Alternatively, if you want a more concise title: What causes bubbles to merge?
  • Context: Undergrad
  • Thread starter Thread starter member 428835
    Bubbles
Bubbles coalesce primarily due to the principles of surface tension and pressure, as described by the Young-Laplace equation. This equation indicates that a bubble's pressure is inversely proportional to its radius, meaning larger bubbles have lower pressure and potential energy. When two smaller bubbles touch, a seam forms, and if a tiny hole develops, the pressure quickly equalizes, prompting the bubbles to merge into a single larger bubble. This merging minimizes the overall surface area, thereby reducing energy according to the laws of thermodynamics.
  • Understanding of the Young-Laplace equation
  • Basic knowledge of surface tension principles
  • Familiarity with concepts of pressure and potential energy
  • Awareness of thermodynamic principles related to energy minimization
  • Research the implications of the Young-Laplace equation in fluid dynamics
  • Explore the role of surface tension in various physical phenomena
  • Study the thermodynamic principles of energy minimization in systems
  • Investigate the behavior of bubbles in different fluid environments
Students and professionals in physics, fluid dynamics researchers, and anyone interested in the physical properties of bubbles and surface phenomena.
member 428835
Why do bubbles coalesce? I imagine it has to do with surface tension and pressure. The Young-Laplace equation states a bubbles pressure is inversely proportional to its radii. Higher pressure implies higher potential energy, so maybe bubbles coalesce to form a bigger bubble with bigger radii, and hence smaller pressure and less energy?
The surface tension tries to minimize the surface area. One big bubble has lower surface area than two smaller bubbles.
When two smaller bubbles touch, there's a seam between them. If a tiny hole develops in the seam, connecting the two bubbles, then you have a narrow choke between the two spheres. In the choke, the radius of curvature is very small, so it is very unstable. The Young-Laplace equation refers to a static situation, but gives the idea that the pressure is instantaneously not equal everywhere. Pressure will quickly equalize, which means the bubble needs to reshape itself into a sphere.
All the best (and most reliable) arguments are based on energy. "Good on yer!"
Since energy is proportional to surface area, this is why surface area is minimized, right?
19K
  • · Replies 0 ·
  • · Replies 264 ·
32K
  • · Replies 19 ·
