What does "induced radiation" mean in this H-atom problem?
  • Thread starter Thread starter Saitama
    Wavelength
84 replies · 17K views · last reply
I like Serena said:
That is the right number! :smile:
(But the wrong unit! You're still specifying angstroms! :wink:)
Edited! :smile:
I like Serena said:
Does it match with one of your answers?
Yes it matches the (c) option but the answer is (a) option.
I like Serena said:
And to repeat my question, is it possible the electron is excited to energy level 3?
Because if so, then other wavelengths might be induced.
No, it's not possible.
Right! :)
Interesting.
The (a) option is literally true, since the induced radiation cannot have a shorter wavelength than the exposed radiation.
But option (c) is also right afaik, since this is the only radiation that would be induced, and the answer is a little sharper.
The answer is (a). That's because you performed some miscalculation.
You can solve this exercise almost without any calculation.
I think it's better to think in the proper energy unit for this problem, eV (electron volt). You will handle with shorter numbers and the thinking will be easier. However, you can take what I say and do it in Joules, it will (and has to) be the same.
To get the energy in electron volt you just have to think that [itex]1\,\,eV=1.6\cdot 10^{-19}\,\,J[/itex].
So, to get an idea, start by transforming the incoming photon energy into eV and then the ground state energy of hydrogen atom.
Then compare these two energies. Is the energy of the incoming photon higher or lower than the ground state? If it is higher, the electron will be bounced outside the atom (the atom will be ionized). If not, the electron could jump to another orbital if the energy gap between the initial and ending orbital is exactly the energy of the incoming electron.
Can you post here the comparison between the ground state energy of hydrogen and the energy of the incoming photon? (Either in joule or eV, as you wish...)
What does this comparison say to you? Remember that, after the fourth/fifth energy level, you can consider the spectrum nearly continuous, at least for a rough calculus.
Can you solve the exercise now?
Ah, I see the problem now.
As DiracRules already said, you miscalculated.
Can you calculate the induced wavelength if the electron falls back from the 3rd energy level to the 1st?
Hi DiracRules! :smile:
The energy of the incoming photon is around 12.1 eV and the ground state energy of the H-atom is 13.6 eV. The energy is much less, so i don't think electron will be bounced outside the atom.
I don't understand what do you mean by "If not, the electron could jump to another orbital if the energy gap between the initial and ending orbital is exactly the energy of the incoming electron." :confused:
Is the wavelength 102.573 nm?
Pranav-Arora said:
Is the wavelength 1025.73 nm?
I get 102.518 nm, but that is close enough, if at least you convert it to actual nanometers! :smile:
Is that more or less than the exposed radiation?
I like Serena said:
I get 102.552 nm, but that is close enough, if at least you convert it to actual nanometers! :smile:
Your answer is less than the exposed radiation and mine is more than the exposed radiation.
My bad, again I didn't check, and I didn't expect the problem to be so sharply defined.
I've looked up the proper value of the Rydberg constant for Hydrogen, which is:
RH = 1.09678 x 107 m-1.
Filling this in, I get 102.573 nm.
So you were right! :smile:
:biggrin:
Now what we have to do next?
Pranav-Arora said:
:biggrin:
Well, my question was: what is the highest energy level the electron can jump to.
Can you answer that?
And after that, what are the possibilities for the electron falling back to a lower energy level?
And after that, what are the corresponding induced wavelengths?
And after that, what is the lowest possible induced wavelength?
Is the highest energy level infinity?
If so, then the lowest possible induced wavelength is 91.17 nm.
But how would i calculate the possibilities for the electron falling back to a lower energy level and the corresponding induced wavelengths?
Sorry I mistyped. I meant "If not, the electron could jump to another orbital if the energy gap between the initial and ending orbital is exactly the energy of the incoming photon."
To find the minimum wavelength of the induced radiation you just have to realize that emission is the absorption process seen backward: if the electron absorbs a photon with, say, 1J and gets excited, then it will come back to the ground state emitting a 1J photon. So, since you found that the maximum the energy, the lower the wavelength, you just have to calculate whether or not the incoming photon will bounce the electron in the ground state in an excited state.
If it gets excited, then it will emit the same amount of energy it receive. If not, it won't emit anything.
How do you find the energy of orbital?
I don't think i our case that the electron would bounce to the excited state since i calculated the energies as you said in a previous post.
That's not correct.
You can use the Bohr equation for the energy:
[itex]E_n=\frac{R_H}{n^2}[/itex]
where you can put [itex]R_H=13.6\,\,eV[/itex].
Now, you said correctly that the ground state is 13.6 eV, whilst the energy of incoming photon is 12.1 eV.
So if it gets excited, it will jump to a state whose energy [itex]E_n[/itex] is the remnant from incoming photon and the energy of the level. This is possible if the Bohr equation is verified. You have to check the one and only condition of that equation: that n is an integer.
DiracRules said:
That's not correct.
How it will get excited when the energy of incoming photon is 12.1 eV? :confused:
Because the actual energy of the electron is -13.6eV, while the energy of the photon is +12.1eV.
Remember that all the bounded levels have negative energies. It will get excited if there exists a level at [itex]E_0 + E_{photon}[/itex]...
I thought of using the negative sign before but i got confused.
Anyways what i have to do next? :smile:
Have you checked whether the number fits with Bohr equation?
Here are the steps:
1) Find the possible energy of the excited state (I told you how to do in the previous post)
2) See if it fits in Bohr equation for energy, that is: calculate [itex]n[/itex] and see if there is something wrong.
3) Make your deductions...
Which number? :confused:
(This question is making me mad. Btw, it's getting late night here, i am off to bed :smile:)
What I mean is: if you put in the equation [itex]E_n=\frac{R_H}{n^2}[/itex] the values of [itex]E_n[/itex] and [itex]R_H[/itex], is there an integer that fits well in [itex]n[/itex]? If so, then the electron can get to the excited state, else it can't.
That's all.
That's all.
What should be the value of [itex]E_n[/itex]? :confused:
You seem to be missing something here, but I don't understand what it is you are missing.
The highest energy level is indeed infinity, but that level cannot be reached since there is not enough energy in the incoming photon.
Btw, I've been checking up on this problem.
As DiracRules stated earlier, the photon can only be absorbed if its energy matches one of the jump-energies of the electron (almost) exactly.
After that the most energetic photon that can be emitted is a photon of this same wavelength.
A less energetic photon would have a longer wavelength.
In this question, electron cannot jump to the second level too since the energy of the incoming photon is 12.1 eV.
Am i right? :confused:
Yep.
The electron will jump to the 3rd level.
I like Serena said:
Yep.
Why it cannot jump to infinity. :confused:
Not enough energy in the incoming photon.
It would need 2 incoming photons, but only one can be absorbed at a time, after which a photon is emitted, before a new photon is absorbed.
But i am not able to understand why the answer is (a) option?
An incoming photon is absorbed, making the electron jump from the first to the third energy level.
This electron falls back to the ground state and emits a photon of the same wavelength as the absorbed photon.
Doesn't that match with answer (a)? :confused:
Where is your global view? If this were a test paper question, you should be solving it in about 1 minute.
If an atom is excited to an upper level, the energy of the emitted photon could be the same as the energy of incoming radiation - if the drop to ground state is done in one step - or smaller, if the drop back goes via lower levels.
Those lower energy emissions have a longer wavelength, so the SHORTEST wavelength [that is what we were asked about in the question] is the same as the incoming radiation.
Option (a) is the nanometre equivalent of the Angstrom description of the incoming radiation - so would be the answer.
Note: the only other possibility was that the incoming radiation was not an exact match for one of the excited state - in which case it would be elastically scattered, and we would see option (a) for that reason.
To paraphrase the question:
"Did you know that the energy of a photon given off by an excited atom is no higher than the energy of the incoming radiation exciting the atoms?" - in combination with "Did you know that minimum wavelength corresponds to maximum energy?"
Other than recognising that the Angstrom wavelength corresponded to one of the nonometre wavlengths, no calculations were necessary in the question [as befits the idea that you should have completed the question in one minute]
Sorry for the late reply but i thought i would first go through our discussion.
Why doesn't the electron jump to the second level?
What do you mean by "elastically scattered"?
Yes i know that the energy of a photon given off by an excited atom is no higher than the incoming radiation, but is the energy given off always equal to that of incoming radiation?
And yes i know that energy is inversely proportional to wavelength. :smile:
That's all.
I still don't understand what should i put the value of [itex]E_n[/itex].
