What does a spectrogram represent?
  • Thread starter Thread starter skyisthelimit
A spectrogram represents the distribution of frequencies in a sound signal over time, displaying the amplitudes of specific frequencies. In Audacity, it visualizes an entire sound clip, showing how frequencies change throughout the duration. Each peak in the spectrogram corresponds to a sound, with higher peaks indicating louder sounds. The spectrogram is derived from the Fourier transform, which analyzes time-varying signals like music. Limitations include the inability to represent very low frequencies depending on the update rate of the spectrogram.
skyisthelimit
Hi,
I am wondering what does a spectrogram represent? I know that a spectrogram displays the amplitudes of specific frequencies, however, in the program Audacity, it plots a spectrogram of an entire sound (a few seconds). What does this spectrogram represent, and how is it different to at an individual time?
cheers.
Funny you bring Audacity up. Thanks to you I've just realized I installed it by mistake instead of Audacious.
You have two readouts, one is left speaker the other is right speaker.
That's your stereo.
Now, each peak represents a sound (if it was a simple drum beat each second you would have a single peak each second on the graph).
I believe that the higher the peak, the louder / stronger the sound is.
Here's the Wiki on it: http://en.wikipedia.org/wiki/Spectrogram
skyisthelimit said:
Hi,
cheers.
A spectrogram is basically the Fourier transform of a signal. For example, if you have a time-varying signal (like music), the spectrogram tells you the distribution of frequencies in the music.
There's a few subtleties to consider- a time-varying spectrogram means there is a lower limit on the frequency that can be represented (for example, a spectrogram that updates 30 times a second can't tell you anything about frequencies below about 60 Hz), and the spectrogram also 'bins' the frequencies like a histogram, but those are usually minor details.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 165 ·
10K
