What is vector-like matter?
  • Context: Graduate
  • Thread starter Thread starter meha
    Matter
The discussion centers on the concept of "vector-like matter" within the context of theoretical physics, particularly in relation to gauge theories and supersymmetry. Participants explore the definition, implications, and distinctions between vector-like and chiral matter, referencing various theoretical frameworks and papers.
  • Some participants inquire about the definition of "vector-like matter" and its origins, with references to specific academic papers.
  • One participant suggests that vector-like matter refers to fermionic matter with vector-like couplings to standard model gauge fields, contrasting it with chiral couplings of ordinary fermions.
  • Another participant raises a question about the implications of vector-like matter in the absence of SU(2) x U(1) groups, seeking clarification on the distinction between chiral and non-chiral matter in larger gauge groups like SU(5) or SO(10).
  • A participant discusses the relationship between chiral superfields and vector superfields in supersymmetry, questioning whether different concepts are being conflated.
  • One participant argues that the term "vector-like matter" is misleading, emphasizing that it pertains to interactions rather than the matter itself.
  • Another participant clarifies that vector-like matter can arise from spinors constructing bilinear vectors or axial vectors, and that the terminology can be confusing.
  • There is a correction regarding the nature of the neutrino current, with distinctions made between left chiral and axial currents.
Participants express differing views on the terminology and implications of vector-like matter, with no consensus reached on its definition or the clarity of the concepts involved.
The discussion reveals limitations in understanding due to the complexity of the concepts and the potential for conflating different theoretical frameworks. Specific assumptions about gauge groups and interactions remain unresolved.
meha
What is "vector-like" matter?
Hi,
can someone please tell me what vector-like matter is?
meha
can you tell us where you found the term "vector-like matter"?
Unfortunately they do not write down the kinetic part of the Lagrangian.
I suspected that it has something to do with spin, but w/o the Lagrangian it's hard to tell. In addition they talk about a scalar superpartner, but the superpartner to a spin-1object is not spin-0.
It looks like they're using the term to imply that the new (fermionic) matter has vector-like couplings to all standard model gauge fields. This is to be contrasted with ordinary standard model fermions, which have chiral SU(2)xU(1) couplings.
Thanks. According to the reference hep-th/9903387 vector-like is used synonymously with non-chiral. Which means that left and right components transform differently under SU(2) x U(1). But what if these groups are not present? What would be the distinction between chiral and non-chiral matter for SU(5) or SO(10)?
Just to make sure: "chiral" means that there is a gamma matrix projector in the Dirac kinetic term, whereas "vector" means it looks like in QED w/o such a projector?
Thanks for all your thoughts.
Probabli the best translation is tom's "like in QED".
Historically, the problem of GUT models has been to avoid vector-like interactions. Actually, vector-like *matter* is a misnomer; it refers to *interactions*
Now I am confused. In susy theories there are chiral superfields as well as vector superfields, completely independent of interactions. (http://en.wikipedia.org/wiki/Supersymmetric_gauge_theory). Chiral fields are defined by [tex]\bar{D} \Phi=0[/tex]. Vector fields one the other hand are identical to their hermitian adjoints [tex]V = V^{\dagger}[/tex]. Am I intermingling different concepts here?
Yes, the concepts are different and the name vector-like matter is misleading.
As far as we understand the paper the situation is as follows: one uses spinors (!) to construct either bilinear vectors (like the el.-mag. current from the fermion field) or bilinear axial vector (like the left-handed neutrino current in el.-weak theory). The currents are coupled to other fields, in these examples the photon field or the Z- and W-field.
If the current is a vector, the matter is called vector-like even if the matter field itself is a spinor. (this is my interpretation of the discussion)
Strictly, the neutrino current is left chiral, not axial. A left chiral current is vector minus axial vector (or V-A); and a right chiral current is V+A.
You are right.
  • · Replies 28 ·
  • · Replies 25 ·
13K
