Very bright geo satellite in my night sky?
  • Context: Undergrad
  • Thread starter Thread starter avicenna
    Satellites
The discussion revolves around the observation of a very bright object in the night sky, which some participants speculate may be a geostationary satellite, while others suggest it could be planets like Jupiter or Venus. The conversation includes attempts to identify the object based on its brightness and position over time, as well as the need for more specific observational details.
  • One participant notes seeing a bright object that remains stationary in the sky from 10 PM to 6 AM, questioning its identity as a geostationary satellite.
  • Several participants emphasize the need for the observer's location and specific coordinates to help identify the object accurately.
  • Some participants propose that the object could be Jupiter at night and Venus in the morning, based on its brightness and visibility.
  • There are suggestions that if the object is a planet, it would typically move with the stars, which raises doubts about its identification as such.
  • One participant mentions the possibility of the object being a geostationary satellite, noting its unusual brightness.
  • Another participant discusses the implications of brightness and distance, suggesting that if the object is as bright as Venus but much closer, it would have to be significantly larger.
  • Some participants express skepticism about the observer's ability to accurately identify the object based on the provided details.
  • There are recommendations for using apps like Stellarium or Google Sky Map to assist in identifying celestial objects.
Participants do not reach a consensus on the identity of the object. Multiple competing views remain, with some suggesting it is a planet, while others consider the possibility of it being a geostationary satellite.
The discussion highlights limitations in observational data, such as the lack of specific location information and the observer's uncertainty about the brightness and identity of the object. There are also unresolved questions about the object's movement and visibility conditions.
Astronomy enthusiasts, amateur astronomers, and individuals interested in celestial observations may find this discussion relevant.
avicenna
TL;DR
There is a very bright geostationary satellite visible in our nigh sky quite recently. It was there at 10 pm and was there at 6am at the same position which means it is stationary above a fixed position relative to the earth.
Something strange! There is a very bright geostationary satellite visible in our nigh sky quite recently. It was there at 10 pm and was there at 6am at the same position which means it is stationary above a fixed position relative to the earth. But the internet says we cannot see geostationary satellites which should at very high orbit.
So what is it. It is the brightest "star" almost like Venus when visible.
Astronomy news on Phys.org
Um, well um, er, I'm not sure how to say this...
What are the coordinates of this object (duh), or at least your lat/long on the Earth and which direction you are looking?
@berkeman is right - we need to know a) where you are, and b) where it is. Anything else you can tell us would be helpful. "Almost as bright as Venus" means what exactly? ASs bright as Jupiter? As bright as Venus at is maximum or minimum. Do you see a color? A disk?
We need more than "I saw something. What is it?"
I am looking slightly towards east; altitude is about 60 degree from horizontal. Sky not cloudy at 10pm and not a single other star visible. At 6am, also no other stars. sunrise about 7am.
[edit] I don't want to reveal my location fro privacy reasons. The point is taht it is at the same location at 10pm and 6am. Cannot be a bright light carried by weather balloon.
Well that narrows it down to the whole Earth. Thanks mucho. Counting down.... three one thousand, two one thousand, one one thousand (you don't want me to get to the zero one thousand)...
  • Haha
If you don't tell us where you are, it's going to be hard. It's like telling us "it's on my left".
Something to think about. Venus is 8000 miles across and on average about 100 million miles away. If something is as bright and 20,000 miles away, it's got to be about a mile and a half across, assuming it shines by reflected sunlight.
That's also my understanding. I don't understand why my location is needed, say Ecuador. The fact is it is at the same location and does not rise and set with the sun. I can't understand.
For all the details OP is giving us, we might as well to conclude it's Jupiter at night and Venus in the morning. I'm not sure I have enough confidence in their observational or communicaton skills to rule it out. :mad:
According to Stellarium, in Ecuador's sky Venus is about 35 degrees up in the Eastern sky at 6AM, and Jupiter is about 35 degrees up in the Eastern sky at 10PM.
Because there are lots of satellites up there.
However, there are also a lot of non-satellites.
In either case, knowing where you are and where you see it helps determining what it is. You can keep secrets, that's your choice, but how do you expect us to help you if you do?
That said, if you are at the equator, you should be able to work out where the putative satellite is over. Nevertheless, I think with what you have already told us, it is probably not a satellite. It may not even be a single object.
According to Stellarium, in Ecuador's sky Venus is about 35 degrees up in the Eastern sky at 6AM, and Jupiter is about 35 degrees up in the Eastern sky at 10PM.View attachment 333926
If it is a planet, it would move with the stars. But it is not moving. I will try watching at 10pm and then 3am tomorrow. At 6am today it was "there".
I would suggest you identify the object yourself.
Go to this site. https://www.heavens-above.com/main.aspx
Specify your location.
When you see the object, look to see what is predicted to be there in the sky.
No comment. Have fun. (oops, that was a comment, no?)
That's what I was thinking as well. A pair of binoculars would be able to verify it.
Only if you watch it long enough to see it move....and you said you didn't see any stars.
Another possibility is Saturn and Sirius.
With the information we have, which is the more likely possibility?
A, You are seeing two different objects.
B. There is a small moon-sized body in geosynchroinous orbit that only you can see. To give an idea of the size, I have a comparison between the size of the object and the largest rocket that might have launched it.
That's the speck on the bottom.
Do you have a smartphone? Download Stellarium. The app lets you point the phone at the sky, and displays in real time what you are looking at. I don't remember if the free version includes satellite data, but - like others - I don't think you'll need that.
Also Google Sky Map app.
If it was Jupiter and Venus, then it was a strange coincidence that I watched at 10pm and 6am when one planet replaced the other. I will watch tonight at 9.pm and follow up after to see if it sets. They almost have the same brightness, the brightest stars I have ever seen.
If you saw it around 10PM and 6AM, and your theory is that it's geostationary, you don't test the theory by looking again near 10PM and 6AM. You test it by looking at 2 AM.
You are dead right! The night star is Jupiter.
I look for the star at 9pm tonight but the Singapore (not Ecuador) sky was cloudy. At 11.30pm, the sky cleared and there was the lone, but bright star. It was clearly shifted west by an appreciable arc , say 20-30deg.
What confused me originally was I saw two different planets of similar brightness at about the same position at different times - 10pm and 6am! It is a rather rare event of coincidence. I could not distinguish the different brightness of Jupiter and Venus.
[edit]I was part cause of the rare coincidence; had I watched at 10pm and 12midnight, then I would have known the star was a planet.
@avicenna - I think your previous thought was absolutely right, and it is indeed a geostationary satellite. I was wondering since October 2023 who it belonged to. And it is indeed unusually bright, so that one can easily confuse it with Jupiter or even Venus. Well, I'm just happy somebody else noticed it too.
Greetings from Southern Germany!
  • Skeptical
So look at it with a good pair of binoculars. Even with those, Jupiter would stand out because 4 of the moons would be visible, for instance, you wouldn't need stellarium or some such software, which I have BTW and it is awesome.
I understand your scepticism (or anyone else's), but Jupiter can't currently be seen in Southern Germany before early hours in the morning. Whatever it was/is, it wasn't flickering like a star, but looked like a planet with its brightness closest to Jupiter. Then it started changing its brightness going from -2 to about -3.5 making it even brighter like Venus, then dimming again to -1 or so.
That's when I knew it was an artificial object. But it stayed in the same position all the time unlike other satellites in low orbit (which totally confused me, and for a moment, even scared me). Then I saw this object going brighter and dimming again a couple more times in the following months and wondered if there was some kind of an astrophysics experiment going on. (That's why I started googling it hoping to find someone else with similar observations.)
And my last logical explanation for this phenomenon is that it was just a drone. They are relatively inexpensive these days and somebody could have played a joke on me.
No, Jupiter can be seen before sun rise in southern Germany right now. Edit: also Mars and, out of frame, to the right Saturn.
Did you not understand post #16
There are a couple of simple tests for a geostationary satellite.
When seen at night, against the background of the "fixed stars", a geostationary satellite will appear to move at a rate of 15° per hour towards the east. You should be able to see a geostationary satellite creeping along with binoculars. Planets move very much slower against the background. During one night of observations with binoculars, you will not detect a planet moving.
A photograph, from a fixed camera, with a four-minute exposure, will show a geostationary satellite as a fixed point, while the stars will each form a short 1° long arc. A geostationary satellite in the photograph will appear to be brighter, since the light during those four-minutes is accumulated, and has not been spread over a 1° arc.
Geostationary satellites aren't usually visible to the naked eye and are certainly not as bright as planetary bodies or even bright stars, typically coming in at magnitudes +11 to +14, occasionally +5 or +6, with one being reported as about +3 once (source). Even in the darkest of skies under the best of viewing conditions geostationary satellites are almost impossible to see at all. At least without a telescope.
Totally grateful for all explanations except the one from glappkaeft. Every time I saw this object was about 10p.m. in Southern Germany, and I learned much later that Jupiter cannot be seen UNTIL the early hours in the morning (meaning before sunrise doesn't contradict my statement).
And I'm taking back my statement about it being a drone, because I saw it from two different cities in Germany. And now that I think of it, that would be way too much trouble for anyone to play a joke on me.
Avicenna's statement has caught my eye and I wondered if the two of us were referring to same thing. (The windows of my apartment face east.)
Anyway, google search has brought me here and being able to comment on Avicenna's statement was the sole reason for me to sign up. I'm a genetic genealogist who likes to look up to the sky once in a while, but I have little to no expertise when it comes to astrophysics.
Why not? Because he is not telling you what you want to hear?
Further, your messages are a couple of weeks apart. How do you know you are seeing the same object?
  • · Replies 56 ·
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 18 ·
