Why Do Hyperbolic Functions Require Complementary Functions Like Abs and Sgn?
  • Level: Undergrad
  • Thread starter Thread starter Jhenrique
    Roots
8 replies · 2K views
Jhenrique
By pythagorean identity, ##\sin(x)^2 + \cos(x)^2 = 1##, so ##\sin(x) = \sqrt{1 - \cos(x)^2}##; also, ##\sinh(x)^2 - \cosh(x)^2 = - 1##, therefore ##\sinh(x) = \sqrt{\cosh(x)^2 - 1}##.
Happens that the last equation is incorrect, here is a full list of the correct forms for the hyperbolics:
https://de.wikipedia.org/wiki/Hyperbelfunktion#Umrechnungstabelle and here is a full trigonometric list for comparation: https://es.wikipedia.org/wiki/Identidades_trigonométricas#Relaciones_b.C3.A1sicas.
So, why the 'normal' trigonometrics no needs of completary functions, like Abs and Sgn, and the hyperbolic trigonometrics needs in some case?
Mathematics news on Phys.org
From the Wiki that you linked ... immediately above the table that is apparently in question:
De estas dos identidades, se puede extrapolar la siguiente tabla. Sin embargo, nótese que estas ecuaciones de conversión pueden devolver el signo incorrecto (+ ó −).
No. You omitted the ##\pm##.
##\sin(x) = \pm \sqrt{1 - \cos(x)^2}##
Again, no, same problem as above.
##\sinh(x) = \pm \sqrt{\cosh(x)^2 - 1}##
Jhenrique;4708956 Happens that the last equation is incorrect said:
https://de.wikipedia.org/wiki/Hyperbelfunktion#Umrechnungstabelle[/url] and here is a full trigonometric list for comparation: https://es.wikipedia.org/wiki/Identidades_trigonométricas#Relaciones_b.C3.A1sicas.
Yeah, I like of omit +/- because, by definition, a root square have 2 roots...
No, that's not the definition. The square root of a positive real number has one value, not two.
It's true that real numbers have two square roots -- one positive and one negative -- but the expression ##\sqrt{x}## represents the principal square root of x, a positive real number that when multiplied by itself yields x.
If a square root represented two values, there would be no need to write ##\pm## in the quadratic formula:
$$x = \frac{-b \pm \sqrt{b^2 - 4ac}}{2a}$$
When you start with sin2(x) + cos2(x) = 1 and solve for sin(x), you need ##\pm## in there, otherwise you are getting only the positive value.
And if you have ##x=y^6## ? You'll write ##\pm\sqrt{\pm\sqrt{\pm\sqrt{x}}}## ? Not is better let that the ##\sqrt[n]{x}## represents the n roots?
On the reals there are only two roots: ##\sqrt[6]{x}## and ##-\sqrt[6]{x}##.
Jhenrique, you have reals and complex numbers mixed up.
If you take the square root of both sides of
[tex]y^6=x[/tex]
you get
[tex]y^3=\pm\sqrt{x}[/tex]
Let's make it simple.
##y^6 = 64##
##\Rightarrow y = \pm \sqrt[6]{64} = \pm 2##
As it turns out, there are four other sixth roots of 64, but they are all complex. The only real sixth roots of 64 are 2 and -2.
