Wavevector k in Helmholtz Equation
The discussion centers on the wavevector k in the context of the Helmholtz equation, derived from the wave equation through separation of variables. The wavevector k, defined as ##k = \frac{2\pi}{\lambda}##, is established as a fixed parameter in the equation, despite the existence of a spectrum of k values corresponding to different wave solutions. Participants clarify that while solutions can span multiple k values, each specific solution is derived for a singular, fixed k, leading to a set of solutions ##f_k## labeled by their respective wave numbers.
  • Understanding of the Helmholtz equation and its derivation from the wave equation.
  • Familiarity with the concept of wavevectors and their mathematical representation.
  • Knowledge of separation of variables as a method in solving differential equations.
  • Basic grasp of wave properties, including wavelength and frequency relationships.
  • Study the derivation of the Helmholtz equation from the wave equation in detail.
  • Explore the implications of fixed versus variable wavevectors in wave mechanics.
  • Investigate the role of boundary conditions in determining specific solutions to the Helmholtz equation.
  • Learn about the applications of Helmholtz equations in various fields such as acoustics and electromagnetism.
Physicists, engineers, and students studying wave phenomena, particularly those interested in the mathematical foundations of wave equations and their applications in various scientific fields.
fog37
Hello Everyone,
Helmholtz equations derives from the wave equation by using separation of variables and assuming that the solution is indeed separable ##g(x,y,z,t) = f(x,y,z) T(t)##. The solutions to Helmholtz equations are functions of space, like f(x,y,z), and do not depend on time t.
the wavevector ##k = \frac{2\pi}{\lambda}## is present in the equation. Is that a constant or a variable? Solutions can span a spectrum of ##k## values so I don't believe the ##k## in the equation can be a constant otherwise the equation would be limited to function having a single and specific k value...
Thanks
Different k values correspond to different waves with respect to wavelength or direction
True, but in the equation, is the k to be take as a variable?
Oh, that was your question. No, wavevector k is fixed.
I would say that the wave vector ##\mathbf{k}## is a parameter, since you solve the equation for fixed ##\mathbf{k}## but the value depend on the specific problem you want to solve.
so are you saying the solutions to this equation can only have a single k since the equation itself has a single k?
Presumably, this is a matter of convention. But, my personal point of view is the following (maybe other people on this forum will not agree). In your first post you are saying:
We have therefore a set of solutions ##f_k## labeled by the wave number ##\mathbf{k}##. As, I said before you are then solving the equation for a fixed ##\mathbf{k}## and obtain one ##f_k##. You can then repeat this and solve for arbitrary number of values of ##k## depending on which solutions on the set you are interesting in.
  • · Replies 0 ·
