What Dimensions Minimize Material in a Paper Cup Designed for 8oz?
tjc9
company manufactures paper cups that are designed to hold 8 fluid ounces
each. The cups are in the shape of a frustum of a right circular cone (so the top and
bottom of the cup are circles, not necessarily of the same size, and the side profile is
that of a trapezoid). What are the dimensions for a paper cup that minimizes the
amount of material used?
The volume of the cup would be pi/3(R^2+Rr+r^2)h
The surface area would be pi(r)^2+pi(R+r)sqrt((r-R)^2+h^2​
Know that I'd need to hold volume constant at V=8 fl. oz. or 14.4375 in.^3. Know I need to minimize the surface area of the cup. I solved for h in the volume equation then substituted that into the area equation. I don't know where to go from there because if you take the partial derivatives it becomes way too complicated.
I believe you should use the lagrange multiplier method, minimizing the function of the area using the constant volume function as a constraint. Are you familiar with such thing?
I know sort of how to but not with that function. Also, what constraint would the volume function create
The problem can range from almost-impossible to nasty but do-able, depending on how you represent it. Your representation is just about impossible with your choice of variables, although it can be solved easily enough using a numerical optimization package.
I found it much better to represent the frustrum as an actual difference between two cones of radii ##R## and ##r## and of heights ##H## and ##h.## We have ##R = H t## and ##r = h t##, where ##t## is the tangent of the half-angle at the apex of the cone. It is best to leave it as just ##t##, rather than as ##\tan( \theta/2).##
When I did all of that the Lagrange multiplier method became just barely practical.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
14K
