What's the shortest length here?
9 replies · 3K views · last reply
Asad Raza
Question: An ant starts at one vertex of a solid cube with side of unity length. Calculate
the distance of the shortest route the ant can take to the furthest vertex
from the starting point.
Now, in the answer, the cuboid is unfolded and a rectangle of side 1 and 2 is formed. Calculating the hyptoneuse gives the distance.
That was the proposed solution. I wanted to calculate it via sqrt(1+1+1). Why is my answer wrong?
H^2=P^2+B^2
Sqrt( 1^2+1^2+1^2)
H^2=P^2+B^2
Sqrt( 1^2+1^2+1^2)
Yes, the shortest distance between the furthest vertices is along the body diagonal (the red line in the picture) but can the ant move along it?
Wireframe cube drawn in black with a red line running from the top-left back vertex diagonally through the interior to the bottom-right front vertex, marking a body diagonal.
Asad Raza said:
Then it should be 1+sqrt2
And the answer is sqrt5
Why? It is not the shortest distance.
Follow the hint in the solution, unfold the cube. The shortest way between the red points is the straight line segment connecting them.
Net of a cube unfolded into a cross shape, with a faint wireframe cube drawn over its left side; two red dots mark points on the net joined by a straight red line.
But how can an ant travel along the diagonal you've made?
The ant can climb on a sheet of paper, either it is folded or unfolded.
Diagram of a cube drawn in perspective with a red straight line running across its front face and a pink line on the adjacent face, with a grey curved arc drawn over the top right corner.
Cut the pattern in Post #5 and fold it to make a cube.
Got it. But without unfolding it, how'd you get the intuition, or prove rationally, that it is shortest path?
Unfolded, it is the same sheet of paper, as the cube was made of. On the plane sheet, the shortest path between two points is the straight line connecting them. So unfold the cube, connect the two points with a straight line, fold back making the cube, and you see the shortest path on the surface of the cube.
This method is very easy and can be used for other shapes which can be unfolded into a plane pattern.
But you can do it mathematically. The path should cross an edge, see figure. Write up the length of the path as the sum s1+s2, in terms of x. Find the minimum.
Wireframe cube with two red dots at opposite corners of its bottom and top faces, joined by two pink-shaded triangles meeting at a red point x on a vertical edge, with segments labelled s1 and s2.
Sometimes problems are difficult to solve one way, but quite easy if looked at in another way. This is one of those problems: the "unfolding" method makes it straightforward.
The alternative would be to not unfold the cube, but to express the distance in terms of some relevant variable or variables, then perform a minimization, using calculus, for example.
