Why acceleration is absolute in special relativity?
  • Level: Graduate
  • Thread starter Thread starter GregAshmore
    Acceleration Relative
335 replies · 54K views · last reply
harrylin said:
What to think? Can such a lack of understanding really exist, or is the biker just trying to talk his way out of it by stripping the term from its obviously intended contextual meaning?
So, in your opinion, what is the "gravitational field's" obviously intended contextual meaning? In my opinion, it is the Christoffel symbols, but you seem to have a different opinion that you are strangely secretive about.
harrylin said:
While I certainly agree with the second sentence, the first one is plain nonsense to me
Then you are being logically inconsistent. The second sentence implies the first.
harrylin said:
"In rest" has in this context the physical meaning that the laws of nature are valid wrt the object; its state of motion is null.
Well, this is probably the source of the confusion. You are using terms in non-standard ways. The term "at rest" simply means v=dx/dt=0, and the term "moving" simply means v=dx/dt≠0.
Since the laws of nature can be written in a coordinate independent form they are valid wrt any object, so according to your definition all objects are "in rest".
harrylin said:
For this it is sufficient that our traveler consents to be locked in a projectile that would be launched from Earth with a velocity sufficiently close to that of light but lower, which is physically possible, while arranging an encounter with, for example, a star that happens after one year of the traveler's life, and which sends him back to Earth with the same velocity.
Ah, I see that instead of changing the topology of spacetime, Langevin changes its curvature to allow the traveling twin to return without feeling any force. This scenario could not be set up in flat spacetime as he sets it up, because in flat spacetime there is no gravity, so an encounter with a star could not turn the traveling twin around while still having him feel no force.
DaleSpam said:
The phrase "appears to turn around" (emphasis added) seems to refer to coordinate acceleration, in which case it would not be true that all observers must agree on it. If you intended the statement to refer to proper acceleration then it is a little confusing.
I think that GregAshmore understands the distinction between coordinate and proper acceleration, so I think that the rest is just miscommunication about which "flavor" of acceleration is being discussed at anyone moment.
Correct. I meant coordinate acceleration.
ghwellsjr said:
So because my spacetime diagrams only show one frame instead of the two that are more commonly shown in a Minkowski diagram, that prevented you from grasping what I was presenting, correct? But now that you realize the difference, does post #23 make perfect sense to you? Could you use it with further explanation to get your son to understand what I was presenting there?
No, it was not that only one frame was shown. It was the description of the rocket as moving. The application of motion words to the rocket is a trigger. The objector is under the mistaken impression that if the rocket does not move, the traveling Earth twin will be younger on reunion. All talk about inertial vs. non-inertial is not exactly denied; it is just ineffective. He feels he is entitled to a review of the case in which the rocket is stationary; he wants to see how it works out. Any description of the rocket as moving triggers the rejection of the explanation and the repeat of the objection: I want to see the case in which the rocket is stationary.
It is difficult to avoid motion words. As you observed, I tried to use neutral descriptors, so that I did not give the reader any room to infer that one or the other object is "really" moving. And, as you also observed, I did not fully succeed. I will revise the text, because I think it is important, in this problem more than others, to avoid the "motion" trigger.
ghwellsjr said:
Are you talking about this one spacetime diagram?
No, I mean the ordinary spacetime diagram, the one showing the Earth's worldline as a single line segment, and the rocket's worldline as two line segments, forming a triangle.
The "aha" moment for me was the realization that this spacetime diagram shows both cases at once. The worldline of the Earth shows the Earth at rest in its inertial frame; that same worldline shows the Earth moving relative to the rocket's inertial frames. Similarly, the two worldlines of the rocket show the rocket in motion with respect to the Earth's inertial frame, and at rest in its two inertial frames.
So, when the objector says, "I want to see the case in which the rocket is at rest", the response can be, "We have that case already in front of us, in the spacetime diagram that we have been studying."
This will come as a surprise to the objector. He believes that the only way to show the rocket at rest is with one line segment.
Having gotten his attention, it can now be shown that the rocket is indeed at rest in its inertial frame during separation, just as the Earth is at rest in its inertial frame.
When the separation ends and approach begins, a choice must be made. One or the other object must change frames. It would be helpful, I think, to show provisionally the Earth changing frames, with the worldline drawn to the "northeast" to meet the rocket, which continues along its original line. This is where the inertial/non-inertial distinction becomes meaningful to the objector. It can be pointed out that Earth is (or would be) at rest in this new inertial frame, just as it was in the original inertial frame. But the Earth cannot change inertial frames, because it is inertial throughout--the Earth twin feels no unbalanced force.
The rocket does feel an unbalanced force; it is non-inertial. It can therefore change inertial frames. But it does not move in its frame, even during the period of "non-inertiality"; its coordinate is zero throughout.
Now the objector (this one, at least) has not only seen the case of the stationary rocket, he understands why the inertial/non-inertial distinction proves that the rocket twin must be younger, and the Earth twin cannot be younger.
ghwellsjr said:
Spacetime diagram with coordinate time in units on the vertical axis and coordinate distance in light-units on the horizontal axis, showing a red vertical worldline labeled A to D and a blue zigzag worldline labeled B and C, with a crosshatched grid of light rays between them.
If so, wouldn't it have been just as confusing to you if you had not previously figured out that it was not a conventional Minkowski diagram with two frames in it?
The drawing was confusing, but not because it has only one frame. (Arguably it has four, though without axes shown for two?) It is not clear why the Earth's worldline has three segments. Also, it is not obvious why the timing of received light signals is important to the argument. I don't doubt that these issues go away if your explanation is studied with due diligence. It's just that by the time I got that far (in the first reading), I was already overloaded with detail, and fighting the "motion trigger" reflex.
ghwellsjr said:
What are you calling a symmetrical diagram? A Minkowski diagram? And why would it be invalid? And why is it not needed? Now I'm confused.
Consider the valid triangular spacetime diagram: the Earth's single-segment worldline is drawn vertically; the rocket's bent worldline is on the right. The symmetrical diagram has the rocket's worldline drawn vertically, and the Earth's bent worldline on the left. That is the diagram the objector expects to see in the case that the rocket is stationary. It is invalid because the Earth in inertial. It is not needed because the valid diagram shows the case of the rocket at rest.
The term "appears" was in effect quoted from GregAshmore post stating "either object can be the one that appears to turn around". In essence I was objecting to the same thing you are here.
That's what I thought to, but still not sure why previous responses have not resolved the issue.
harrylin said:
For a last time, as we've been here twice before: everyone can always claim to be at rest in his own frame
Yes. That is the practical meaning of the principal of relativity. "I am at rest. At rest in this position, I will deduce from observation the laws of physics. Those laws will be of the same form as the laws developed by all other resting observers, no matter the type of their motion with respect to me." {Edit: I made a statement similar to this a week or so ago. I seem to remember it was corrected. I'll stand by the gist of it, even if it is not correct in every technical particular. I could look up Einstein's exact words for GR, but I don't think it necessary to make my point.}
harrylin said:
such a statement cannot be disproved.
Of course it can. Show that I have moved with respect to an absolute position marker, and you have disproved the claim. Show that the claim violates a law of physics, and you have disproved the claim. For example, the claim that the rocket is at rest requires some cause for the Earth's coordinate acceleration, its reversal of motion. If there is no cause, then the claim that the rocket is at rest is proven wrong. You yourself have argued against the claim that the rocket is at rest in its non-inertial frame on the grounds that a change of coordinates alone cannot cause the reversal of the earth.
harrylin said:
You could just as well state that you're in your own world. That's physically meaningless.
See above.
Why not? The change of coordinates causes coordinate acceleration and reverses the coordinate velocity of the earth. What is in the least bit objectionable about any of that?
GregAshmore said:
The drawing was confusing, ... It is not clear why the Earth's worldline has three segments. Also, it is not obvious why the timing of received light signals is important to the argument.
Those are both answered here:
http://arxiv.org/abs/gr-qc/0104077
The importance of the timing of the signals is described on page 3 in the section "Radar Time and Radar Distance". The three segments are explained on pages 7 and 8 in the section "Gravity Doesn't Matter".
I didn't actually make that argument. (Not in this thread, at least.) Nor do I wish to participate in the argument--it goes against the new rule of me not making statements that I can't verify by calculation.
GregAshmore said:
Yes. [everyone can always claim to be at rest in his own frame] is the practical meaning of the principal of relativity. "I am at rest.
No to your first sentence, yes to your next sentences; obviously this is a matter of careful formulation. One can always design a reference system relative to which one is in rest. That fact is generic (valid for all theories) and has nothing to do with the PoR. The PoR concerns laws of nature.
[..] the claim that the rocket is at rest requires some cause for the Earth's coordinate acceleration, its reversal of motion. If there is no cause, then the claim that the rocket is at rest is proven wrong. You yourself have argued against the claim that the rocket is at rest in its non-inertial frame on the grounds that a change of coordinates alone cannot cause the reversal of the earth.
The rocket is certainly "at rest in its non-inertial frame", but yes you seem to understand what Einstein meant with "in rest". :smile:
Minkowski spacetime diagram with coordinate time (units) on the vertical axis and coordinate distance (light-units) on the horizontal axis; a red vertical line labelled A to D is at distance 0, and a blue line labelled A to B slants left from the origin, with a grid of diagonal light-ray lines and tick marks numbered 0 to 25.
Ok, then are you talking about this spacetime diagram?
Minkowski spacetime diagram with coordinate time on the vertical axis and coordinate distance in light-units on the horizontal axis, showing a blue vertical worldline A-B labelled and a red worldline O-C-D with numbered light-signal markers 0 to 15 along diagonal blue lines.
I thought we agreed that my diagrams show only one frame with Earth as the blue line and the rocket as the red line. So now I need an "aha" moment in order to understand what follows:
It comes as a surprise to me.
Could you please draw the diagrams that you are describing? I'm totally confused.
I'm afraid I'm going to become the objector now. I just don't understand your reasoning. Please draw diagrams with annotations so that I can follow your line of reasoning.
My drawings have only one frame--didn't we agree on that? I thought the issue for you had nothing to do with my diagrams not being typical Minkowski diagrams with more than one frame depicted? I'm really confused.
It actually has five. I just didn't draw the vertical segments at the top and the bottom where the Earth and the rocket are "at rest at same position". But to understand why there are those three segments for the non-inertial diagram in which the rocket is at rest, read posts #92 and #93 of this thread.
The timing of those all-important light signals is how the rocket twin creates the spacetime diagram. That is explained in the link in the previous post.
If you don't doubt that these issues go away if you study my explanations, then why haven't you studied them?
If I saw that symmetrical spacetime diagram, I would not understand why you say it is invalid just because the Earth is inertial or why the valid diagram shows the case of the rocket at rest. I don't think a real objector would be persuaded by your arguments, at least I am not.
Einstein was a physicist, but you try to interpret his physical explanations mathematically. There is no secret about a field in physics being a zone of influence where a force is exerted by a physical cause; that's the meaning of "field" at the time that Einstein used the term, and he didn't modify its meaning.
[..] Well, this is probably the source of the confusion. You are using terms in non-standard ways. The term "at rest" simply means v=dx/dt=0, and the term "moving" simply means v=dx/dt≠0. Since the laws of nature can be written in a coordinate independent form they are valid wrt any object, so according to your definition all objects are "in rest".
I'll try one last time. Please explain how the Earth can be accelerated with effect back in time due to the firing of the rocket engines. Which law of nature permits that?
No, in 1911 there was no GR. SR assumes flat spacetime and handles gravitation classically. The mistake that you ascribe to Langevin is due to you projecting modern GR concepts on him teaching SR correctly in 1911.
The modern way of saying it is that physical effects cannot propagate faster than light, but that coordinate acceleration is not (purely) physical. Coordinates are a system of book-keeping for events, and whether an object has zero or nonzero coordinate acceleration is as much a fact about your coordinate system as it is about the object. The point of introducing the notion of "proper acceleration" is to tease apart what's physical about an object's motion from what's an artifact of your coordinate system.
But SR, together with classical (Newtonian) gravity is inconsistent, I believe.
Yes, of course. Einstein was an excellent theoretical physicist, so he spent a great deal of time and effort to put his physical explanations into a mathematical framework. So his physical explanations refer to mathematical terms in his physical theory.
The question to you, which you continue to avoid, is which specific mathematical term in Einstein's theory do you think is he talking about when he says "gravitational field"? I think he is talking about the Christoffel symbols. You disagree, so please be explicit.
I really enjoy the hypocrisy of your "I'll try one last time" statement. As though I have been evasive on this point at all. I answered in 109, 114, and most explicitly in 171. However, since I want to foster clear communication, I will repeat the answer again.
It is not the firing of the rocket engine which causes the (coordinate) acceleration of Earth, it is the choice of coordinates. If you used the same coordinates without a rocket then the Earth would (coordinate) accelerate just the same. If you used different coordinates with the rocket then the Earth would not (coordinate) accelerate the same. The (coordinate) acceleration of the Earth therefore depends on the choice of coordinates, and does not depend on the firing of the rocket engines.
Yes, agreed.
I don't know if it is inconsistent; for sure SR ignores effects from gravitation on time.
Coincidentally the effect of the star's gravitation on the traveler's aging should be quite small in the given example, perhaps less than the effect of Earth's gravitation on that of the stay-at-home. Commonly that is neglected in such examples.
DaleSpam said:
[..] The question to you, which you continue to avoid, is which specific mathematical term in Einstein's theory do you think is he talking about when he says "gravitational field"? I think he is talking about the Christoffel symbols. You disagree, so please be explicit.
I disagreed with your assumption that he was discussing mathematical symbols when he wrote "gravitational field"; regretfully all my attempts to clarify the misunderstanding were in vain. I won't try anymore.
I really enjoy the hypocrisy [SNIP]
Enough, that ends our discussions.
Coincidentally the effect of the star's gravitation on the traveler's aging is quite negligible in the given example, and probably less than the effect of Earth's gravitation on that of the stay-at-home. Commonly that is neglected in such examples.
It is inconsistent because it posits spacelike causal influence. This was recognized by 1906, possibly earlier. Newtonian gravity + galilean relativitity are consistent (whether conventionally expressed, or in a generally covariant formulation like Newton-Cartan). But Newtonian gravity + SR are fundamentally inconsistent.
Independent of the how much 'gravitational time dilation' contributes to a scenario, it is GR that provides the basis for speaking of looping inertial paths. Without GR, with gravity as a force, a flyby path is not inertial - it is accelerated. Further, GR explains that there can be multiple geodesics (inertial paths) between two points, with different clock time experienced (this is generally true of curved manifolds, never true of flat, topologically trivial, manifolds). GR math also implies that whatever the maximum clock time path between two events is, it will be a geodesic (while allowing other geodesic paths that are not maximal).
Langevin's paper must be taken in the historical context of 'before there was any consistent way to treat SR + gravity'.
PAllen said:
It is inconsistent because it posits spacelike causal influence. This was recognized by 1906, possibly earlier. Newtonian gravity + galilean relativitity are consistent (whether conventionally expressed, or in a generally covariant formulation like Newton-Cartan). But Newtonian gravity + SR are fundamentally inconsistent. [..]
You seem to refer to the fact that the speed of gravitation is neglected in classical mechanics. Yes indeed, SR imposes a maximum speed of c on gravitation, thanks for pointing that out. However, such considerations are irrelevant in the context of standard SR twin scenarios despite a stay-at-home on Earth. Such aspects are rather off-topic in this thread as well as in most examples of that kind.
With gravity as a force, a flyby path is not inertial - it is accelerated.
Yes, exactly.
I.e., incorrectly. As stevendaryl pointed out, SR is inconsistent with Newtonian gravity. I don't know whether Langevin knew this in 1911, but he should have, as Einstein had already pointed it out and was already working on how to construct a new theory of gravity that would be consistent with SR.
I wasn't trying to ascribe a "mistake" to him; I was simply pointing out that his scenario does not show that you can have multiple free-fall paths between the same pair of events in the absence of gravity. The bolded phrase is true regardless of whether you interpret "gravity" as a force or as the curvature of spacetime. Either way you have to bring in gravity to allow the traveling twin to return without feeling any force. I put the argument in modern terminology because that's what I'm used to, but you could rephrase it in 1911 terminology that would have made sense to Langevin; in fact I just did. :wink:
But the traveling twin following this path still feels no force; he is in free fall the whole time. Newtonian gravity knew enough to make that prediction. (That's actually part of the reason that Newtonian gravity is inconsistent with SR; the kinematics aren't right.)
No, it's much worse than that. Consider Langevin's twin paradox scenario in the inertial frame of the stay-at-home twin. The traveling twin follows a curved path in this frame, hence he is accelerated (in the sense of coordinate acceleration), yet he is inertial--he is in free fall the whole time, feeling no force. The kinematics of SR do not permit this possibility; in an inertial frame in SR, coordinate acceleration *must* correspond to proper acceleration, i.e., to feeling a force. This is true even if nobody had yet realized it in 1911 (which they had--at least, Einstein had).
If he is discussing his theory of gravity, general relativity, then the things he discusses must have some correspondence to elements of the theory and hence can be identified with one or more of the mathematical symbols of GR. If he is not discussing his theory of gravity then his discussion is irrelevant to this thread.
Personally, I think that he is discussing his theory of gravity, GR, when he talks about "gravitational fields". When I look at the comments that he makes about "gravitational fields" the only element of his theory that seems to match are the Christoffel symbols. It is therefore my opinion that Einstein refers to the Christoffel symbols when he uses the term "gravitational field". An opinion to which you have not been able to provide a viable alternative.
It is a fact that the Christoffel symbols depend on the choice coordinate system (not on rockets) and also that they do not generate a wave equation. Therefore it is not surprising to me that there is a lack of literature about rockets producing gravitational waves or causing gravitational fields.
That is certainly your perogative. I am willing to continue the discussion, should you change your mind.
PeterDonis said:
I.e., incorrectly. As stevendaryl pointed out, SR is inconsistent with Newtonian gravity. I don't know whether Langevin knew this in 1911, but he should have, as Einstein had already pointed it out and was already working on how to construct a new theory of gravity that would be consistent with SR. [..]
Right, and nevertheless irrelevant here; see my comments to PAllen.
PeterDonis said:
[..] Consider Langevin's twin paradox scenario in the inertial frame of the stay-at-home twin. The traveling twin follows a curved path in this frame, hence he is accelerated (in the sense of coordinate acceleration), yet he is inertial--he is in free fall the whole time, feeling no force.
That's a continued mix-up of modern GR jargon and concepts with SR. That the traveler feels no force is irrelevant for Langevin's SR calculation; he will come back younger than the stay-at-home on Earth.
PS. I'm afraid that such discussions deviate from the topic; I'll wait for GregAshmore's comments on that, if any.
One further comment on this. The problem is still that, in GR, there are several quantities which could warrant the name "gravitational field", even by this definition of "field". So the term still needs clarification, and thus it is reasonable to ask for such clarification in any discussion of "gravitational fields" in GR.
Yes, this is a good point.
I think there are at least two views on what is the manifestation of presence of gravitational field. For some people it is the acceleration of test bodies - this probably lead Einstein to his principle of equivalence. The field, as force, is then relative coordinate dependent concept and can be locally transformed away. Thus in the frame of our rocket, there would be non-zero gravitational field.
There are also people who prefer to say that field is present only when curvature is non-zero; in this view, in the rocket there is no gravitational field, since the acceleration is uniform and curvature zero...
Jano L. said:
I think there are at least two views on what is the manifestation of presence of gravitational field. For some people it is the acceleration of test bodies ... There are also people who prefer to say that field is present only when curvature is non-zero
Exactly. My personal preference, and I believe Einstein's preference, is the first view (Christoffel symbols). But it is only a mild preference and I am content with either approach, as long as people are clear about which one they are using.
