What Patterns Emerge When Visualizing Infinity on Non-Flat Surfaces?
  • Level: Graduate
  • Thread starter Thread starter exmachina
    Infinity Surfaces
8 replies · 3K views
exmachina
Try drawing this mentally:
Start with a circle of radius r, draw n number of points spaced evenly on the circle. at each point on the circle draw another circle of radius r, once again with n number of points. What sort of a picture would one get repeating this process a million times, and as n tends to infinity and r tends to some very small non-zero quantity?
I was told that: for n = 1, 2, 3, 4, or 6, it looks like a bunch of lines connected together at points in a regular way, like an infinite graph. For any other n, it just fills the whole plane.
But I still can't visualize it. This is a preliminary to an extension of non-flat surfaces (ie. repeat the process only this time on a riemannian manifold)
Why not take a compass and paper and try it?
I did, but it becomes very hard to do as n gets large, especially in the limit as n tends to infinity
If you half the radius of the circle during each iteration, you'd get some kind of fractal on the boundary.
I don't see a pattern in anything other than n=2,4. Put the center of the circle at the origin. If you take the example n=5, the x and y coordinates of four of the points contain pi. I don't see anything other than noise coming out.
So I wrote a program , it definitely does seem to pack for n = 1,2,3,4,6
#include <stdio.h>
#include <SDL/SDL.h>
//#include <SDL/SDL_draw.h>
#include <math.h>
#define WIDTH 4000
#define HEIGHT 2000
#define BPP 4
#define DEPTH 32
#define ORIGINX WIDTH/2
#define ORIGINY HEIGHT/2
#define NUMPOINTS 5
#define RADIUS 45
#define PI 3.1415926
#define SEARCHDEPTH 11
void setpixel(SDL_Surface *screen, int x, int y, Uint8 r, Uint8 g, Uint8 b)
Uint32 *pixmem32;
Uint32 colour;
colour = SDL_MapRGB( screen->format, r, g, b );
int ytimesw = y*screen->pitch/BPP;
pixmem32 = (Uint32*) screen->pixels + ytimesw + x;
*pixmem32 = colour;
void drawcircle(SDL_Surface *screen, int centerx, int centery, int iter)
int deltax;
int deltay;
double dangle = 2*PI/NUMPOINTS; // starts at pi/3
double angle;
for(angle = 0; angle < 2*PI ; angle+=dangle)
if (iter>=SEARCHDEPTH) {
return 0;
} deltax = (int) RADIUS*cos(angle);
deltay = (int) RADIUS*sin(angle);
setpixel(screen, centerx+deltax, centery+deltay, 255, 255, 255);
// Draw_Circle(screen, centerx+deltax, centery+deltay, RADIUS, 255);
/*DEBUG
printf ("cos of angle %f\n", cos(angle));
printf ("angle: %f\n", angle);
printf ("deltax: %d\n", deltax);
printf ("deltay: %d\n", deltay);
printf ("iteration: %d\n", iter);
//updates the screen only 1/5th of the time
if (iter==SEARCHDEPTH/2){
SDL_Flip(screen);
iter++;
drawcircle(screen, centerx+deltax, centery+deltay, iter);
iter--;
void DrawScreen(SDL_Surface* screen, int h)
if(SDL_MUSTLOCK(screen))
if(SDL_LockSurface(screen) < 0) return;
drawcircle(screen, ORIGINX, ORIGINY, 0);
if(SDL_MUSTLOCK(screen)) SDL_UnlockSurface(screen);
}int main(int argc, char* argv[])
SDL_Surface *screen;
SDL_Event event;
int keypress = 0;
int h=0;
if( SDL_Init( SDL_INIT_EVERYTHING ) == -1)
return 1;
screen = SDL_SetVideoMode(WIDTH, HEIGHT, DEPTH, SDL_SWSURFACE);
if (screen == NULL )
return 1;
SDL_WM_SetCaption( "Drawing the 'circles' ... ", NULL );
//DrawScreen(screen,h++);
while(!keypress)
while(SDL_PollEvent(&event))
switch (event.type)
case SDL_QUIT:
keypress = 1;
break;
case SDL_KEYDOWN:
keypress = 1;
break;
SDL_Quit();
return 0;
here's what it looks like for 3 iterations, the intensity scale is from dark red (very few points) to yellow (medium # of points) to white ( a lot of points). note that right now, the algorithm is quite terrible. Unfortunately it grows exponentially (ie. n^i n = number of points, i = iterations) so 50 points per circle, 5 iterations, 312 million points. I haven't found any smart ways to break the exponentiality yet.
