Which is larger: log_7(10) or log_11(13)
  • Topic:
  • Thread starter anemone
    Logarithms
6 replies · 3K views · last reply
anemone
MHB
POTW Director
Without using a calculator, prove which of the following is larger:
$$\log_7 10$$ or $$\log_{11} 13$$
[sp]Using logs to base 10, $\log_7 10 = \dfrac{\log10}{\log7}$ and $\log_{11}13 = \dfrac{\log13}{\log11}.$ If $$\log10\cdot \log11 > \log7\cdot \log13\qquad(*)$$ then it will follow that $\log_7 10 > \log_{11} 13$.
Since $\log10 = 1$ and $\log11>1$, the left side of (*) is greater than $1$. To see that the right side of (*) is less than $1$, notice that $7^7 = 823543 < 10^6$ and $13^7 = 62748517 < 10^8$. (In principle, you could get those results by repeated multiplication without using a calculator, though I admit that I cheated there.) Therefore $7\log7<6$ and $7\log13<8$, and so $$\log7\cdot \log13 <\frac67\cdot\frac87 = \frac{48}{49} < 1,$$ which shows that the inequality (*) holds.[/sp]
Third Grader, non-general Solution. :-)
[sp]I want this to be WAY easier.
10/7 = 1 + ~43% (no calculator required)
13/11 = 1 + ~18% (no calculator required)
It's going to take A LOT more work to get 43% out of 7 than is required to get 18% out of 11.
No doubt, other examples would be less clear to my third grade friend.[/sp]
My solution:
In much the same way as Chris, I got to the point where I needed to show:
$$1>\log(7)\log(13)=\log(10-3)\log(10+3)$$
Note: I am using the notation $$\log(x)=\log_{10}(x)$$.
Now, obviously:
$$\log(10-3)<1$$ and $$\log(10+3)>1$$
And given the fact that the rate of change of log functions varies inversely as their argument, we could choose to write:
$$\log(13)=1+x$$
$$\log(7)=1-(x+y)$$
where \(x,y>0\)
And so our inequality becomes:
$$1>(1-(x+y))(1+x)=1-(y+x^2+xy)$$
or:
$$0<y+x^2+xy$$
As \(x\) and \(y\) are both defined to be positive, the result follows.
Thanks to Opalg and MarkFL for participating and for the two insightful solutions!
Now, @tkhunny, I am afraid you have to walk me through your solution...
My solution:
First, we assume that $$\log_7 10>\log_{11} 13$$ is true. By changing the base-7 and base-11 logarithms to base-10 logarithms, we have
$$\begin{align*}\frac{\log_{10} 10}{\log_{10} 7}&>\frac{\log_{10} 13}{\log_{10} 11}\\ \frac{1}{\log_{10} 7}&>\frac{\log_{10} 13}{\log_{10} 11}\\ \log_{10} 11&>\log_{10} 7\log_{10} 13\,\,\,\,\,\,\text{(since }\log_{10} x>0\,\,\, \text{for all}\,\,x>1)\end{align*}$$
We can see that $$\log_{10} 11>1$$ as $$11>10$$. So, if we can prove $$1>\log_{10} 7\log_{10} 13$$, we are done.
Observe that by the AM-GM inequality, we have
$$\sqrt{\log_{10} 7\log_{10} 13}<\frac{\log_{10} 7+\log_{10} 13}{2}=\frac{\log_{10} (7(13))}{2}=\frac{\log_{10} 91}{2}<\frac{\log_{10} 100}{2}=1\\\implies 1>\log_{10} 7\log_{10} 13$$
The proof is then followed.
I just wondered if there were a range over which we could simply ignore the logarithms.
There appears to be such a range, but the non-calculator premise may be violated when making the less vague impression.
  • Line graph of four curves over x from 5 to 20: (x+3)/x in blue, log(x+3)/log(x) in black, (x+2)/x in red and log(x+2)/log(x) in yellow, all decreasing toward about 1.1 or below.
  • Line graph of two curves over x from 5 to 12, both decreasing gently: the blue curve for (x+3)/x divided by log(x+3)/log(x) runs from about 1.23 to 1.15, and the red curve for (x+2)/x divided by log(x+2)/log(x) runs from about 1.16 to 1.10. Legend formulas are shown at right.
we have $10 > 7 * 1.4$ and $13 < 11 * 1.4$
hence $log_7 \,10 > 1 + log_7 \,1.4$ and $log_{11} \,13 = 1 + log_{11} \,1.4$
so $log_7\,10 > 1 + log_7 \,1.4 > 1 + log_{11} \,1.4 > log_{11} \,13$ as $log_7 \,1.4 > log_{11} \,1.4$
hence $log_7\,10 > log_{11} \,13$
