What Determines the Flow Speed in Differently Sized Horizontal Tubes?
Hypnos_16
Seawater flows through a horizontal tube of diameter 3.00 cm that is joined to a second horizontal tube of diameter 1.70 cm. The pressure difference between the tubes is 7.25 kPa. What is the speed of flow in the first tube?
I thought it was P1 + 1/2 pv2
turns out it isn't
i don't know if it's cause I'm stressed, or just missing something, i cannot get this question to work.
Note: P1 + 1/2 p v1^2 = constant = P2 + 1/2 pv2^2.
Do you also need to apply the conservation of mass ?
The conservation of mass? and what "Constant" are you talking about there?
The conservation of mass will allow you to relate the speed of the fluid in the two different size pipes and the pipe diameter.
Bernoulli's equation says P + p v^2 / 2 + p g h = constant. So if you know these values at one point, you know them at the other.
