What is the spectral paradox?
  • Topic: Insights
  • Thread starter Thread starter trilobite
    Paradox
17 replies · 7K views · last reply
trilobite
Insights Author
trilobite submitted a new PF Insights post
Exploring the Spectral Paradox
Line graph of spectral radiance against wavelength, rising from near zero to a peak near 2.5 then falling, with a light blue shaded band over the descending part of the curve and the title 'Article' above.
Continue reading the Original PF Insights Post.
Wow! Your article was like a good invention; obvious to everyone after being explained by the inventor.
Overall, the key point to remember is that one must be careful when interpreting spectral curves, especially their peaks
Is there a general rule to follow in data analysis that would let us avoid such paradoxes?
"rubbish" was my first reaction. haha good start.
But the apparent paradox is only there because such graphs don't have a full explanation of the scale units. Δf Hz is not equivalent to a fixed step size of Δλ m so different powers will be admitted into uniform steps of frequency than in uniform steps of wavelength, as you sweep across the frequency (or wavelength) spectrum.
f=c/λ
so
df/dλ = -c/λ2
and df = -cdλ/λ
That impresses a scale factor of 1/λ across the width of the wavelength spectrum. The peaks cannot coincide. The range covers around an octave so the effect is both significant and annoying.
Thinking about it, it doesn't even surprise me that the peak of our vision is at the peak of frequency sensitivity because it's the energy of the photons the counts and that is hf. (Permission to dump on me about that last point)
Would this paradoxical behaviour show itself in any filter design that's based on wavelength (some delay line filters, perhaps)? We are so used to using frequency analysis of circuits.
Yes: be aware of what is being plotted against what! (Do as I say and not as I do. :wink:)
This isn't a paradox; it's simply that the power-spectral-density is being calculated as per unit wavelength differential instead of as per unit frequency unit. To call it a paradox would be like saying that it's paradoxical that an apple is an apple and and orange is an orange. I want my 5 minutes back.
We could avoid this dichotomy by expressing Power Spectral Density as Power Log(spectral) density, i.e., instead of
W/(m^2 * delta(nm)),
use
W/(m^2 * delta(log(nm)))
This should give the same shape curve as
W/(m^2 * delta(log(THz)))
because
log(nm) = log(c)-log(THz),
thus removing the nonlinear mapping between the wavelength and frequency based metrics.
As with the original unit, denominator is area times an interval. Here, the interval in the measurement unit would actually be the difference of the logarithms of the ends of the interval, or the log of the ratio of the ends of the interval.
We don't even have to use logarithms if we force the interval in the measurement to be constant on a log scale, i.e., a constant ratio such as a milli-octave.
use
because
The paper by Soffer and Lynch does make a similar point concerning the alternative of using a logarithmic representation. However, the authors state that this method has "no special physical significance" and should not be "singled out as a preferred physical ... representation" for electromagnetic spectra, even though it does cause the wavelength and frequency peaks to coincide. As a wavelength, that peak for solar radiation is approximately 720 nm, according to the paper. Note that that value is very close to Heald's median point of 710 nm, as I suspect the mathematics imply, although Heald does describe the value as "physically meaningful!"
My own opinion is that, while all of the above points are valid and interesting, they don't directly address the "paradox" at issue here. That's because this kind of paradox is primarily a psychological or pedagogical matter, not a physical or mathematical contradiction. Granted, some people may not feel the paradox, at all. But for those (like me) who do, a detailed exploration into where that sense of paradox is coming from can perhaps be helpful in dispelling it.
I would think it could be a useful exercise to find other situations in Science where a peak in a curve shifts according to the units on the x axis.
Strangely, (visible) light tends to be specified in terms of wavelength (the fault of history and the result of the prism / diffraction grating). Other members of the EM spectrum tend to be measured in terms of frequency / energy. In my opinion, because frequency is the variable that remains the same, it is a more suitable measure. Using frequency would have prevented a lot of confused questions on PF and other places about the assumed change in frequency at a boundary. (because, they say fλ=c etc.)
I'm quite confused about this part:
The important point here is that you get that same value whether you measure the area under the wavelength curve (Fig. 1) or under the frequency curve (Fig. 2), even though the two curves have different shapes!
Reference https://www.physicsforums.com/insights/exploring-spectral-paradox/
Check out the formulae in Hyperphysics and WikipediaWe see that:
##B_{\lambda}=\frac{du}{d\lambda}\cdot g \quad ,\quad B_{\nu}=\frac{du}{d\nu}\cdot g##
where: ##\quad g=\frac{hc}{\lambda}\cdot \frac{a}{e^{\frac{h\nu}{kT}}-1}##
a
is some coefficient.How do we show that the two integrals are equivalent?
##\int \frac{du}{d\lambda}\cdot g \quad d\lambda \quad, \quad \int \frac{du}{d\nu}\cdot g \quad d\nu##
It's the Definite Integral that counts. The Integral between the limits of λ will be equal to the integral between equivalent limits of ν. You have to do the job completely.
There's more to the Definite Integral than just the inverse of Differentiation.
hmm, do you have a link to the mathematical proof?
Is a proof needed that the energy between the limits of frequency and the corresponding limits of wavelength is the same? It's the same energy and the same conceptual filter letting it through. I know that Maths is usually required here but this constraint comes before the Maths - not after a proof (I would have thought). :smile:
I managed to figure out how it works :smile:
The proof was basically staring at me right in the face. :DD
I would like to understand better this paradox. I tried to have a mathematical approach, if I take the distribution function ##f(\lambda)## for ##\lambda## and ##g(\nu)## for distribution function of ##\nu## : then I can apply the transfert theorem :
$$f(\lambda)\text{d}\lambda = g(\nu)\text{d}\nu$$
So, I get : $$g(\nu)=|\dfrac{\text{d}\lambda}{\text{d}\nu}| f(\lambda)=\dfrac{c}{\nu^2}f(\lambda)$$
We can notice that : ##g_{max}=\text{max}(\dfrac{c}{\nu^2}f(\lambda))\neq f_{max}##
I tried to find the relation between ##\lambda_{max}## with ##f_{max}=f(\lambda=\lambda_{max})## and ##g_{max}=g(\nu=\nu_{max})##, more precisely
the relation between ##\lambda_{max}## and ##\nu_{max}## (which is not simply ##\lambda=\dfrac{c}{\nu}##).
For this, starting from ##g(\nu_{max}) = g_{max}##, I took : $$\dfrac{\text{d}g}{\text{d}\nu} = 0$$
Giving also :
$$-2\dfrac{c}{\nu^{3}}f(\dfrac{c}{\nu})-\dfrac{c}{\nu^{2}}\dfrac{\text{d}f(\dfrac{c}{\nu})}{\text{d}\nu}=0$$
Finally, I get, that seems to be wrong, the equation : $$\dfrac{\text{d}f}{\text{d}\nu}=-\dfrac{2}{\nu}f$$
So, have I got to conclude by writing :
$$f(\nu)= \dfrac{\text{A}}{\nu^{2}}$$ with ##A## a constant to determine ?
I don't know how to conclude, the last relation seems to have no sense, doesn't it ?
If I am on the wrong track, please let me know. Any help is welcome
Regards
Firstly there is no paradox. ;)
The apparent problem relates to the Definite Integral and the different limits when you choose to integrate wrt f or wavelength. This has already been dealt with. I can't think how to resolve it without introducing integration. But why avoid that when it's the whole basis of Energy Density.
