What is the final position of the stone after being stopped by the spring?
  • Thread starter Thread starter lgn_barnard
    Energy Spring
The discussion focuses on the physics problem involving a 15.0 kg stone sliding down a frictionless hill and encountering a spring with a force constant of 2.10 N/m. The stone reaches point B with a speed of 22.65 m/s after traveling 100 m on a rough horizontal surface with a kinetic friction coefficient of 0.20. The participants emphasize the importance of calculating the correct kinetic energy and accounting for friction during the spring's compression to determine how far the spring compresses and whether the stone will move again after being stopped.
  • Understanding of kinetic and potential energy equations (PE = mgh, KE = 0.5mv²)
  • Knowledge of spring mechanics (spring energy = 0.5kx²)
  • Familiarity with friction coefficients and their effects on motion
  • Basic algebra skills for solving physics equations
  • Calculate the effect of kinetic friction on the stone's motion using the equation F_friction = μ_k * m * g
  • Learn how to apply conservation of energy principles in systems involving springs
  • Study the relationship between static and kinetic friction in motion problems
  • Explore advanced topics in dynamics, such as energy loss during motion on rough surfaces
Students studying physics, particularly those focusing on mechanics, as well as educators looking for problem-solving strategies in energy conservation and friction applications.
lgn_barnard
A 15.0kg stone slides down a snow-covered hill (the figure (Figure 1) ), leaving point A with a speed of 11.0m/s . There is no friction on the hill between points A and B, but there is friction on the level ground at the bottom of the hill, between B and the wall. After entering the rough horizontal region, the stone travels 100 m and then runs into a very long, light spring with force constant 2.10N/m . The coefficients of kinetic and static friction between the stone and the horizontal ground are 0.20 and 0.80, respectively.
What is the speed of the stone when it reaches point B?
22.65 m/s (this is correct)
How far will the stone compress the spring?
Will the stone move again after it has been stopped by the spring?
picture: Mastering Physics
PE = mgh
KE = .5mv^2
spring energy = .5kx^2
I set up the equation
.5mv^2=.5kx^2+(kinetic friction)mgL
0.5(15)(22.65^2)=0.5(2.1)x^2 + 0.2(15)(9.8)(100)
I solved for x to equal 29.4, but this is wrong
Please show your reasoning.
Please attach any diagrams referred to.
What kinds of energy does the stone start out with?
It looks like you have included only the initial kinetic energy - but with the wrong speed.
First find the final velocity of the stone when it reaches the spring. From this you can find the kinetic energy, this will be the energy that it imparts on the spring. Now once it's stopped find the static frictional force on the stone, and compare it with the force that the spring is exerting. This is how I would solve it, break it into bite sized chunks.
Your equations look fine. However, you'll have to take into account that the friction force acts also during the compression of the spring. It is only said that the stone travels 100m before it runs into the spring.
So if I add (.2)(15)(9.8)(x) to the right side of the equation if should come out correct?
Why don't you try it and see?
It's faster that way, and you learn more.
is 22.65m/s the speed when the stone hits the friction section?
[edit - oh I see it is]
we don't have the diagram remember.
It is best practice to do all the algebra before plugging numbers in.
28K
