Volume between two intersecting spheres using solid of revolution
2 replies · 3K views · last reply
themadhatter1
Find the volume of the solid that lies in between both of the spheres:
x2+y2+z2+4x+2y+4z+5=0
and
x2+y2+z2=4
This is the first chapter of the calculus III material so no double or triple integrals are needed to solve this problem.
I completed the square on the first equation and obtained:
(x+2)2+(y-2)2+(z+2)2=4
So I just have 2 intersecting spheres. Finding the volume of a "slice" of a sphere can be done using a solid of revolution, however, I would need know how far one sphere is intersecting into the other in order to calculate the volume.
My idea is to minimize the distance between (x+2)2+(y-2)2+(z+2)2=4 and the point (0,0,0). Then I will be able to figure out how "thick" the 2 "slices" of the spheres are.
However, I'm not quite sure how to do this. I know how to find the distance between points in space but solving for each variable I will wind up with 2 solutions because of the radical. Is there an easier way to do this that I am missing?
Thanks.
Well, the easiest way to solve this is by calculating a double integral with spherical coordinates, but you said that this is not needed.
Your method is also nice, but a little more work. Let's see if we can do it right.
We need to find the shortest distance between (0,0,0) and the equation [itex](x+2)^2+(y-2)^2+(z+2)^2=4[/itex].
We can do that by calculus by minimizing a certain function, but that might get tedious. Here's another method: the line which has the shortest distance connect (0,0,0) with (-2,2,-2) (the center of the circle). So you only need to set up the equation of the line and see where it intersects the sphere.
Genius! I love it. Can't believe I didn't think of that.
so for the line I I created the equation x=-2t,y=t,z=-2t
Next I plugged the equation into the sphere with it's center at (-2,1,-2) obtaining...
[tex] (-2t+2)^2+(t-1)^2+(-2t+2)^2=4[/tex][tex] 2(4t^2-8t+4)+(t^2-2t+1)=4[/tex][tex] 9t^2-18t+5=0[/tex][tex] t=\frac{1}{3},\frac{5}{3}[/tex]
The first t value is the one that will help me so I plugged it back into my equation for a line, obtaining[tex](\frac{-2}{3},\frac{1}{3},\frac{-2}{3})[/tex]
The distance from (0,0,0) to this point turns out conveniently be 1. So one half of the solid section has a distance of 1 from the edge of the sphere.
Now I integrate to find the volume of the whole solid.
[tex]2\pi\int^{2}_{1}4-y^2 dy = 2\pi[4y-\frac{y^3}{3}]^{2}_{1}=\frac{10\pi}{3}[/tex]
Does this look correct?
