Which of the 2 metals is the magnet
  • Thread starter Thread starter Despot
    Magnet Metals
This discussion centers on the interaction between magnets and magnetic metals, specifically addressing how orientation affects attraction. Participants agree that a magnet will always attract a magnetic metal, regardless of their relative positions. The conversation also explores practical applications, such as using a bar magnet to pick up metal objects and the concept of creating a temporary magnet through rubbing. The consensus is that understanding these principles is intuitive yet often overlooked.
  • Basic understanding of magnetism and magnetic fields
  • Familiarity with permanent magnets and magnetic metals
  • Knowledge of bar magnets and their orientation
  • Concept of temporary magnets and methods to create them
  • Research the properties of different types of magnets, including neodymium and ferrite
  • Explore the concept of magnetic fields and their visualization
  • Learn about the applications of magnets in everyday devices
  • Investigate methods for creating temporary magnets and their uses
Students of physics, educators teaching magnetism, hobbyists experimenting with magnets, and anyone interested in the practical applications of magnetic properties.
Despot
I have 2 pieces of metal in front of me. One is a magnetic metal and the other one is a magnet. I need to know which of the two pieces is the metal and which is the magnet. They look identical and I can't use anything else apart from the 2 metals.
none
No idea where to start
Consider different orientations and relative positions in which you might bring them together. What would you expect to observe?
They would attract each other. I'm thinking of balancing them both and make some sort of a makeshift compass but think that's a sketchy solution.
In the same way, regardless of their relative positions and orientations?
Yes I believe a magnet and a magnetic metal will always attract each other. Am I missing something here?
I think you are.
Suppose you wanted to pick up a metal object using a magnet. How would you orient the magnet towards the object?
I've thought of rubbing them together to create a temporary magnet but I don't see how that would tell me which one's the permanent.
haruspex said:
I think you are.
If it was for example a bar magnet I'd orient 1 end to the metal object I was trying to pick up.
haruspex said:
I think you are.
And I just got it, thank you!
Quite a nice example of knowing the answer intuitively, but not realising you do.
