What does it mean when equipotential lines are closer together?
3 replies · 10K views
mujadeo
Can someone please define contour map for equipotential surfaces in really simple terms.
I understand that the potential diff is from the neg side
I don't understand what it means when the lines are closer together?
I thought the lines are just divisions of the voltage, and an equipotential surface means that the potential anywhere along each individual line is uniform, but it is different from line to line (cuz your moving further or closer to the negative)
Please help!
an example:
if this is contour map, what do the close-together lines mean??
An analogy is a contour map for elevation (topographical). The closer spaced lines indicate the elevation changing more rapidly (example: hill or ravine). With equipotential surfaces, closer spaced lines indicate that potential (voltage), is changing more rapidly over distance. Here is an http://www.britannica.com/eb/art-1327/Equipotential-surfaces
Ok thanks, that helps, but now i guess I am having prob with the actual word.
"EQUI" ... --what exactlly is equal in the contour map? i am assuming equi word root means "equal"
All points along any given line have equal potential.
Just like on a map, all points on any line have equal altitude.
