What angle maximizes projectile range from elevated terrain?
  • Thread starter Thread starter John 123
    Projectile
11 replies · 3K views
John 123
A projectile is fired from a height of
[tex] y_0[/tex]
ft above a level terrain,with a velocity of
[tex] v_0[/tex]
and at an angle
[tex] \alpha[/tex]
with the horizontal.
Find
a. The equation of the particle's path.
I have solved this:
[tex] y=y_0+(\tan\alpha)x-\frac{g(\sec^2\alpha)}{2(v_0)^2}x^2[/tex]
b.It's horizontal range-take the x-axis on ground level.
I have also solved this as the horizontal range is found from setting y=0
this leads to a quadratic in x and taking the positive root gives the range.
c. It's maximum height.
Again I have solved this by setting dy/dx =0
Finally
[tex] y_{max}=y_0+\frac{v_0^2\sin^2\alpha}{2g}[/tex]
d. When will it reach the ground?
Again I have solved this.
[tex] t=\frac{range}{v_0\cos\alpha}[/tex]
The denominator is the horizontal component of vo.
IT IS THE NEXT PART THAT I CANNOT SOLVE.
e. What is the value of alpha that will make the range a maximum?
John
Hi John! :smile:
John 123 said:
Find
I have solved this:
ok, what is the range that you found, and that you now have to maximise?
In part (d) what is "range"? The given quantities are v0, α and y0. Unless you assume that the projectile returns to the same height y0, you will not be able to proceed. If this assumption is valid, take y0=0 and proceed as tiny-tim suggests. But you do need to find an expression for the range in terms of the given quantities.
OK the range is obtained by setting y=0.
This leads to the following quadratic in x.
[tex] \frac{g\sec^2\alpha}{2v_0^2}x^2-(\tan\alpha)x-y_0=0[/tex]
This leads to a complicated expression in x the positive root of which is the range.
The problem now is finding
[tex] \frac{dx}{d\alpha}[/tex]
and setting it to zero to find the value of alpha to make x a maximum.
John
First off set y0 = 0. Then re-express all trig functions with sines and cosines. Then it should be obvious to you what's going on.
With yo=0
[tex] x=\frac{v_0^2}{g}\sin2\alpha[/tex]
Then with
[tex] \frac{dx}{d\alpha}=0[/tex]
[tex] \frac{2v_0^2}{g}\cos2\alpha=0[/tex]
This gives
[tex] \alpha=\pi/4[/tex]
However how do we solve this problem to include y0.
The book answer to this question is:
[tex] \sin\alpha=\frac{v_0}{\sqrt(2(v_0^2+gy_0))}[/tex]
First you need to solve the equation you have with y=0
[tex] <br /> 0=y_0+(\tan\alpha)x-\frac{g(\sec^2\alpha)}{2(v_0)^2}x^2<br /> [/tex]
for x. The larger of the two values is the range (Why?). Then, as tiny-tim said, maximize that function.
Hi kuruman! :smile:
I think you meant set y = 0. :wink:
But using sec2 = tan2 + 1 is probably easier. :smile:
I have set y=0
Then the equation is:
Now need to express x explicitly in terms of alpha, then find dx/d(alpha)
then equate
The equation is a quadratic in x and the roots are complicated and finding dx/d(alpha) is the problem?
John
John 123 said:
The equation is a quadratic in x and the roots are complicated …
… and the day is long :redface:, and the wages are small :redface: …
get on with it! :rolleyes:​
[tex] y_0[/tex]
is the height above ground level from which the projectile is fired.
John
