What Is Dark Matter?
  • Context: High School
  • Thread starter Thread starter DaTario
    Dark matter Matter
54 replies · 9K views
bapowell said:
The quantum vacuum doesn't have a mass, it has an energy.
General Relativity allows one to infer gravitational effects from energy densities.
Best wishes
DaTario
Astronomy news on Phys.org
It's more than just energy density, though, but also momentum density, pressure, and shear. Though in the isotropic case only energy density and pressure provide any contribution.
Indeed. Did I say anything that was counter to that?
Chalnoth said:
... But for nucleons, the situation is entirely different. The strong nuclear force, instead of dying away with distance, actually gets stronger. This means that if you hold a quark and anti-quark some distance apart, the strong force between them produces a very large positive potential energy, rather like if they were held together by a spring under tension. In fact, if you pull the quark and anti-quark too far away from one another, the tension between them gets so great, that a quark/anti-quark pair pops out of the vacuum between them and instead of a pair of quarks, you now have a pair of mesons.
Anyway, so if you have three quarks, two ups and a down, sort of the minimum-distance configuration they can have is actually so that these gluon "springs" between them actually have quite a lot of tension. So much, in fact, that protons aren't just made out of three quarks, but three quarks plus a whole bunch of quark/anti-quark pairs continually popping in and out of the vacuum. Of course, energy is conserved when these quark/anti-quark pairs pop in and out, so you can think of the extra energy as coming from the tension of these gluon "springs" between the quarks.
This is so cool! :cool:
Chalnoth, you should write a popular science book! Before, I knew that there where something called Quantum Chromodynamics, and I knew how it 'looks', but definitely not the 'mechanism' behind (and I have watched Frank Wilczek on YouTube).
[URL]http://www.physics.adelaide.edu.au/~dleinweb/VisualQCD/QCDvacuum/su3b600s24t36cool30actionHalf.gif[/URL]
The "spring under tension" is absolutely brilliant – I understand that!
I know it’s ridiculous to promote 'intuition' in science, but to me as a layman – I can smell there’s something "around the corner" in physics and cosmology. To me, 'forces' in physics have always been a complete magic mystery – How the h**l can this magnet attract this other magnet on a distance, when there’s absolutely nothing between!?
And the answer is – Virtual Particles! Basically the same 'mechanism' that works inside nucleons!
I’m going to place a substantially (virtual :smile:) bet: That the force of gravity also must include virtual particles (feel free to laugh)! I admire Albert Einstein, but I never really liked the 'rubber sheet'... because it’s a kinda 'weird' rubber sheet, that makes the apple fall onto my head... straight down...
Just one question: What prevent the ups and down quarks from 'imploding' into a micro black hole? (Uncertainty principle?) Or reversed, what creates the strong tension?
Chalnoth said:
The total aggregate mass of dark matter is many times that of the normal matter. This doesn't mean that the particles themselves need to be particularly massive. Though many dark matter candidates are very massive, axions, for instance, are not.
Okay thanks. The obvious conclusion – there can be a lot of DM particles.
they has not seens its yet therefore making it hard prove its existence... not denying that it does though
In order for an object to become a black hole, its stress-energy must be compressed into a region smaller than a sphere of radius equal to the Schwarzschild Radius:
[tex]R_S = \frac{2Gm}{c^2}[/tex]
where m is the mass of the object. While elementary particles don't have a well defined 'size', a common way to give them dimension is to talk about their Compton wavelength:
[tex]\lambda = \frac{h}{mc}[/tex].
From the uncertainty principle, one sees that this is the minimum uncertainty in the location of the particle.
Therefore, the question of whether an elementary particle will collapse into a black hole depends on whether its Compton wavelength is larger or smaller than its Schwarzschild radius. The particles of the Standard Model have Compton wavelengths many many orders of magnitude larger than their Schwarzschild radii (try it!)
bapowell said:
... Therefore, the question of whether an elementary particle will collapse into a black hole depends on whether its Compton wavelength is larger or smaller than its Schwarzschild radius.
Thanks bapowell, the Schwarzschild solution is very interesting, and I’m going to dig into that.
So one could say that the Uncertainty principle + Compton wavelengths give the quarks a "dimension/size", right?
And this "dimension/size" is what causes the gluon "springs" tension, right?
Could one also summarize and say that - the Uncertainty principle is the base for the "Quantum Chromodynamics Mass" in nucleons?
Not really, no. In QCD, quarks are precisely point-like particles. In a quantum-mechanical sense, of course, this is a bit subtle of a definition to grasp, but ultimately it means that the interactions between quarks and gluons are modeled in QCD as occurring at singular points.
Nope. Now, it turns out that the mathematics that goes into modeling the particles as points in QCD (and in electroweak theory) leads to infinities. We get rid of these infinities by sort of artificially cutting off the sums at some high energy (which is equivalent to assuming that there is some size, even if we don't know what it is). The behavior at high energies is then modeled with a series of parameters that must be measured experimentally. So if the particles are actually extended objects, such as strings (as in string theory strings), then these sums have a natural cutoff at some rather high energy, and the theory is finite.
This has nothing to do with the uncertainty principle, mind you.
I don't think that it has anything to do with that at all.
Thanks Chalnoth. This is real hard for a layman to grasp, especially in translating this into a 'working picture'. I guess these things (only) works best in the mathematical world.
I’ll try to rephrase:
Chalnoth said:
... Anyway, so if you have three quarks, two ups and a down, sort of the minimum-distance configuration they can have is actually so that these gluon "springs" between them actually have quite a lot of tension.
The strong nuclear force is the (attractive) force that holds quarks together to form nucleons, right?
What force (or phenomenon) sets "the minimum-distance configuration", which results in that the gluon springs "actually have quite a lot of tension" (outward)?
I think it can be understood as just the zero-point energy configuration of the system, in a similar way to the zero-point energy configuration of the Hydrogen atom (S0). Obviously the math is quite a bit more complex, but I don't think the uncertainty principle has a lot to say here.
Could you think of it like – the quarks always want to be free (maybe silly), they always want to "run away", but the strong force wants to hold them together? And this is what causes the gluon "springs" tension...?
(... maybe this works in kindergarten ...? :smile:)
That might be more reasonable.
There is electrostatic repulsion amongst some of the quarks. That makes them maybe want to run away. At least that's what my 1st grade teacher always said.
But it's the uncertainty principle that makes the quarks want to run away. I don't see why one should say that it has nothing to do with it - or with zero point energy, for that matter.
Thanks Chalnoth & bapowell. This gives me some hope on 'basic understanding'.
Okay, now I’m confused again... I feel little like that "uncertainty principle" has taken over my whole body... :confused:
Actually, the electrostatic repulsion is nearly negligible for the interiors of nucleons. The strong nuclear force is just so vastly stronger that it doesn't make much difference (it makes some, of course). I think I'll have to revise my statement and suggest that Ich is largely correct here.
George Jones said:
Unlike photons, gluons can be (colour) charged, and the interaction of virtual gluons plays a role here. See pages 68-70 (largely qualitative) from
http://books.google.com/books?id=w9Dz56myXm8C&printsec=frontcover#v=onepage&q&f=false.
Yup, the fact that the gluons themselves carry strong-force (color) charge means that they couple not only to quarks, but also to themselves. This is what makes it so that the strong force acts sort of like springs between the quarks, as the charged gluons form a sort of tube between nearby quarks.
And what Griffiths calls "gluon polarization" dominates at short distances and thus drives the strong coupling constant towards zero at short distances (page 70). But, as you say, only detailed calculation (worthy of Nobel prizes :biggrin:) can verify this.
Okay guys, if a layman would wrap this up, it’ll be:
"the strong force acts sort of like springs between the quarks"
And the reason the quarks don’t BOOM! gets sucked into a micro black hole, is the uncertainty principle (making it impossible to nail down those little bastards).
This leads to a tension (virtual energy) inside the nucleons, and this energy can be translated to 90% QCD Mass.
Einstein: E = m (big!)
Correct?
(Can I have the Nobel Prize now?? :biggrin:)
P.S. George thanks for the link to http://books.google.com/books?id=w9Dz56myXm8C&printsec=frontcover#v=onepage&q&f=false"!
Not quite. There's a bit more to the story. It's probably more correct to say that quarks simply aren't energetic enough. If you look back at the expression I posted above, as you increase the mass/energy of the particle, the Schwarzschild radius gets larger while the Compton wavelength gets smaller. Eventually, you reach an energy scale at which they meet. Then you get a black hole. Thinking in terms of the uncertainty principle, one sees that as the energy increases, the minimum uncertainty in the location of the particle decreases (this is the reason for the decrease in the Compton wavelength). Then, when that minumum uncertainty becomes smaller than the Schwarzschild radius, BOOM!, we form a black hole.
bapowell said:
Not quite. There's a bit more to the story. ...
Okay, thanks bapowell.
Correction:
And the reason the quarks can resist the strong force (inwards), is the uncertainty principle.
Correct?
Thanks Chalnoth! Finally it feels like I have some 'weight' in QCD! :cool:
