What can I use to make clear dish soap thicker?
  • Thread starter Thread starter everywhere
    Soap
A user seeks to create a clear, viscous paint by thickening transparent dish soap, initially experimenting with food coloring. They identify propylene glycol (PPG) and alkyl dimethyl amine oxide as potential thickeners but are unsure of their transparency and viscosity. The discussion highlights the effectiveness of Carbopol products as ideal thickeners, although retail availability is limited. Alternatives such as polysaccharides (agar, alginate, carrageenan) and gelatin are suggested for achieving desired thickness, with gelatin combined with gum arabic recommended for creating a gummi-like consistency. The conversation emphasizes the importance of experimenting with various thickeners to achieve the right texture and transparency for the paint.
everywhere
Hello this is my first post to this forum though I've lurked before.
I want to paint with something 100% clear and quite viscous. I added food coloring to transparent dish soap and that is so far the best solution to a clear paint body, but I want to make it thicker. I found a list of common ingredients in dish soap here, and I may be mistaken but I figured if I knew which ingredient is a thickening agent that doesn't increase opacity, I could simply add more of it to the dish soap and get a thicker gel.
From what I could find only the PPG (propylene glycol) and alkyl dimethyl amine oxide are thickeners. So I would like to know if any of you know the properties of these chemicals. How transparent are they and how viscous are they? And is it possible to buy in retail quantity? I found PPG on amazon but I'm not sure if it's the right thickness. I found this DOW link and I'd like to get my hands on their thickest product but of course I can't buy in bulk from DOW.
I've looked into other thickeners that are clear, stearic acid seems like my best bet and if anyone's worked with it before I'm wondering if I would have to melt it in with soap and generally how it performs generally.
Chemistry news on Phys.org
You're painting with soap? Anyway, the dimethylamine oxide is one of the surfactants... not a thickener. The PPG/PEI/PEG copolymers are functional in surfactants formulations. They are wetting agents, emulsifiers and coupling agents. The real thickener wasn't given in that answer.
For thickeners, go here.
Yes I am. Thanks my bad.
I just spent about 3 hours reading from that link. The Carbopol products look perfect. Would you know where to get their products at retail? The only retailer I could find is http://www.islandartisansupply.ca/index.php?main_page=product_info&products_id=414, I think I'll try them but they only have one carbopol formula, I want to try others mainly the ultrez 21 too.
The only other possibility involves making up a business name and asking the supplier for a sample (bad idea?)
I don't think you'll find Carbopol at any retail stores. If you are limited to what you can find retail, and I include scientific supply houses as retail, I would use other polymers like polysaccharides (agar, alginate, carrageenan) or gelatin. You can make these compounds into as thick a solution as you want, even something as thick as a gummi (using gelatin). http://pubs.acs.org/doi/abs/10.1021/ma00176a029 that reports the unusual thickening of gelatin/anionic surfactant combinations. Sounds like it's right up your alley. In combination with gum arabic, gelatin can thicken in a spectacular way... all the way to gummi-like jelly. Dissolve the gum arabic in some water and combine small amounts of this dilute solution to the solution of gelatin.
I really like the Carbopol type thickening. It makes processing amazingly easy provided there aren't any multivalent metals in the formulation. Of course as a chemist I can get samples fairly easily. YMMV.
Yeah okay. I still might get Carbopol from that one supplier I found if they work out but now I will definitely get some gelatin and gum arabic the next time I'm out. Thank you very much.
Pectin is cheap and it is used for thickening all kinds of foods. Easy experiment.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
