What is the inverse of this logarithm equation?
  • Thread starter Thread starter supernova1203
    Inverse Logarithm
The inverse of the logarithmic equation y = -log5(-x) is y = -5-x. To derive this, one must first express the original equation in exponential form, resulting in 5-y = -x. By switching x and y, the inverse is obtained as 5-x = -y, leading to the final form y = -5-x. This process confirms that the initial confusion regarding y = log5(x) was incorrect.
  • Understanding of logarithmic functions and their properties
  • Familiarity with exponential equations
  • Knowledge of function inverses and graph transformations
  • Basic algebraic manipulation skills
  • Study the properties of logarithmic functions in detail
  • Learn how to derive inverses of various types of functions
  • Explore graph transformations and their implications on function behavior
  • Practice solving exponential equations and their inverses
Students studying algebra, particularly those focusing on logarithmic and exponential functions, as well as educators looking for clear explanations of function inverses.
supernova1203
y=-log5(-x)
i tried it and i got y=-5(-x)hm.. you know how people say that if you want to find the inverse graph of something just switch the x and y coordinates from the table of values? Well i also tried that approach and apparently the inverse is y=log5x
atleast that's how it looks on table of values and on the graph...i don't know why i went with the y=-5(-x)I don't know if i got it right or not, someone kind enough to take a look and see if i got it right or not? or maybe just give me the solution outright so i know if i did it correctly or not? :P
Your result is correct. If you start from your original equation, multiply both sides by negative 1, you can easily switch x and y, and carry couple simple steps to find y as a function of x.
hm... so y=log5x is correct?
No! Your first result was correct. y=-5^(-x)
ahh ok ty
Original equation: y=-log_{5}(-x)
-y=log_{5}(-x)
Now express exponential form :
5^{-y}=-x
Now, switch x and y to create inverse:
5^{-x}=-y,
and then simply, y=-5^{-x}
y=-log5(-x)
To check if you're right, when you get to the equation x=-5^{-y}, just plug that value of x into your original equation y=-\log_5(-x) and see if you get an equality.
