fascinated
- Messages
- 31
- Reaction score
- 4
HI all! Clearly a noob here. The title says it all. I can't seem to find anything. Thanks for any help, folks.
So, does that mean that Earth's atmosphere technically extends to the sun? Even beyond?Ibix said:
It doesn't. Gravitational influence is infinite ranged as far as we are aware. You can find a surface where the Earth's gravity becomes less than that of the Sun, for example, and define that as the edge of the Earth's influence, but it's fairly arbitrary.
Usually, space is defined more in terms of whether there's atmosphere. The Earth's atmosphere is pretty negligible above 20km, the defined upper edge of the atmosphere is higher - 50k to 100km up, I believe - see Wiki's article.
fascinated said:So, does that mean that Earth's atmosphere technically extends to the sun? Even beyond?
no it doesn't, don't mis-quote the article !fascinated said:"The moon flies through Earth's atmosphere,..."
Earth's atmosphere is about 300 miles (480 kilometres) thick, but most of it is within 10 miles (16 km) the surface.
Right, because where gravity stops is where our atmosphere ends by definition, no?davenn said:You asked about the Earth's gravity and you were given the correct answer
now you have suddenly switched to Earth's atmosphere
I read the article. It says "about." And google has no better answer that I could find, hence this thread, lol.davenn said:now you have suddenly switched to Earth's atmosphere
There isn't a defined line boundary of where the atmosphere stops, is slowly dies out at ~ 300 - 400km above the Earth's surface
Google will give better numbers
I didn't, please.davenn said:no it doesn't, don't mis-quote the article !
Again, it says "about" and I was looking for more. If we don't know, we don't know and that is fine. I am really trying to find out IF we know, if that makes more sense.davenn said:so that article answers your second Q ... dies out at ~ 480km
Right, but I don't care about that. I am interested at the exact point where our atmosphere ends (if this point is known).Delta2 said:Earth's gravity becomes only 1%
No. Gravity and atmosphere are unrelated - for example the Moon has gravity but no atmosphere.fascinated said:Right, because where gravity stops is where our atmosphere ends by definition, no?
The point is that there isn't really a sharp cutoff. It isn't a case of "we don't know", it's a case of "how do you define no atmosphere". There is never a point when you are in perfect vacuum, because there's gas even in interstellar space. That's not the atmosphere, but the exact height at which atmosphere stops and interplanetary medium starts is a matter of definition rather than absolute scientific fact. That's why you see different heights - different people use different definitions.fascinated said:Again, it says "about" and I was looking for more. If we don't know, we don't know and that is fine. I am really trying to find out IF we know, if that makes more sense.
I am looking for where the Earth's gravity can no longer affect the particles in our atmosphere or where Newton's 2nd law takes over and equilibrium occurs. I may be defining things incorrectly for which I apologize.Ibix said:"how do you define no atmosphere".
The moon has a thin atmosphere.Ibix said:No. Gravity and atmosphere are unrelated - for example the Moon has gravity but no atmosphere.
There is no such limit. I'm not sure why you aren't grasping what has been said about how gravity works. Can you state clearly your understanding of this issue for gravity, without considering the atmosphere?fascinated said:I am looking for where the Earth's gravity can no longer affect the particles in our atmosphere or where Newton's 2nd law takes over and equilibrium occurs. I may be defining things incorrectly for which I apologize.
If there is no limit, then that would make sense.russ_watters said:There is no such limit. I'm not sure why you aren't grasping what has been said about how gravity works.
Not really as it is gravity that allows us to have an atmosphere to breathe.russ_watters said:Can you state clearly your understanding of this issue for gravity, without considering the atmosphere?
russ_watters said:Also, I don't know how you think Newton's 2nd Law applies... or rather why don't think it applies in the atmosphere. Can you explain?
I know it could be, but appears there is nothing concrete.russ_watters said:It could be the article answers your question, though: 390,000 miles.
No, what I mean is, how gravity works for other things besides the atmosphere. For example, can you explain for example how gravity affects spacecraft a long distance from Earth? Once you make sure you have that correct, then you can apply that to the atmosphere.fascinated said:Not really as it is gravity that allows us to have an atmosphere to breathe.
That picture does not answer my question. [edit] Worse, it seems to lead in a wrong direction if you think it is relevant here...
The Earth's mass is curving spacetime and everything must follow that line?russ_watters said:No, what I mean is, how gravity works for other things besides the atmosphere.
This is part of what I am examining... or trying to.russ_watters said:For example, can you explain for example how gravity affects spacecraft a long distance from Earth?
THIS! Please explain.russ_watters said:That picture does not answer my question. [edit] Worse, it seems to lead in a wrong direction if you think it is relevant here...
Then explain! We can't tell you if the idea that you have in your head is right or wrong if you won't tell us what that idea is!fascinated said:This is part of what I am examining... or trying to.
You said that picture discusses Newton's 2nd Law. You need to tell me why. I can't explain what you haven't told me! You may as well post a picture of a cat and ask me to explain it.THIS! Please explain.
It follows the curvature of spacetime.russ_watters said:I'll make it very concise: A spacecraft is a million km from Earth and stationary with respect to Earth. It shuts off its engine. What happens?
energy has an absolute unfailing tendency to go from "more concentrated" to "less concentrated"russ_watters said:You said that picture discusses Newton's 2nd Law. You need to tell me why.
Keep this Newtonian and try again.fascinated said:It follows the curvature of spacetime.
That isn't Newton's 2nd Law. So which did you mean? And explain. Use your words.energy has an absolute unfailing tendency to go from "more concentrated" to "less concentrated"
https://www.ftexploring.com/energy/2nd_Law.html
Never mind, friend. I am looking at this from our current knowledge base. We have not believed in "mass attracting mass" for over a century. Heck, we never did, really.russ_watters said:Keep this Newtonian and try again.
If that teaching link is wrong, please explain why.russ_watters said:That isn't Newton's 2nd Law.
Evidently you haven't taken any physics in school yet. That's not how it works. Heck, that isn't how NASA works.fascinated said:Never mind, friend. I am looking at this from our current knowledge base.
The link is about the 2nd law of thermodynamics, not Newton's second law of motion.If that teaching link is wrong, please explain why.
Please explain then; this is important.russ_watters said:Evidently you haven't taken any physics in school yet. That's not how it works. Heck, that isn't how NASA works.
I know what the link is about and it is EXACTLY what you asked about.russ_watters said:The link is about the 2nd law of thermodynamics, not Newton's second law of motion.
Im starting to question whether you are really trying to learn anything here or not. You need to put more effort into this if you want help.
NASA uses Newton's Law of Gravity to navigate spacecraft and if it's good enough for them, it is good enough for this purpose.fascinated said:Please explain then; this is important.
So...you aren't relating this to Newton's second law?I know what the link is about and it is EXACTLY what you asked about.
I'm looking for something deeper... sorry., but thanks for the interest and help.russ_watters said:NASA uses Newton's Law of Gravity to navigate spacecraft and if it's good enough for them, it is good enough for this purpose.
Read the entire link. It teaches the 2nd law to teachers, lol.russ_watters said:So...you aren't relating this to Newton's second law?
fascinated said:The Earth's mass is curving spacetime and everything must follow that line?
from what you have written so far it appears that you may be trying to 'run before you can walk'. You may have read something about and beyond Newtonian Physics but that doesn't imply that you can use terms like "curving spacetime" in a valid way.fascinated said:I'm looking for something deeper.
This thread is closed due to your lack of effort. Please feel free to PM me with a sincere and significant attempt to learn and communicate and I will consider re-opening it. If you're interested in that sort of thing.fascinated said:I'm looking for something deeper... sorry., but thanks for the interest and help.Read the entire link. It teaches the 2nd law to teachers, lol.
