What Do These Assembly Instructions Do with $30 in Register d0?
  • Thread starter Thread starter chelsea9947
1 reply · 2K views
chelsea9947
If the content of d0 is $30 state in words what each of the following numbered instructions will do when placed immediately after the test instruction below
tst d0
a) bne fred
b) beq fred
c) bpl fred
d) bmi fred
a) bne fred = [go to label fred] [if d0] [not equal to $30]
b) beq fred = [go to label fred] [if d0] [equal to $30]
c) bpl fred = [go to label fred] [if d0] [ plus $30]
d) bmi fred = [go to label fred] [if d0] [minus $30]
example
TST or tst direct against zero instruction.
This is really the same as compare with zero
tst <effective address>
it subtracts 0 from a copy of the location specified and sets the condition flags accordingly.
If the value to be tested is positive then +N –0 = +N or if negative –N –0= -N or if 0 then 0-0 =0
tst d0 is d0 equal to 0, greater than zero or less than zero
beq joe = [go to label joe] [if d0] [equal to 0]
bgt dan= [go to label dan] [if d0] [greater than 0]
blt ben= [go to label ben] [if d0] [less than 0]iam confused can someone help
If the content of d0 is $30 state in words what each of the following numbered instruction pairs will do.
a. cmpi #$30,d0
beq dan
b. cmp.l unknown,d0
bne dan
c. cmp.w d1,d0
bgt dan
tst d0
a) bne fred
b) beq fred
c) bpl fred
d) bmi fred
These are not right. I'm a little rusty on Motorola 68000 assembly (which is what I think you are using), so I assume these instructions are inspecting the contents of the D0 register.
bne <label> - means branch to <label> if d0 is not equal to zero.
beq <label> - means branch to <label> if d0 is equal to zero.
bpl <label> - means branch to <label> if d0 is positive (plus).
bmi <label> - means branch to <label> if d0 is negative (minus).
chelsea9947 said:
example
These all look fine to me.
a. cmpi #$30,d0
beq dan
b. cmp.l unknown,d0
bne dan
c. cmp.w d1,d0
bgt dan
These compare instructions subtract the first operand from the second and set the N and Z flags as appropriate. For a, D0 - #$30 = what? Does control branch to label dan?
For b, you don't know what value is in unknown, but whatever value is in this location, it is either >= $30 or < $30.
For c, you don't know what is in D1, but you can say what will happen depending on what value is in that register.
