What is intrinsic time-dependence in the Schrödinger picture?
  • Context: Graduate
  • Thread starter Thread starter carllacan
The discussion revolves around the concept of intrinsic time-dependence in the context of the Schrödinger picture of quantum mechanics. Participants explore the definitions and implications of time-dependence for operators, particularly in relation to external fields and the comparison with the Heisenberg picture.
  • One participant seeks a formal definition of intrinsic time-dependence and questions how a Schrödinger-picture operator can exhibit time-dependence.
  • Another participant provides an example of a Hamiltonian that becomes explicitly time-dependent due to a varying external electric field, illustrating the concept of time-dependence in the Schrödinger picture.
  • A participant contrasts the time-dependence of Schrödinger operators with that of Heisenberg operators, noting that the latter includes both explicit time dependence and evolution due to the Hamiltonian.
  • Further clarification is provided on the distinction between total derivatives and partial derivatives in the context of time-dependence, using a fluid dynamics analogy to explain the differences in operator behavior between the two pictures.
  • It is noted that in the Schrödinger picture, the operators are non-dynamical, and all time-dependence is contained within the state vectors, while the Heisenberg picture reverses this relationship.
Participants express varying levels of understanding and agreement on the definitions and implications of time-dependence in the Schrödinger and Heisenberg pictures. Some points are clarified, but no consensus is reached on the broader implications of intrinsic time-dependence.
The discussion includes assumptions about the definitions of time-dependence and the roles of operators in different quantum mechanical pictures, which may not be universally agreed upon. The implications of these definitions remain unresolved.
carllacan
There are many things in this sentence that I don't get
Ballentine 91 said:
"The [Shcrödinger picture] operator could have intrinsic time dependence if it represented the potential of a variable external field, or if it were the component of a tensor defined with respect to a rotating coordinate system."
What does exactly mean intrinsic dependenc? I think I know the answer, but I'd like a formal definition, if possible.
Now, the sentence come up in the context of Schrödinger / Heisenberg picture. How is it possible for an Shcrödinger-picture operator to be time-dependent, be it explicitly or implicitly?
Here's an example. Say an atom has the Hamiltonian H = H0. It's a function of whatever internal atomic variables you want to use, H(p, q) say.
Put the atom in a uniform external electric field and the Hamiltonian becomes H = H0 + Ez. Npw suppose the electric field is time varying, E = E0 cos ωt. Then the Hamiltonian H = H0 + E0z cos ωt is explicitly time-dependent.
It's now H(p, q, t).
And how does that differ from the time-dependence of a Heisenberg operator?
The time-dependence of a Heisenberg operator has 2 parts in it. 1 part is the explicit time dependence, as Bill_K noted, and the other part comes from the time evolution due to the Hamiltonian. The Heisenberg picture is one in which the state vectors are not time dependent, they stay still, so all the time evolution, explicit and implicit, has to be encoded into the operators.
If in Bill_K's post, you had H(p,q)=H0 and no explicit time dependence, there are still operators which ARE time dependent if they don't commute with H.
In the Schrödinger picture, ##\frac{d}{dt}A_S = \frac{\partial}{\partial t}A_S## which is what we mean when we say a Schrödinger operator is at most explicitly time dependent. The ##\frac{d}{dt}## is a total derivative and is to be contrasted with the partial derivative ##\partial_t##.
To touch base with something you're probably already familiar with, consider the velocity field ##\vec{v}(t,\vec{x})## of some classical fluid. Then ##\frac{d}{dt}\vec{v} = \frac{\partial}{\partial t}\vec{v} + (\frac{d \vec{x}}{dt}\cdot\vec{\nabla}) \vec{v} = \frac{\partial}{\partial t}\vec{v} + (\vec{v}\cdot\vec{\nabla}) \vec{v}##; what ##\frac{d}{dt}\vec{v}## does is follow the dynamical time evolution of ##\vec{v}## along the flow lines of ##\vec{v}## which means it considers not only the explicit time dependence of ##\vec{v}## but also the dynamics of ##\vec{v}## governed by the evolution of ##\vec{x}## under forces (Newton's 2nd law), whereas ##\partial_t## simply considers the explicit time dependence of ##\vec{v}##. The operator ##\frac{d}{dt}## is also called the convective derivative in fluid mechanics.
In that same spirit, for a Heisenberg operator we have ##\frac{d}{dt}A_H = \frac{\partial}{\partial t}A_H + \frac{i}{\hbar}[H,A_H]## so ##\frac{d}{dt}A_H## tracks the dynamical evolution of ##A_H## whereas ##\partial_t## just evaluates the explicit time dependence of ##A_H##. On the other hand a Schrödinger operator is non-dynamical so ##\frac{d}{dt}## only evaluates the explicit time dependence of the operator. Therefore when we say that the states ##|\psi \rangle## contain all the time-dependence in the Schrödinger picture what we really mean is, in the Schrödinger picture it is the states that are dynamical i.e. the operators are non-dynamical; in other words the states evolve dynamically under the Schrödinger equation ##i \hbar \frac{d}{dt}|\psi \rangle = H |\psi \rangle## whereas there are no equations of motion for the Schrödinger operators ##A_S## as the only quantity of relevance for them is ##\frac{\partial}{\partial t}A_S##. In the Heisenberg picture it is the other way around.
OK, I think I get the idea.
Thank you very much, all of you.
