Vibration profile calculation for shaker table
The discussion centers on calculating the vibration profile for a device intended for testing on a Unholtz-Dickie shaker table. The user seeks assistance in determining the forces in three axes (X, X2, X3) based on the table's acceleration profile and the device's specifications, including a weight of 23.5 lbs and a required force of 30.59g at frequencies between 10 to 500 Hz. Concerns are raised about the shaker table's ability to deliver the necessary force, particularly at higher frequencies, and the need to understand acceleration spectral density (ASD) in relation to the device's testing parameters. The user ultimately finds a solution for calculating the required ASD values using specific equations based on the provided data. Accurate calculations are essential for ensuring the device can be tested effectively within the shaker table's operational limits.
yrealyea
Hi guys,
I hope we got some expert out here for vibration profile problems.
I have a device that need to be on a shaker table but I need to "find" its profile to see if the shaker table can actually run this experiment. The Shaker table is Unholtz-Dickie system SA30-560B and I have data of this table's profile in Acceleration (g PK) vs Frequency (Hz).
My device with fixture weights 23.5lbs, and I need to run it between frequency of 10 to 500 Hz with 30.59g force, this is a long life test. Can someone help me on finding the X, X2, X3?
Also that ASD stands for what? I can't figure out what that stands for, but the table's profile has in Acceleration of g-force Peak vs Frequency instead of ASD vs. Frequency.
ASD = acceleration spectral density (similar to power spectral density).
The values of x, x2, x3 are all defined by the graph and the table of values underneath. If you don't understand how to interpret the data, I think you need to review the basics of random vibrration theory and testing.
There is no way you will get 30g at 500Hz from that ASD specification.
You also need to check the force output is big enough to shake the mass (plus the mass of the table, etc) at 30g.
This http://www.acutronic.com/uploads/media/DataSheet-iTS-VibrationTestEquipment.pdf suggests the continuous power rating of the SA30 amp isn't big enough.
Alpha, I drew that chart with table there for convenient, I'm actually looking to calculate the three forces in 3 different axes on my device, so they are not the x, x2, and x3. I know that shaker table can't sustain the test somewhere below a hundred Hz. But I need to find out what is the exact range that it can't be tested so that I can skip that part of test and run the rest of profile that shaker can take.
Again don't worry about the fixture weight for now, can you tell me how you can calculate the PSD x, x2 and x3? I need those 3 values to compare it to the shaker table's profile and see at which point they overlap.
Thanks.
Bump, anyone able to help me?
I found the answer, in case anyone else like to know how to solve it.
I was giving an ASD value which represented value in mid (flat) line of profile, I used db/Oct and Hz, along with ASD flat line value with this equation:
P1=P2*(f1/f2)^((db/oct)/3)
P1 is value of ASD I'm looking for at f1=10 Hz
While P2 is the given ASD value of flat line of profile.
Also, if the value of db/Oct is negative then you will use this:
P1=P2/((f1/f2)^((db/oct)/3))
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
