Why do distant objects appear to move more slowly?
  • Thread starter adjacent
10 replies · 3K views · last reply
adjacent
This is not really a homework question and I am not sure if this should be in the Maths forum or Physics forum.
See the title.
For example,a plane with the same length and speed is moving at constant speed near and far away from me.
From my experience I know that the far plane will appear to move more slowly.Why?
I have seen many people saying that as the distance from the eye increases,the distance the plane have to move across the field of view increases.That's why it is moving slowly.
This does not make much sense to me.
I don't have a proof based understanding of this.
One idea that came to my mind is that as the distance from the eye increases,as the plane goes from a point A to B(Eye is C),the angle ACB is less than the angle ACB it makes when it moves nearer to me.
So as the angle is less, the distance it moves on the image is less.
(I can't explain this so well but I hope you understand what I mean)
My explanation seems too childish.If it's right,can you make it make sense Mathematically?
Your idea already seems mathematical for me. Math doesn't always mean equations and operations. It is also logic. You have used (knowingly or unknowingly) the math that is needed. Still, this could be connected to mathematical equations as [itex]S=rΘ.[/itex]
:eek: What is [itex]S=rΘ[/itex]?
Actually it is the consequence of the definition of the plane angle, how we made it.
Any plane angle, Θ is defined as the ratio of the arc length of a circle which subtends the angle Θ, to the radius of the circle.
If S is the arc length, r the radius then
Θ=S/r
S=rΘ
Diagram of a circular arc: angle theta at the vertex between a horizontal radius r and a sloped line, with arc length s marked between the two lines.
Note that Θ is in radians.
Θ=S/r
S=rΘ
Geometry diagram of a sector-like arc: a horizontal line of length r from a vertex, a second ray at angle θ from the vertex, and a curved arc labelled s spanning between the two rays.
But if light is being refracted by the lens,why not use the refraction formula?
$$n_1\sin(i)=n_2\sin(r)$$
What's the use of S=rΘ here?
I'm not sure if I got you right.. by refraction formula, how do you prove that farther objects appear to move slowly?
No.Not the refraction formula,sorry.I'll use a ray diagram.
Ray diagram of a converging lens with object AB on the right and its inverted image A'B' on the left, with rays drawn from A and B through the lens and the principal axis dashed.
Then I will do a little trigonometry to prove it.
  • Ray diagram of a converging lens with object AB to the right, image A'B' inverted and to the left, and principal axis dashed horizontally.
Ray diagram of a converging lens with object AB on the right, shown as a green-tipped arrow at B and point A, and its inverted image A'B' on the left, with dashed principal axis and rays drawn through the lens.
So your object moves from A to B while the image moves from A' to B' and A'B' is smaller than AB hence it appears to move slowly, right?
If you do the trigonometry, you'll end up with something similar to S=rΘ only that the angle Θ will be inside a trig function.
No it's not like that.
Ray diagram of a converging lens with a vertical eye-lens line on the left, showing a nearer object AB (blue, labelled This AB is nearer) and a farther object AB (black), with their images A' and B' projected on the retina-side line.
The AB is closer than AB(Note the colour difference)
So as the plane move from A to B,the image moves from A' to B'.
When the plane move from A to B,the image move from A' to B' and the distance A'B' is greater than A'B'.So the far plane takes a longer time to move across the retina than the near plane.The rest is handled by the brain
  • Ray diagram of a converging lens with two object segments, a nearer AB shown in green and a farther AB in black, projecting inverted images A' and B' onto a vertical retina line.
I get it. This is nothing but the use of ##S=rθ## here. If you would look into the derivation for the magnification of a simple microscope (the lens here) you can observe that the angle subtended by the object at the eye, and at the lens is considered. Not getting into details, we can deduce that relation to meet our needs, and it clearly yields ##\tan θ = \frac{h}{D}## where ##h## is equivalent to ##S## and ##D## to ##r##. ##\tan θ## can be approximated to ##θ## for small angles. Fetching ##θ=\frac{S}{r}##
Since ##S## is constant, ##\theta## is inversely proportional to ##r##. Hence as distance, ##r## increases, ##\theta## decreases. It's 'angular velocity' decreases.
Thank you so much
PhysicoRaj.
I think I understand it now :smile:
