What is the Cross-Correlation Theorem for Continuous Fourier Transform?
  • Thread starter T.Engineer
    Integral
20 replies · 6K views · last reply
T.Engineer
can anybody find the result for the following equation:
F(d)= [tex]\int^{T_f}_{0}p(t)p(t-d) dt[/tex]
where
916; = d but it doesn't appears very well
and
p(t) = (-1)^n * e^(t^2) * d/dt * e^(-t^2)
thanks a lot!
I am sorry I didnt write it correctly
p(t) = (-1)^n * e^(t^2) * d^n/dt^n * e^(-t^2)
where n= 1,2,...,N
I just want a general formula for the result
Have you attempted at an answer? What technique(s) have you tried? Integration by parts comes to mind...
my question is how to find a general formula for the following
where
and
n=1,2,...,N
Thanks a lot!
And my response is 'why do you keep putting n's in and then taking them out?' State the question precisely. I presume you're just supposed to do it for n an integer, rather than for n=1,2,3,...
That p_{n} is, up to a normalization constant, a Hermite polynomial of degree "n". So try looking that integral in mathematical tables of integrals or ask Mathematica software about the result.
"There are many functions - called special functions - which fail to
have an anti-derivative expressible as a finite combination of
elementary functions. The so-called elliptic functions, the error
function, and the gamma function are a few examples. The error
function, which is extremely useful in both physics and statistics, is
defined as:
erf(x) = (2/sqrt(pi))integral from 0 to x of e^(-t^2)dt
Extensive tables of the error function would not exist if the
anti-derivative of e^(-t^2) were expressible as a finite combination
of elementary functions."
http://mathforum.org/library/drmath/view/53554.html
defined as:
p(t) is not an exponential. It's a polynomial as dextercioby has already pointed out.
I have realized the same because, as dextercioby had pointed out, there is a closed solution for n=1.
Here's how I'd approach the problem (and I communicated this to T.Engineer at least once before, under Statistics & Probability). I'd start with n=1 and calculate the closed solution, which is easy. Then move on to n=2, 3, ..., and see if there is a pattern.
There are also recurrence relations for the Hermite polynomials which could be exploited without rediscovering them empirically. It's clear there is no exponential in the final integral since exp(-t^2) comes out from the differentiation intact and cancels with the exp(t^2) without even knowing there are closed form solutions for particular n.
Right; the fact that a closed solution exists is sufficient but not necessary to see that it is not the error function, or any other special function.
If anybody is interested in pursuing this, here's a Maxima (free math software) program to compute the nth case. It should be pretty self explanatory.
p(t,n):=expand(exp(t^2)*(-1)^n*diff(exp(-t^2),t,n));
integ(n):=p(t,n)*subst((t-d),t,p(t,n));
final(n):=integrate(integ(n),t,0,Tf);
E.g. typing 'final(7);' after this is entered computes the n=7 case.
Please, can you tell me from where can I download this program.
Thanks a lot!
Thanks a lot!
Try http://maxima.sourceforge.net/. If you are running a debian flavor linux it might be as simple doing 'apt-get install xmaxima'.
T.Engineer said:
I am running windows Xp.
Then get, for example, maxima-5.12.0a.exe from the downloads section.
can you help to find a general formula for the autocorrelation function Hermite polynomials.
Thanks a lot!
