Why acceleration is absolute in special relativity?
335 replies · 54K views · last reply
harrylin said:
That the traveler feels no force is irrelevant for Langevin's SR calculation
What "SR calculation"? The "calculation" that the traveling twin is younger implicitly uses flat spacetime (and don't say flat spacetime wasn't known in 1911; Minkowski published his spacetime formulation of SR in 1907). But in flat spacetime, the traveling twin can't swing around the star without feeling a force. The fact that Langevin hand-waved this by supposing that the star's "gravity" somehow changes that does not make his "calculation" correct; it just means it was a hand-waving error that he was able to get away with in 1911. There is no consistent way to formulate a theory of "gravity" in flat spacetime that makes Langevin's hand-waving calculation valid; the correct version of his calculation uses GR, i.e., it uses curved spacetime.
harrylin said:
such discussions deviate from the topic
Not really; they bear on the question of what the physical asymmetry is between the twins. You were the one who originally claimed that Langevin's version is a counterexample to the claim that proper acceleration--feeling a force--is the asymmetry. I am simply pointing out that this claim only works in the presence of gravity, and the standard formulation of the twin paradox assumes that gravity is negligible. If we allow gravity to be present, the whole thing becomes much more complicated because there are so many more possible scenarios; Langevin's is actually one of the simplest ones involving gravity.
Sorry that doesn't make any sense to me; free-fall has been well known since Newton.
The fact that Langevin hand-waved this by supposing that the star's "gravity" somehow changes that does not make his "calculation" correct; it just means it was a hand-waving error that he was able to get away with in 1911. [..]
He assumed the correctness of SR and gave a straightforward application without handwaving. It would however be interesting if you demonstrate that the error in his calculation (according to GR) was considerably more than in usual SR examples in which the effect of Earth's gravitation on clock rate is neglected; that will certainly warrant starting a new thread.
ADDENDUM: as an afterthought, such an attempt would probably be doomed from the outset, as in the example the turnaround time was intended to be negligible compared to those of the inertial phases, so as to allow easy calculation. That's the standard assumption, also with Einstein's rocket.
Jano L. said:
There are also people who prefer to say that field is present only when curvature is non-zero; in this view, in the rocket there is no gravitational field, since the acceleration is uniform and curvature zero...
The problem is that there is already a notion of "gravitational field" used in nonrelativistic physics. With many nonrelativistic notions, there is a corresponding relativistic notion that approximately coincides with the nonrelativistic notion in limiting cases. Spacetime curvature does not reduce the Newtonian notion of "gravitational field" in any kind of limit.
What does happen in the limit is this:
Connection coefficients in GR → Newtonian gravitational field + fictitious forces
There is no good way (as far as I know) in GR to tease apart exactly the quantities that become the Newtonian gravitational field in the nonrelativistic limit, except in special cases such as spherical symmetry.
He assumed the correctness of SR and gave a straightforward application without handwaving. I invite you to demonstrate that the error in his calculation (according to GR) was considerably more than in usual SR examples in which the effect of Earth's gravitation on clock rate is neglected; that will certainly warrant starting a new thread.
I have to say that the point of your example is a good one. What I think the point was, in the context of this thread, anyway, that it is possible to have a twin paradox type situation in which neither twin "feels" any acceleration. That of course is true in General Relativity, but Langevin's example shows that it's not necessary to use General Relativity to get an approximate answer to the question: What happens in a twin paradox situation where neither twin feels any acceleration?
In the Langevin example, we can break the "traveling" twin's path into three legs:
  1. Far from the distant star, traveling toward it.
  2. Traveling near the distant star.
  3. Far from the distant star, traveling away from it.
Einstein, even before he developed GR, claimed that legs (1) and (3) can be approximately handled using SR alone. The "stay-at-home" twin, in contrast, is always far from any big masses, and so SR is always adequate for computing his age.
But we can't compute the aging of the traveling twin during leg (2). However, what we can do is to simply let it be an unknown quantity [itex]\delta \tau[/itex]. Then for the entire trip, the stay-at-home twin ages by an amount
[itex]\tau_{sah}[/itex]
the traveling twin ages by an amount
[itex]\tau_{trav} = \tau_1 + \delta \tau + \tau_2[/itex]
We can compute the ratio [itex]\dfrac{\tau_{sah}}{\tau_{trav}}[/itex] in the limit as the distance to the star gets very large. (Assuming, which seems pretty sensible, that [itex]\delta \tau[/itex], the aging during the time orbiting the star, is a constant, independent of how long the twin traveled getting to the star.)
A mathematically true statement in SR (flat spacetime, trivial topology - e.g. no cylindrical topology), for two world lines between to events to show differential aging, one or both must incur proper acceleration. This is an invariant quantity in SR, the same in all frames or generalized coordinates. Where things get dicey is whether an accelerometer measures proper acceleration. If you allow some ad hoc mixture of SR + gravity, you have the feature that there is proper acceleration not detectible by an accelerometer.
GR changes definitions so that proper acceleration is always corresponds to what is measured by an accelerometer; and inertial paths = free fall paths.
Of course independent of any theory, it was known since Newton that our universe allows multiple free fall paths between a pair of events (e.g. crossing orbits).
No, his calculations were methodologically just wrong, though he didn't know it. That his specific example lead to small errors doesn't hide the fact he had no idea there was potential for his treatment to be way off.
Consider how he would have handled the following simple example all in our solar system:
a) A rocket firing thrusters so as to maintain a stationary position relative to the sun without falling or orbiting.
b) a circular orbital craft meetng (a) once per orbit
c) a bullet probe launched by the rocket radially outwards at an event of (a) and (b) meeting, such that it returns for the next (a) and (b) meeting.
Langeven's methods would say (a) ages the most. In fact, (c) ages the most, despite its having high speed for a good part of its trip. The fact that SR only calculation works for (a) and (b) is because these paths are all at the some potential - so gravitational time dilation does not apply at all. For a flyby around a a star, gravitational time dilation would not cancel, and a pure SR calculation is clearly an error, that Langevin was completely unaware of. That the error could be reduced by making the inertial parts of the journey long is irrelevant to the error of method. Alternatively, you could say that Langevin had no idea to even inquire about the error and argue that it could be made small - he had no concept of the parameters to make such an argument.
I disagree; you are doing the same hand-waving that Langevin did. Your calculation does give a way of getting an approximate answer to the question of relative aging (since the traveling twin's time elapsed during leg (2) becomes negligible in the limit as the distance to the star gets very large). But it's not an approximate answer to the question I put in bold above, because it doesn't account for why the traveling twin doesn't feel any acceleration during leg (2). There is *no* way to consistently account for that using SR (i.e., flat spacetime) with a Newtonian "gravity" force tacked on; there is no such consistent theory. (Langevin may have thought there could be in 1911; I'm not sure. If he did, he was wrong.)
PeterDonis said:
[..] the traveling twin's time elapsed during leg (2) becomes negligible in the limit as the distance to the star gets very large [..]
Yes, that's the standard assumption for such "twin paradox" examples: the turnaround is assumed to be sufficiently fast so that the turnaround phase may be neglected for the calculation.
Actually, no. SR, for a non-gravitational turnaround makes an exact prediction. It also makes an exact prediction for a twin that is undergoing uniform acceleration the whole time. These predictions are correct, so far as is known (e.g. from accelerator experiments).
Obviously. At any given time in the history of physics, there are some phenomena that we believe we understand, and there are phenomena that are yet to be explained. In order for a theory of physics to have predictive value, we have to make assumptions about the magnitudes of the effects due to phenomena we don't understand. Such assumptions always have the possibility for error, but how can you do any better than that.
SR was developed for use in describing situations where gravity was negligible. It would have no relevance to the real world if there were no situations in which we could neglect the effects of gravity. But without a theory of gravity, how can you know whether gravity can be neglected in any particular situation? You don't.
It's not supposed to account for it. We know, for empirical reasons, that a person in free fall doesn't feel acceleration.
That's done just to simplify the example. It's not a fundamental assumption of the explanation.
With instantaneous turnarounds, the proper distance along each leg is just algebra: [itex]\sqrt{\Delta t^2-\Delta x^2}[/itex]. If we don't assume instantaneous turnarounds, we have to evaluate some sort of line integral. It's fairly easy to prove that in the limit as the turnaround time approaches zero, the line integral reduces to the simple algebraic calculation, so we use the latter when the details of the turnaround aren't important to the problem at hand.
But today, we *do* understand GR. Remember how this sub-thread got started: with the claim that Langevin's example shows that you can have different elapsed proper times between events along different worldlines, without one of the worldlines having to be accelerated. This can only happen in the presence of gravity; Langevin obviously knew that since he knew he had to use a star, a large gravitating mass, as the "turnaround mechanism".
But Langevin appeared to think his example showed something useful about flat spacetime; he appeared to think that gravity could be added to SR without changing anything fundamental about spacetime itself. Today we know that can't be done. If the original claim had been phrased something like "Langevin gave an example of the traveling twin going around a star to turn around, which doesn't require him to feel any acceleration; but today we understand that that example requires curved spacetime for a full explanation", I would not have raised the objection I did. But it wasn't.
By measuring its effects. We know that in our everyday lives we don't have to take account of gravitational time dilation when we take an airplane flight. We don't need a theory of gravity to tell us that; we know it from our own observations--that our elapsed wristwatch time matches elapsed ground time between takeoff and landing (adjusted for time zone change if necessary). Similarly, in the Langevin example, the traveling twin could measure his elapsed proper time while slingshotting around the star and verify that it was very small compared to his elapsed proper time on the outbound and inbound legs. He doesn't need a theory of gravity to do that.
Then it's not an answer to the question it claimed to be an answer to.
It seemed to me that Langevin's example was just being used to illustrate that SR could be used (approximately, anyway) in cases where neither twin "feels" any acceleration. If Langevin was using his example for a different purpose, that doesn't change anything.
Only in a very limited subset of such cases: where the portion of the traveling twin's trajectory that is affected by gravity is very small compared to the total trajectory. And even then you need spacetime curvature in the neighborhood of the gravitating body to consistently explain *why* the traveling twin feels no force there. You can't just say "it's approximately SR" because there is no consistent theory of "SR plus Newtonian gravity" for the actual calculation to be an approximation to.
ghwellsjr said:
Could you please draw the diagrams that you are describing? I'm totally confused...
I'm afraid I'm going to become the objector now. I just don't understand your reasoning. Please draw diagrams with annotations so that I can follow your line of reasoning...
If you don't doubt that these issues go away if you study my explanations, then why haven't you studied them?
If I saw that symmetrical spacetime diagram, I would not understand why you say it is invalid just because the Earth is inertial or why the valid diagram shows the case of the rocket at rest. I don't think a real objector would be persuaded by your arguments, at least I am not.
I will address the concerns you raise in regard to my analysis of the twin paradox. It will have to wait until the weekend. I will need some time to do a proper job of it; it may not be finished until some time next week.
As to why I have not studied your diagrams, it is my intention to do that, as well read the material that DaleSpam has recommended. It hasn't happened yet due to time constraints. My evenings have been consumed with thinking about the comments directed to me and putting together what I believe to be accurate responses.
The standard "twin" paradox" examples are like Langevin1911 and Einstein1918 with a stay-at-home on Earth, neglecting effects form its gravitation, and assuming negligibly fast turn-around. That is done on purpose, as it's not a sophisticated calculation exercise but an illustration to explain how SR works.
Nugatory said:
That's done just to simplify the example. It's not a fundamental assumption of the explanation. [..]we use the latter when the details of the turnaround aren't important to the problem at hand
The "twin" example was meant to illustrate the effect of changing direction (acceleration) according to SR. Indeed, the details of the turnaround aren't relevant for that illustration.
The details are relevant when gravity is used for the turnaround since doing so puts the scenario outside the domain of applicability of SR.
For me and most people a theory is applicable if the estimated error is acceptably small; stevendaryl gave a good elaboration in post #214.
Let's stop the nitpicking: GregAshmore will already find it difficult to find back the for him interesting posts in this thread!
I agree, but the error in the accelerometer reading becomes arbitrarily large as the error in the clock reading becomes arbitrarily small. Both readings are important to the resolution of the scenario.
?? Ideal instrument readings have no error and the scenario doesn't make use of an accelerometer in the capsule, nor does it need it. Please present your issues as a topic in a new thread.
No, the theory (SR) makes errors predicting what ideal instruments would read in the gravitational-turnaround scenario. The accelerometer is the usual method used to identify the asymmetry between the traveling twin and the homebound twin in SR. That error (SR predicted accelerometer) is unbounded as the other error (SR predicted clock) is minimized when using SR as an approximate theory to analyze a gravitational turn around scenario.
I had the idea that that was the intention behind Langevin's thought experiment.
The calculation is an ad hoc amalgam of SR and gravity theory. That's true of most (all?) cases in which someone uses a theory to predict what happens in the real world. There will be aspects of the real world that aren't covered by the theory (or whose calculation from first principles is intractible). In those cases, it's actually quite common to split the problem up into subproblems, some of which can be handled using one theory, and some of which require a different (possibly purely phenomenological) theory.
I'm not sure what you mean by saying that the error is unbounded.
Look, if you took seriously the sorts of objections that are being made to Langevin's calculation, then SR would have been a theory without any empirical content in 1905. It wouldn't make any predictions at all, since it is only valid when the effects of gravity are negligible, and without a theory of gravity, you can't say whether the effects of gravity are negligible. So SR couldn't be used to calculate anything in the real world.
Similarly, in 1915 GR could not be used to calculate any real-world effects, because GR ignores quantum mechanics, and until you have a quantum theory of gravity, you can't precisely say under what circumstances quantum effects are negligible.
And quantum mechanics in 1925 would have no testable consequences, since it neglected relativity, and without a relativistic theory of quantum mechanics, you can't say precisely what the error is from ignoring relativity.
And so forth. No theory would have any testable consequences unless it's the ultimate theory of everything, because without such a theory of everything, you could never say under what circumstances a partial theory was applicable.
The way that this Gordian knot is cut is by trying to develop rules of thumb for the circumstances in which a theory is applicable, and ways to estimate the size of errors due to phenomena not covered by the theory. So any "pure" theory, if it is to have any empirical content at all, must be accompanied by a more-or-less ad hoc theory of the domain of applicability and the order of magnitude of errors. People can call this supplementary theory "hand waving", but it's absolutely critical in empirical science. Without it, science doesn't apply to the real world, at all.
Yes, an inconsistent and therefore invalid one.
Yes, but there's a difference between using a provisional treatment of a subproblem that is later validated by a deeper theory, and using a provisional treatment of a subproblem that turns out to be inconsistent and invalid once we have the deeper theory. Langevin's treatment is case of the latter, not the former.
I was thinking about this comment. You are correct, that there is no way to tease them apart in GR. I think that is essentially the content of the equivalence principle. The Newtonian gravitational field is equivalent to a fictitious force per GR, and so they are subsumed into a single quantity in GR.
As you make your [itex]\delta \tau[/itex] small the SR predicted accelerometer reading becomes large while the actual accelerometer reading remains 0.
Einstein and others had to make assumptions about which situations they believed gravity was important and which they believed gravity was not important. Often they were wrong, as Einstein in his 1905 paper with the example of the clock at the pole and equator and Langevin with his gravitational twin paradox. Luckily scientists were able to find a large number of experiments where gravity is negligible in order to empirically verify SR and establish its domain of applicability.
I think you are getting things backwards here. The experiments are what determine the domain of applicability, not later theories. You don't need another theory to tell you that your current theory is/is not applicable, all you need is measurements that agree/disagree with your theory.
OK. According to the Ad-Hoc Domain Of Applicability Theory for SR (AHDOAT-SR), Langevin's example is outside the DOA. The fact that AHDOAT-SR was insufficiently developed for Langevin or Einstein to know is certainly a good reason for us to excuse them for their understandable mistake, but it is certainly not a good reason to repeat the mistake ourselves.
I agree with that; it seemed to me that other people were saying that Langevin's derivation required some kind of theoretical justification. I was pointing that that didn't make any sense, because you would need a theory of everything before you could ever apply any theory.
I don't think it is. Look, we have plenty of experience with clocks circling a gravitating star, because all of our clocks do that. To the extent that SR has any relevance in our solar system, it has to be the effects of the sun's gravity can be bounded. Before GR, people used SR to explain the Michelson-Morley experiment, which certainly took place in a gravitational field. If the presence of a gravitational field makes SR inapplicable, then it was never applicable.
An experiment like Langevin's was never done, and still hasn't been done, so actually neither he nor us really knows the result of such experiment.
I pointed out that earthbound experiments and specifically comparison of orbit versus hovering at an approximately constant distance from sun, and approximately constant distance from Earth's center really are immune to substantial gravitational time dilation effects. The theoretical justification (nearly constant gravitational potential) need not be known to observe this fact.
A stellar flyby is not so immune. I do think the idea of bounding this, and swamping it with very long 'near inertial' travel is valid. However, the flyby, taken by itself, is actually very substantially affected by gravitational time dilation, because you have rapid change of potential. For highly elliptical orbits, gravitational time dilation swamps SR kinematic effects.
Of course it is. SR predicts a very large accelerometer reading during the turnaround, and real free falling accelerometers read 0.
Not every measurement in every scenario is sensitive to gravity. This one is.
I am not making a claim that SR is inapplicable in every scenario where there is any gravity present. It is inapplicable in the twin paradox, for the reasons I stated above.
I was not trying to say Langevin's derivation required extra justification at the time he made it; he was basically making a bet that a theory of gravity of the sort he was thinking of would be consistently possible.
I was only saying that that does not allow us, today, knowing that the kind of theory of gravity he was thinking of is *not* consistently possible, to say that his version of the twin paradox, with the traveling twin not feeling acceleration, can be explained "just by using SR". He thought it could, but today we know it can't.
This is a different case. The MM experiment can be analyzed entirely in a single inertial frame that covers the entire experiment. Langevin's twin paradox scenario cannot. So knowing that Langevin's scenario can't be analyzed just using SR, in the light of today's knowledge, does not imply that the MM experiment can't be analyzed just using SR, in the light of today's knowledge.
DaleSpam said:
[]SR predicts a very large accelerometer reading during the turnaround, and real free falling accelerometers read 0.
I am "getting" very little of the discussion concerning the relationship between SR, Langevin's scenario, and GR. That's not surprising, as I understand only the most basic principles of SR (and for all I know that understanding may need fine tuning), have only a vague conception of GR as a theory in which space and time curve to produce relative motion of massive objects without applied force in the presence of a gravitational field--and absolutely no knowledge of Langevin's ideas.
But this much I believe to be undeniably true of a purely SR treatment of a scenario in which two bodies, one inertial and the other non-inertial, separate from each other and then approach to reunion: the non-inertial body must experience unbalanced force at the transition from separation to approach. There is no other way for the period of separation to end. Therefore I agree with DaleSpam's statement in [my] bold, above.
I think I understand the point that even if one posits that the non-inertial twin reverses direction by "swinging around" a star, there must still be an unbalanced force--a non-zero reading on an accelerometer. The unbalanced force is due to the change of gravitational potential during the flyby. However, at this time I am unable to verify my understanding by calculation, so I have no actual opinion in the matter.
I'm about ready to sign off this thread, as the question in the OP has been answered to the extent possible with my current knowledge. My response to George's concerns will be in a new thread, as it pertains specifically to the explanation of the twin paradox, rather than to the more general question of the relativity of acceleration.
What have I learned?
1. Coordinate acceleration is relative; proper acceleration is not.
2. Proper acceleration may be experienced while at rest in a coordinate system. (This follows from 1.)
3. Loosely speaking, the experience of proper acceleration corresponds to the experience of an unbalanced force. I think this is in agreement with the definition of proper acceleration as the phenomenon that occurs when there is a non-zero reading on an accelerometer. However, I personally am not a fan of a definition of a fundamental physical phenomenon that requires the use of a mechanism. It seems to me that this leads to getting bogged down in the details of the design of the mechanism. I'd rather talk about the underlying phenomenon that the mechanism is intended to measure. In engineering, we are constantly aware of the difference between theory (the ideal) and practice (the inability to make actual conditions to correspond to the ideal). Defining proper acceleration as the reading on an instrument blurs that distinction, in my opinion.
4. Formally, proper acceleration is the derivative of proper velocity with respect to proper time. I have no idea how proper acceleration can ever be non-zero, because I cannot understand how proper velocity can ever be non-zero, if one defines proper time as the interval between two events at the same location. However, at this point in my education I am content to let this alone (for now).
5. From 3, only non-inertial bodies experience proper acceleration.
6. In the twin paradox, only the rocket twin is non-inertial. Therefore, the Earth twin must have a straight world line in a spacetime diagram, and the rocket twin must have a bent worldline. By spacetime diagram I mean a diagram that charts the coordinate (Lorentz) transformation between inertial frames. I believe this is the same thing as saying Minkowski diagram. The design of the diagram does not allow a non-inertial body to be represented by a straight worldline, nor does it allow an inertial body to be represented by a bent worldline.
7. Also from 5, and illustrated in 6, the rocket twin must experience less elapsed proper time than the Earth twin; there is no treatment of the episode in SR that can result in the Earth twin being younger than the rocket twin.
8. From all the foregoing (with special emphasis on 2), the "absoluteness" of proper acceleration does not contradict the claim of the rocket twin to be at rest throughout the episode. Therefore, the statement that proper acceleration is absolute does not have any "shocking" implications with respect to the general principle of relativity.
9. The case of the rocket twin at rest is treated in the Minkowski diagram. The typical explanation of the twin paradox does not draw attention to this fact, leaving some good-faith objectors unsatisfied with the conclusion that the Earth twin cannot be younger than the rocket twin. Further elaboration on this point will be given in the new thread that I intend to open; this will also be my response to George's concerns.
10. The discussion above is limited to the kinematics of SR. The essentially dynamic state of being non-inertial is recognized in the solution of the problem, but it is not analyzed with respect to the laws of dynamics.
11. [edited for clarity] In my mind, 10 leads to a question. In the intuitive understanding of the universe, the Earth is absolutely at rest. The Earth, as it were, is anchored in place. The impression one gets from popular books on relativity is that the intuitive understanding of the universe may legitimately be claimed by any observer: Every observer may consider himself to be anchored in place.
What are the implications of the rocket twin being anchored in place? Simply this: How is it that a force applied to the rocket causes the Earth and all the stars to move? Einstein's proposal is that a gravitational field is the cause. Granting that point for the sake of discussion, one must still ask how the rocket produces enough energy to accelerate the immense mass of the Earth and stars at the observed rate.
[Side note: This objection was alluded to by harrylin at one point in this discussion. I believe it is at the root of his claim that few physicists these days accept the idea that the rocket is "really in rest". I find it interesting in this regard (without drawing any conclusions) that DaleSpam says that most physicists these days tend to leave the question of the gravitational field in SR alone.]
Please understand that I am making no claim regarding the validity of the principle of relativity. I am merely stating the question that I wish to be able to answer, and wish (eventually) to be able to verify by calculation.
