caumaan
- 33
- 0
What is anti-energy? Does it have some of the awesome energy-based counterarts of antimatter? Applications?
The discussion revolves around the concept of "anti-energy," exploring its potential connections to antimatter and negative energy within the context of physics. Participants examine theoretical implications, applications, and the nature of negative energy in general relativity, as well as related phenomena such as entanglement and faster-than-light (FTL) travel.
Participants express a range of views on the validity and implications of anti-energy and negative energy, with no consensus reached on these concepts. The discussion includes both supportive and critical perspectives on the theories presented, particularly regarding entanglement and FTL travel.
Limitations include the unclear definitions of "anti-energy" and "negative energy," as well as the speculative nature of discussions surrounding FTL travel and time travel. The relationship between negative energy and physical solutions in general relativity remains unresolved.
Originally posted by selfAdjoint
Negative energy is a concept that principally concerns general relativity. [/B]
Originally posted by Doctor Luz
It also concerns parapsycologists, ghosts and all of this stuff...
Jocking appart, what is the negative energy in general relativity? is a specific concept of GR or is simply that the solutions are negative numbers?
Negative values for energy are common on classical and semiclassical physics. This only deppends on the reference value you set for the energy.
So they allow the solutions would be physical but not until someone comes up with the negative energy. Which they hope never happens, because that way lies FTL, and FTL leads to time travel and time travel breaks causality.
Its been found that you can arrange 2 electrons so they have opposite spins. There total spin in this case = 0. Now if you measure the spin of one of the electrons in a particular way then the electron will always measure, say, -1. When the other electron spin is measured, and it doesn't matter how, it will indicate 1. And it works opposite also. You can use the other method to measure the first electron and it will then measure 1. And no matter how you then measure the second electron it will measure -1. And the moment a person measures the first electron "instantly" the second measures the opposite
selfAdjoint said:The negative energy in the GR solutions for worm holes and metric engineering would be genuine if the solutions were physical. Physicists are reluctant to call the solutions unphysical, because that would be arbitrary. What if it were discovered that black holes solutions had negative energy somewhere?
Thanks for clearing that up. I've often wondered in the back of my head why the principle of entanglement couldn't be used in principle to transfer information instantaneously... Would be handy for those robots many light-minutes away, and have ramifications for possibly sending very small sensor objects to other stars. Now I know. :)selfAdjoint said:Uncertainty means you don't have the control over the particles you think you will. You can never be sure the particle you choose to tweak isn't already tweaked. And you only get one tweak; the first one destroys the entanglement. So the entanglement can only be seen in the statistics of particles.
