right colors, but in the same way, with an if-else statement and anything below posy is black.
meBigGuy thanks for trying to help me. As i said above, i can't display any color without if-else. If i must use if posx<=639 && posy<=479 --- give values to red,green,blue else give other values to red green blue.
If i don't use the else it doesn't display any color, if i use if-else it displays the colors from if statements and the colors which must be displayed in else arent displayed below the value of posy from if... I can't understand what is the reason of this.
Code:
module VGASync(
	input clock,
	output reg HS,
	output reg VS,
	output reg [9:0] posx,
	output reg [9:0] posy);
parameter hsync_width=799;
parameter hsync_fall=655;  //pozitia unde se termina front porch sau unde semnalul devin 0
parameter hsync_rise=751;  //pozitia unde incepe back porch sau unde semnalul revine la 1
parameter vsync_width=524;
parameter vsync_fall=490;  //pozitia unde se termina front porch sau unde semnalul devin 0
parameter vsync_rise=492;  //pozitia unde incepe back porch sau unde semnalul revine la 1
always @(posedge clock) begin	if(posx >= hsync_fall && posx < hsync_rise) begin
		HS=0;
		end else begin
		HS=1;
	end
	if(posy >= vsync_fall && posy < vsync_rise) begin
		VS=0;
		end else begin
		VS=1;
	end
	if (posx < hsync_width)  begin
			posx<=posx+1;
		end else begin
			posx<=0;
			if(posy < vsync_width) begin
				posy<=posy+1;
			end else begin
				posy<=0;
			end
	end
end
endmodule
Code:
module RGB(
    input clock,
    input  [9:0] posx,
    input  [9:0] posy,
    output reg [2:0] red,
    output reg [2:0] green,
    output reg [1:0] blue
	 reg [6:0] size=0;
	always @(posedge clock)begin
			red<=3'b000;
			green<=3'b111;
			blue<=2'b00;
		end else begin
			blue<=2'b11;
			red<=3'b111;
			green<=3'b111;
	end
end
endmodule
Code:
module clock(
    input clk50,
    output clk25
	 reg clk25_int;
	 always @(posedge clk50) begin
		clk25_int<=~clk25_int;
	 end
	 BUFG buffer(.I(clk25_int),.O(clk25));
endmodule
Code:
module testop(
    input clk50,
    output HS,
    output VS,
    output [2:0] red,
    output [2:0] green,
    output [1:0] blue
	 wire clk25;
	 wire [9:0] posx;
	 wire [9:0] posy;
	 clock clock_inst(.clk50(clk50),
							.clk25(clk25));
	VGASync VGASync_inst(.clock(clk25),
								.HS(HS),
								.VS(VS),
								.posx(posx),
								.posy(posy));
	RGB RGB_inst(.clock(clk25),
					.posx(posx),
					.posy(posy),
					.red(red),
					.green(green),
					.blue(blue));
endmodule
If you have a simulator, then that is the way to do it. Build a testbench and look at waveforms.
I expect the IO is incorrectly connected/defined. I don't see anything obvious in your code.
I would set 1 color at a time in the if and make sure what I am seeing makes sense. Set the else section to all zeros. Or, just do the opposite. set the if portion to zero and set the else portion.
Try all ones for 1 color to start. Then verify each bit works for the color.
Regarding the verilog itself:
It is a good idea to name module outputs with _o and inputs with _i. Really helps with reading the code.
Also, line up the begin ends in whatever consistent method you want to use.
