What is a separable vector space?
9 replies · 4K views · last reply
fog37
Dear forum,
I am trying to understand what a separable vector space is. I know we can perform the tensor product of two or more vector space and obtain a new vector space. Is that vector space separable because it is the product of other vector spaces?
thanks
No. A separable space contains a countable dense subset. The product of two vector spaces will not be separable unless the two original vector spaces were.
The notion of a vector space alone is not sufficient for separability to be well defined.
Thank you.
What would a countable dense subset be? I understand it contains a subset of vectors that has a particular property. Could you give me an example of what a countable dense subset means from ordinary finite dimensional linear algebra? Let's consider the vector space of vectors
##v=(v_{x} , v_{y}, v_{z})##...
fog37 said:
Thank you.
Dense makes no sense on a vector space only. You'll need further structure, like a norm, a distance or a topology.
For example, the vector space ##\mathbb{R}^3## can be equipped with the norm
[tex]\|v\| = \sqrt{v_x^2 + v_y^2 + v_z^2}[/tex]
A countable dense set can then be given by [tex]\{v~\vert~v_x, v_y,v_z\in \mathbb{Q}\}[/tex]
But let's start with the basics, do you know what a norm is?
Also, where did you encounter the notion of separable? Seeing the context might help.
Obviously. This is implied by the "dense". Without some sort of topology, this is not well defined.
You know that. I know that. The point is that the OP might not.
Hi micromass,
The norm is, conceptually, the "length" of a vector. I run into the idea of separable vector space in introductory quantum mechanics where Hilbert vector space is said to be separable. this leads down to the discussion of such a space being a tensor product of other vector spaces...
fog37 said:
Hi micromass,
OK, since it's in the context of Hilbert spaces, I can give a simpler definition of separable. All it means is that there is a countable orthonormal basis. That is: there is a subset of the Hilbert space ##\{e_n~\vert~n\in I\}## with ##I## countable, which intuitively means ##I## finite or ##I=\mathbb{N}## such that
1) ##\|e_n\| = 1## for all ##n##
2) ##<e_n, e_m> = 0## for ##n\neq m##
3) Every ##x## in the Hilbert space can be written as ##x = \sum_{n\in I}\alpha_n e_n## for some ##\alpha_n\in \mathbb{C}## (it can be shown that ##\alpha_n =<x,e_n>##). Note this sum is an infinite sum (=series) when ##I=\mathbb{N}## and convergence comes into play, which makes it distinct from linear algebra where all sums are finite.
As an example in ##\mathbb{C}^3##, take ##(1,0,0)##, ##(0,1,0)##, ##(0,0,1)##. These are orthonormal and form a basis.
