Why are eigenvectors scaled by eigenvalues in matrix multiplication?
Ush
Hello
This is a concept question I do not understand. I'm just wondering why the answer is what it is. (the answer is written below the question, I just have no idea where it comes from)
Handwritten answers to two eigenvalue questions about a real 3x3 non-invertible matrix A: (a) answered No, because complex roots come in conjugate pairs, so 1 + i requires 1 - i; (b) answered No, because A is not invertible so it has eigenvalue 0.
  • Handwritten answers to two eigenvalue questions about a 3x3 real matrix A that is not invertible. Part a asks if eigenvalues 0, 1, and 1+i are possible; answer: No, because the complex conjugate 1-i must also be an eigenvalue. Part b asks about eigenvalues 3, 3, and 5; answer: No, since A is not invertible it has eigenvalue 0.
For a, you have to know that complex eigenvalues come in conjugate pairs. That is, if a + bi is an eigenvalue of a matrix A, then so is a - bi. The same goes for eigenvectors. If an eigenvector has entries (a, b + ci) then there is another eigenvector with entries (a, b - ci).
For b, you have to know a couple of things.
A square matrix A is invertible if and only if its column vectors are linearly independent. This is equivalent to saying that a square matrix A is invertible if and only if there are no nontrivial solutions to the equation Ax = 0 (this is because Ax is a linear combination of the column vectors of A).
So then a matrix that is not invertible must have nontrivial solutions to Ax = 0. But in this case, you have found an eigenvector of A with eigenvalue 0. That means every matrix that is not invertible must have eigenvectors corresponding to eigenvalue 0.
Another way to think about it, is that when you are looking for eigenvalues and solving |A - λI| = 0, you are looking for the values of λ that will make A - λI not invertible. But if A is not invertible, then clearly λ = 0 is a solution.
Hope this helps.
