What is the solution set for dy/dx = 3y?
  • Thread starter Thread starter intenzxboi
    Integrate
9 replies · 21K views
intenzxboi
can some one explain to me how the set of all solutions for dy/dx = 3y
is.
y= Ce^3x
Simply separate the variables.
[tex] \begin{align*}<br /> \frac{dy}{dx} & = 3y \\<br /> \frac 1 y \frac dy dx & = 3 \\<br /> \int \left(\frac 1 y\right) \left(\frac{dy}{dx}\right) \, dx & =\int 3 \, dx<br /> \end{align*}[/tex]
You should be able to finish from here.
Try rearranging your equation to get it in the form f(y)dy=g(x) dx. Then integrate both sides.
This type of differential equation technique is called 'separation of variables'
i got y= e^3x + e^c
how does that become y= Ce^3x
this is variable separable. c is constant, then you can make it In c so that when using the e function, In c become only c.
The function is LN, not IN. The letters come from Latin: logarithmus naturalis.
Here's a proof of the general case that I got from Courant's Introduction to Calculus and Analysis. This is one of my favourite proofs:
"If a function y = f(x) satisfies an equation of the form [tex]y' = \alpha y[/tex] where [tex]\alpha[/tex] is a constant, then y has the form [tex]y = f(x) = ce^{\alpha x}[/tex] where c is also a consant; conversely, every function of the form [tex]ce^{\alpha x}[/tex] satisfies the equation [tex]y' = \alpha y[/tex].
It is clear that [tex]y = ce^{\alpha x}[/tex] satisfies this equation for any arbitrary constant c. Conversely, no other function satisfies the differential equation [tex]y' - \alpha y = =[/tex]. For if y is such a function, we consider the function [tex]u = ye^{-\alpha x}[/tex]. We then have
[tex]u' = y'e^{-\alpha x} - \alpha y e^{-\alpha x} = e^{-\alpha x}(y' - \alpha y}) .[/tex]
However, the right-hand side vanishes, since we have assumed that [tex]y' = \alpha y[/tex]; hence [tex]u' = 0[/tex] so that u is a constant c and [tex]y = ce^{\alpha x}[/tex] as we wished to prove."
