Why are Physicists so informal with mathematics?
209 replies · 30K views · last reply
TurtleKrampus said:
every physicist in my university's math department
At your university, why are physicists in the math department?
TurtleKrampus said:
I really just want to be presented with a clear model, which probably exists, for the topics I'm being exposed to.
Physics has a lot of tradition and parallel layers of history still alive and often the absolutely necessary is used/displayed only (no sledgehammer for flies does apply).
You might need to opt for some advanced topics to get what you seek here. When advanced math becomes necessary it's customary to explain the less advanced parts again in the new context.
... though likely you'll still get math-by-phisics at higher level too, so better be preparedo0)
In some countries theoretical physics is part of applied mathematics and in the math departments.
brain fart, meant professors in the physics department.
@TurtleKrampus There's a branch of physics called mathematical physics whose purpose is to formulate theories of physics by fully respecting the rigors of various branches of mathematics. It's not at all compulsory, or should I say it's not very common that universities have staff doing research and teaching in mathematical physics. Therefore, for lectures delivered to students, most of the staff use the "standard semi-rigor" of physics textbooks.
For example, none of the exposé here https://en.wikipedia.org/wiki/Ehrenfest_theorem uses the methods of mathematical physics. The theorem of Ehrenfest was proven within the realm of mathematical physics only in 2009 by Friesecke and Schmidt. arXiv:1003.3372v1.
Returning to your dismay, there are, if you want to learn theories of physics properly using mathematics, you can very well do so by opting to books instead of lecturers. For example, classical mechanics is neatly covered either by Abraham & Marsden or by V. Arnol'd, I don't think there's anything sketchy or less rigorous in their books.
There is a Millenium Prize for the Navier–Stokes existence and smoothness problem. Should all computational fluid dynamics stop until this problem is solved?
The complaint was about lack of rigour, not about the existence open problems. Otherwise he would be complaining about mathematics too.
I believe @DrClaude 's point is that CFD is a cheap/ugly shortcut to avoid dealing with that unsolved problem. It's The Wrong Way To Do Things and maybe we should stop until someone figures out The Right Way.
I guarantee any stroke QM could give a mathematician, an engineer could make worse.
  • Haha
I must say I have some trouble understanding the difference between the two in this case. If you can't prove existence and unicity, doesn't the use of the equation show a lack of rigor?In any case, physicists are only interested in whether it works or not (i.e., does it model nature), and leave the details to mathematicians (*cough* Dirac delta *cough*). While the work of mathematical physics is valuable, physics itself needs to satisfy itself with "it works" otherwise we would get nowhere, especially when learning the material.
No, why would it be lack of rigor? An unsolved problem can be rigorously and precisely formulated. (This is not important but the problem is about the long time behavior. Do smooth solutions exist for all ##t##, or do they develop some kind of singularity in finite time? Short time weak solutions are known to exist.)
This is a better example. Before distributions were introduced what Dirac did was not rigorous. An example of lack of rigor would be a physics text that uses Dirac-like "functions" with only a vague and intuitive explanation. (One of course, can argue that it may be better for the intended audience.)
My problem with the OP is that when he tries to present how things should be done, he is even less rigorous than any physics text or lecture.
Yeah, those books (and other similar material) will probably be how I end up studying physics this semester. Thanks
No? I don't see how this relates to what I wrote...
I think that the recommendation of the Abraham & Marsden book is shockingly bad advice. It's in no way suitable as an introduction to physics.
If you really can't accept physics as it is taught by physicists at your university, then you should find some way to drop the subject and stick to mathematics.
It's your decision, of course, but I think it's worth saying that you may be jeopardising your degree by a vain search for mathematical purity in physics.
I mean, all I want is to be presented with a model, which probably exists for the well known, well studied, topics that I will be studying in my physics class. I presented my ideas on a possible formulation of a model of Newtonian Mechanics, this isn't too say that the things I wrote have to work right off the bat, rather I believe that the overall ideas may possibly be expanded on.
Also I call bull on
Intuition only based arguments are not real arguments, they should either be acknowledged to be motivated assumptions, not used, or have some reference to it being true regardless of intuition. And I've heard several accounts of professors using Physical intuition only arguments to skip proving something in mathematics... Don't get me wrong though I don't have anything against saying something like "this turns out to be true AND agrees with what we believe should be morally right", even if a proof isn't presented.
Physics is mandatory here, so I unfortunately cannot drop out of it even if (very much so) wanted to, though thankfully it's only a semester.
I also don't believe that I'd be jeopardising my degree, I've skimmed the class notes / previous years exams, and the class seems to be one of the easiest ones this semester so hopefully I should be fine as long as I attend the classes.
Perhaps physics should learn from financial economics - the models there are mathematically rigorous and the discipline even has its own theorems. The failure of these models to either explain or predict real-world phenomena provides no impediment to plumbing their mathematical depths
  • Haha
This thread reminds me of the joke where the punchline is that mathematicians take a long time to come up with an answer that is 100% correct but still utterly useless. I think in most contexts, insisting on mathematical rigor to the degree the OP wants is a waste of time. It doesn't really add much, if anything, and detracts from the goal of teaching the physics.
Very interesting comment that is. Some situations make certain points important and other points unimportant. This seems to be the characterization going on in the topic. Different people have their own ways of trying to say the same thing.
You didn't have to discredit financial economists... What approach do you suggest they should use?
Making a model gives a very good way to describe the assumptions the author used to study something
Like the very slow converging analytical solution for the three-body problem?
TurtleKrampus said:
Given two inertial reference frames (both being isomorphic to ##\mathbb R^3##) ##R_1,R_2## there exists some ##A \in SO(3)## and ##v \in C^2(\mathbb R, \mathbb R^3)## with ##v'' = 0## such that the projection of the position of some point mass ##r## to ##R_2##, which I'll denote ##\pi_2(r)##, factors through ##R_1## from it's projection of its position in ##R_1##, which I'll denote ##\pi_1(r)##, in the following way:
$$\pi_2(r) = A\pi_1(r) + v$$
I believe that this enlarges into time being invariant across the reference frames, since our transformation is (in terms of ##\pi_1(r)##) time invariant.
There are some minor things that I wrote, for example we can consider the domain of the translation to be an interval, but I wrote it for the sake of simplicity. I don't know if it's possible for reference frames to rotate through time, but if so we just replace A with a continuous function onto SO(3). This is a first thought into how I'd go about writing things, there are probably many errors here..
I would expect that after spelling out this unwieldy thing, you would appreciate why physicists just write t=t'.
  • Haha
TurtleKrampus said:
Yes, t = t' makes no sense to me
But you said it means time is absolute. So you understood it. So how does it make no sense? I don't even think this is a math vs physics rigor thing. Have you never seen in pure maths x being the coordinates in one system, x' being the coordinates in another?
Because we are using approximate solutions and an approximate solution is not rigorous unless you know an actual solution exists, and you have some kind of an error estimate for your approximate solution.
That answers the question of whether or not we can find an analytical solution. It's not done to be useful for approximations
Preferences I suppose
Coming up with detailed mathematical models is a waste of time when your model is completely off base. In many social sciences, it is recognized that mathematical models have very limited applicability so they don't use them. Economists want to pretend they are somehow different. They are not, they study social constructions, and social constructions are primarily controlled by social forces which are not well described by such models. That's not to say they have no applicability whatsoever, but it feels like a lot of it is just a thinly veiled game. To put it another way, Alexander the Great didn't study knot theory, he simply cut the Gordian knot.
Physics is not quite the same, because there quantitative mathematical models are very applicable. However, the full weight of MODERN mathematical formalism would only weigh down most areas of physics. That's not to say there are not areas in which it is profitable to work that way, but for others it is just a burden, either because the formalism clouds the intuitive ideas, because the formalism is unnecessarily complicated or even non-existent as of yet, or because the model is already kinda "wrong", and rigorous conclusions from an unsound model are still unsound.
In my opinion physics does need greater unity with mathematics, which does mean some linguistic changes should happen in physics. But that doesn't mean going to the other extreme, and it also works both ways, ie mathematics should steer a bit closer to physics as well. After all, that is how it developed historically, and still does to a certain extent. The modern standards of "rigor" would never have happened of there weren't the older, far less rigorous "classical" mathematics, and those mathematics would never have developed had there not arisen many questions from physics, questions which in turn could never have developed had physics waited for the final link in the chain! This is not just a historical artifact, it still happens today. Rigorous mathematical foundations of QFT is something that is important and interesting and close to my heart, but it is still a work in process which still has many gaping holes. Physicists could never have waited to use it until it somehow developed fully formed, skipping a bunch of steps in between.
May be people need to say what they mean by rigorous first. Here is an example: you have an equation, someone proves a uniqueness theorem, but noone has proven existence yet. Do you think that the uniqueness theorem is not rigorous?
If you are complaining about physicists not doing rigorous math, what should I complain about, having to work everyday with biochemists? Its your job as a mathematician to bring physical ideas into Bourbaki style, not that of a physicist (they tend to fall immediately asleep with this task).
Just to point out that not all mathematicians think the same way.
https://www.math.fsu.edu/~wxm/Arnol...thematics that is,ministers) and of the users.
A model is just a way to formalize your ideas.
Creating a model allows you to call things theorems, based on the axioms (i.e. assumptions).
There is no loss in generality by creating a model, unless you assume the existence of some type of object / property which hasn't been made rigorous in the language of mathematics, but I assume, with things like stochastic calculus there won't be many things like this.
Ultimately the main limitation with a financial model will be on the influence of real time events, which are in general hard to predict (something like an Elon Musk tweet can influence, and has influenced before, Tesla's stock prices).
I get that for the development of physics creating a model with rapidly changing beliefs / assumptions is not a good thing. What I argue is that for topics in physics which have been explored really well, and that do in fact have faithful models, I argue that introducing one of those models can be a good thing, specially when the people you're exposing the material to study math.
Mathematics has become independent of Physics, topics that are closest to my heart, i.e. something like abstract algebra, Galois theory, representation theory, and to some extent category theory, wouldn't really gain anything by steering into Physics specifically (there are a things that can be motivated by Physics like studying the Heisenberg groups, but the theory itself doesn't really evolve by steering into Physics. In fact Physics isn't special in this aspect, a lot of branches of mathematics are influenced by other Sciences like game theory & Biology and PDEs & Chemistry).
The modern mathematician is probably less restricted to rigor than you might believe. Somewhat counterintuitively for new topics, you often look at a property some things satisfy and then write definitions based on constraints you needed to arrive at that, which ultimately become theorems. That is to say, the theorem in new areas often predates the definition. Or if you'd like, the definitions are motivated by the theorems, and often evolved over time.
When the theory becomes sufficiently well studied the first textbooks are written about it.
There are also experimental mathematical magazines, which expose patterns & possibly corresponding conjectures to "fit" those patterns.
