Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,571
Shackleford said:Okay, I busted out the textbook and perused the SR chapter a bit, particularly the muon experiment.
Does your textbook say anything about relativity of simultaneity?
kev said:In the Earth frame the muon takes about 30 ms to reach sea level. (Longer time interval)
In the muon frame the trip takes about 6 ms. (Shorter time interval)
Let's apply relativity of simultaneity here. Suppose there are two clocks at rest in the Earth's reference frame, one at the muon's starting point and one on the ground; and a clock that rides along with the muon (and a hypothetical observer who rides along with them). We set the clocks so that in the Earth's reference frame, all three read zero when the muon passes its starting point.
In the Earth's reference frame, the muon takes 30 ms to reach the ground, so both the clock at the starting point and the clock on the ground read 30 ms when the muon reaches the ground. Because of time dilation, the clock on the muon reads 6 ms when it passes the clock on the ground.
In the muon's reference frame, 6 ms elapse on its clock during the trip, of course. In this frame the other two clocks are time-dilated, so only about [STRIKE]0.17 ms[/STRIKE] 1.2 ms elapse on those clocks. (The time-dilation ratio is the same in both cases: 1/5 = 6/30 = [STRIKE]0.17/6[/STRIKE] 1.2/6).
In the muon's reference frame, the two "Earth frame clocks" are also not synchronized. At the start of the trip, the clock at the starting point reads 0, and the clock on the ground reads about [STRIKE]21.83 ms[/STRIKE] 20.8 ms. During the trip, [STRIKE]0.17 ms [/STRIKE] 1.2 ms elapse on both of these clocks. At the end of the trip, the clock at the starting point reads [STRIKE]0.17 ms[/STRIKE] 1.2 ms, and the clock on the ground reads 22 ms.
So both an "Earth observer" and the "muon observer" agree that when the trip starts, the clock at the starting point and the clock on the muon both read 0; and when the trip ends, the clock on the ground reads 22 ms and the clock on the muon reads 6 ms. However, they disagree about whether the clock at the starting point and the clock on the ground are synchronized.
