What Are the Maximum and Minimum Voltages Generated by a Generator?
3 replies · 5K views · last reply
zebra1707
Hi there, motor and generator gurus
Suppose a generator has the following specifications, and the rotor turns with frequency 10 Hz. Determine the maximum and minimum value of the voltage generated, using the formula: ε = Βlv
n = 1000 loops = 1000
B = 10 Tesla
I = 10 current of coil in Ampere (A)
A = (0.05 m x 0.1 m) area of coil in m2
τorque = 500 Nm
ε = Βlv maximum voltage is E0 = NABω Since ω = 2pif
My solution is maximum voltage 1000 x 10 x (0.005) x 2 x pi x 10 = 3141 V
Minimum voltage = E0 = 0 (min voltage must be zero)
Assistant needed as my voltage is excessive IMO.
Cheers and thanks
I think I have worked it out, can someone please confirm.
10 Hertz converted to radians is 62.83, therefore my volts would drop to 314 V
and minumum - if e = 0, then the minimum voltage should be 0.
Cheers
Hi there, and help!
I have been attempting to nut this out and could use some guidance.
I think that I have the equation right now E(max) = 2 x n (turns) x B(in tesla)x L x v sin (theta).
Based on the info already available (see previous post) the max voltage is 1000 V.
Can someone please confirm.
Cheers
