When does a(x+t)² + b(x+t) + c = α(ax² + bx + c)?
  • Thread starter Ted123
6 replies · 3K views · last reply
Ted123
For which values of [itex]a,b,c\in\mathbb{C}[/itex] is the following equation true? [tex]a(x+t)^2 + b(x+t) + c = \alpha(ax^2 + bx + c)[/tex] where [itex]\alpha[/itex] is some scalar.
How do I go about this?
I don't understand the question. What roles do x and t play here? Is the equation to be true for all x and t? Some x and t? ...
[itex]x[/itex] is a variable and [itex]t\in\mathbb{R}[/itex] and [itex]\alpha[/itex] is a fixed constant. We want the equation to be true for all [itex]t[/itex].
If you equate coefficients you get:
[itex]a=\alpha a[/itex]
[itex]2ta+b = \alpha b[/itex]
[itex]at^2 + bt + c = \alpha c[/itex]
For what values of a, b and c are these true?
You mean for all x, I assume. Is alpha real?
Try considering α=1, α≠1 separately. (That's alpha, not a.)
If [itex]\alpha =1[/itex] then [itex]a=0[/itex] and [itex]b=0[/itex]
If [itex]\alpha \neq 1[/itex] then the first equation implies [itex]a(1-\alpha) = 0[/itex] so [itex]a=0[/itex] since [itex]\alpha \neq 1[/itex].
Subbing [itex]a=0[/itex] into the second equation gives [itex]b=\alpha b[/itex] so [itex]b(1-\alpha)=0[/itex] so [itex]b=0[/itex] since [itex]\alpha \neq 1[/itex].
Subbing [itex]a=0, b=0[/itex] in the third equation gives [itex]c=0[/itex]
haruspex said:
Unless t = 0.
So, assuming [itex]t\neq 0[/itex] (for if [itex]t=0[/itex] the equation is trivially true), I can conclude that the equation will be true for [itex]\alpha =1[/itex] for all [itex]c\in\mathbb{C}, a=0, b=0[/itex] and when [itex]\alpha \neq 1[/itex] it will only be true for [itex]a,b,c=0[/itex]?
In other words, whatever the value of [itex]\alpha[/itex], the equation will be true for all [itex]c\in\mathbb{C}[/itex] with [itex]a,b=0[/itex] so the polynomial involved [itex]p(x) = ax^2 + bx + c[/itex] must be constant; i.e. [itex]p(x) = c[/itex].
