Where Does Object A Come to Rest Relative to Wagon B?
  • Thread starter Thread starter IIK*JII
    Momentum Relative
The problem involves the dynamics of two objects: object A, which slides on a table and then onto wagon B, which is also on the table. The scenario includes considerations of kinetic friction and conservation of momentum as A comes to rest relative to B. The goal is to determine the distance from the left side of B to the point where A comes to rest.
  • Participants discuss the application of energy conservation and momentum conservation principles in the context of the problem. There are questions regarding the choice of reference frames and the treatment of kinetic energy for both objects. Some participants express confusion over the calculations and the assumptions made about the final velocities of the objects.
The discussion is ongoing, with participants exploring different interpretations and approaches to the problem. Some have found agreement on certain aspects of the calculations, while others are questioning the methods used and the assumptions made regarding the frames of reference and mass considerations.
Participants are navigating through the complexities of the problem, including the effects of friction and the relative motion of the objects involved. There are indications of differing interpretations of the equations and the setup of the problem, reflecting the challenges inherent in the homework context.
IIK*JII
The attached figure below shows object A (mass,m), which is placed on a table, and wagon B (mass,M), which is in contact with the table. The top of the table and the top of the wagon are at the same height. A is made to slide on the table so that it transfers to the top of B with speed v0. At that instant, A begins sliding on the top of B, and B begins to move on the floor. Shortly afterwards, A comes to rest with respect to B, and A and B then travel with a constant speed. The coefficient of kinetic friction between A and the top of B is μ'. B moves smoothly on the floor. The size of A is negligible.
What is the distance from the left side of B to the point where A came to rest with respect to B?
Non-conservation energy due to friction between A and B;
ƩE2-ƩE1=Work ...(1)
Momentum conserve(non elastic collision)
ƩP1=ƩP2 ..(2)
SA/B=SA-SB ..(3)
I) When A slides on B surface, I find SA by using (1)
0-[itex]\frac{1}{2}[/itex]mav[itex]^{2}_{0}[/itex]=-μ'magSa
∴SA=[itex]\frac{v^{2}_{0}}{2gμ'}[/itex] ...(4)
II) A and B move together after collision
From (2), I got the velocity(v') after collision
v'=mv0/m+M
Using (1) again to find displacement of B (B moves by friction of A and B)
Thus, -[itex]\frac{1}{2}[/itex](m+M)([itex]\frac{mv^{2}_{0}}{m+M}[/itex])^2 = -μ'mgSB
∴SB=[itex]\frac{mv^{2}_{0}}{2μ'g(m+M)}[/itex]
and SA/B= SA-SB =[itex]\frac{Mv^{2}_{0}}{2μ'g(M+m)}[/itex]
Is it right?? Who can tell me that my procedure to solve this problem is correct??
help is appreciate :))
Thanks a lot
Can you explain why you set the final kinetic energy of block A equal to 0? Relative to the earth, block A never comes to rest. Seems to me that you need to stick to one frame of reference. So, if you say that the initial velocity of A is vo, then you are using the Earth frame of reference. If you stay in the Earth frame of reference, the final velocity of A will not be zero.
Also, I don't understand why you're lumping the masses together when finding the distance B moves. Shouldn't you just use the mass of B alone for M in [itex]\frac{1}{2}[/itex]Mv'2?
However, when I work the problem I get the same final answer as you do! So, maybe your method is ok. But I don't follow it.
TSny
I think I misunderstood with this problem because I think velocity of A = 0 relative to the Earth so I set final kinetic energy of A = 0. Because of this I understand that 2 masses (A and B) stick together too...
What's the equation did you set?
In the Earth frame block A has a final velocity of
v' = [itex]\frac{mvo}{m+M}[/itex]
So, it seems to me that in your first equation under "The attempt of a solution" your zero should be replaced by the kinetic energy of block A when it has its final velocity. Does that seem right to you?
When setting up the similar equation for block B, I think you should use just the mass M of block B rather than (m+M) when setting up the final kinetic energy of block B: [itex]\frac{1}{2}[/itex]Mv'2. Does that also seem right?
If I make these changes and work through the algebra, I get different answers than you did for Sa and Sb. But I get the same answer as you did for the difference: Sa - Sb! :bugeye: I find that kind of amazing.
In block B: Did you set equation of energy like this
[itex]\frac{1}{2}[/itex]M(v')2=μmgSB
v'=[itex]\frac{mv<sub>0</sub>}{m+M}[/itex]
∴SB=[itex]\frac{mMv^{2}_{0}}{2μg(m+M)^2}[/itex]
and from your mentioned in #2, I get SA=v[itex]^{2}_{0}[/itex](mM+M2)/2μg(m+M)2
but when I find SA/B I can't eliminate M2 term...
I get (2mM + M2) rather than (mM + M2) in the numerator of the expression for SA. I agree with your expression for SB.
now I get SA like you get :) This is from my wrong calculation
but when find SA/B, I can't manage the answer as you can :((
Oh! now I can do it!
Thank you :)
  • · Replies 27 ·
18K
  • · Replies 25 ·
