What Is the Fastest Descent Direction on Mt. Everest in a Snowstorm?
  • Thread starter Thread starter wannabeengg
    Gradient
The discussion revolves around determining the fastest descent direction on Mt. Everest during a snowstorm, focusing on the relationship between direction traveled and elevation change. The problem involves concepts from calculus and vector analysis.
  • Participants discuss the need to define variables and formulate equations related to the descent direction and rate. There are mentions of using partial differentiation and gradient vectors to analyze the slope. Some participants suggest simplifying the problem by assuming a planar surface and using trigonometric methods.
The conversation is ongoing, with participants offering guidance on how to approach the problem. There is an exploration of different methods to find the steepest descent, but no consensus has been reached on a specific solution or method yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is uncertainty regarding the formulation of the necessary functions for the problem.
wannabeengg
1. While descending Mt. Everest you are caught in a sudden snowstorm. Unable to see more than a few feet in front of you, you determine through careful observation that if you travel three meters northwest you climb 1/2 meter, and if for every two meters you travel northeast you descend 1/4 meter.
1. In which direction should you start for fastest descent?
2. If you travel in this direction at two meters per second, what will be your rate of descend?
3. Derive an expression for your rate of descent as a function of the direction traveled and the speed in that direction.
4. In what direction should you go in order not to go up or down?
I am having trouble in forming the functions.Kindly help
welcome to pf!
hi wannabeengg! welcome to pf! :wink:
in questions like this, give the unknown a name, and then write out the equations
in this case, start by saying that the (steepest) slope is pointing θ west of north …
what do you get? :smile:
Hello there, thanks for the kind welcome! i am not used to in other forums. Well my proffssor gave us a hint about using partial differentiation and also using the gradient vector. To find the steepest slope, we have to use ||the gradient of function f || or in other words the magnitude of gradient vector f. The main problem which i am having is about forming the function. I don't know what to do :-(
hello wannabeengg! :smile:
(just got up :zzz: …)
the gradient is necessary if it's a complicated surface, but we can assume that this is a plane, so just draw a line of greatest slope, drop a perpendicular onto a horizontal plane, and use ordinary trig :wink:
  • · Replies 51 ·
9K
9K
  • · Replies 21 ·
14K
  • · Replies 21 ·
