Why do periodic lattices conduct better
  • Context: Graduate
  • Thread starter Thread starter Gobil
    Periodic
24 replies · 8K views
Gobil
Hi all,
In a periodic array of ions, e.g. a metal crystal, the conduction electrons are free to move around. I have read that distortions to the periodic array can cause a decrease in conductivity of the crystal. These can be crystal impurities, phonons etc. My question is, why should the conductivity change? For example, if we had a perfect gold crystal, and measure the conductivity, it should give a finite value (?). If we then melt this crystal and keep the density more or less the same, we will have less conductivity. This I don't get, the arrangement of the atoms is different, but on average the distance between them is more or less the same, so the average potentials in the two cases are equal, and the electron feels the same forces throughout the crystal. why then are the conductivities different?
it is, but from a quick read it does not really answer the physics of the question. It is calculating the structure factor (which I´m not entirely clear on) for various systems. I´m thinking in terms of a 1D string of ions, an electron that overcomes the potential between the ions is conducting. If these ions are not periodic, why should this make a difference to the average potential felt?
The conductivity (and resistivity) of metals is better described by considering the electrons as waves scattered by the lattice. It's not so much a matter of electrons interacting with individual ions but rather with the lattice as a whole.
in these terms, could it then be explained why the crytalline structure gives good conduction in metals? if the electrons are being scattered by a regular array, there will be interference effects, if the array is amorphous, like in a liquid metal, there will be no intereference effects. I still don´t understand how this should effect the conductivity...
It is a quantum mechanical effect, and I don't think it can be understood at the level of individual "classical" electrons.
However, the QM is reasonably straightforward (solving the SE for a periodic potential) and the result are so-called Bloch waves.
Have a look at the wiki
http://en.wikipedia.org/wiki/Bloch_wave
especially the bit about the Bloch wave vector is a conserved quantity. i.e. there is no scattering in an ideal periodic potential.
this is the part I have trouble with. what is scattering in the QM sense?
NO SCATTERING: when the the electron is translated from one area to another, but has the same momentum (wavevector) in both areas?
SCATTERING:when the the electron is translated from one area to another, and has a different energy?
I just don´t get why they scatter more in a disordered lattice.
No, you can have scattering without a change in energy (just as in classical physics), i.e. only the wavevector changes.
I think your problem is that you are thinking about the electron as a particle traveling among ions, but the point is that this does not work: in a periodic potential the wave-nature of the electron dominates.
but why does this wave nature change in a disordered system, where the spacing on average is the same as the average spacing in the crystal state. The electrons are still close, so all the QM effects still apply, but for some reason they are not as "free" to move around.
The wave nature is still there, but because you no longer have a periodic lattice (e.g. a impurity means that the potential suddenly changes) means that the waves get "distorted"; you no longer get plane waves solutions.
so if the solutions are no longer plane wave solutions, what does this mean for the conduction? In my head if we have some distorted wavefunction, it means the probability distribution will not be regular anymore. I.e. there will be places where it is more likely to find an electron, and places where it is less likely. Is this just the same as saying we now have some potentials which the electron can not overcome (or is less likely to overcome)?
You are right, it is not necessary to have plane wave solutions to get conductivity. It is sufficient that the expectation of the momentum operator does not vanish in the ground state which is also possible for wavefunctions in an aperiodic substance.
Electronic properties of aperiodic substances are very complex and many interesting phenomena like Anderson localization occur. In less dimensions than 3d, electrons and holes may scatter repeatedly and coherently from the same impurity and resistivity diverges with the sample size.
However, as far as I understand, no one has ever questioned that an aperiodic substance in 3d may be conductive.
But the temperature dependence is different. At least at low temperatures and sufficiently pure samples, resistivity is due to electron phonon umklapp scattering. In a crystal, the combined electronic and phonon crystal momentum changes by 2K where K is a wavevector of the reciprocal lattice. In a crystal, the difference of any two electronic states at the Fermi surface is different from 2K (if not, the crystal would show some Peierls instability), so that necessarily a phonon with finite k has to be absorbed. At sufficiently low temperatures, these phonons are absent and resisitivity goes to 0. In an aperiodic crystal, Umklapp scattering may take place for any k value so that electron phonon-scattering leads to a finite value of resistivity also at low temperatures.
so in the Unmklapp process there is actually a momentum exchange between the phonon and electron. This happens when the lattice does not exhibit perfect periodicity, because in going from A to B in the lattice, the electron no longer has the same energy. If it has less energy at the end, it has scattered and given some energy to the lattice. Is this correct?
Yes, in electron phonon scattering, the perfect symmetry of the lattice is broken due to the phonon which is equivalent to a lattice deformation. More important than the change of energy is the change of momentum. Namely if the electron has momentum k before and k' after scattering and the phonon the momentum q, then k+q-k'=K, where K is some reciprocal lattice vector.
In a crystal, k,k' and K and hence also q are of the order of the Fermi momentum as k-k' cannot be too near to K as this would induce an instability of the lattice. However E(q), the energy of the phonon, is then finite and the Boltzmann factor for the presence of a phonon would be very small at low temperatures. That's how resistance increases at very low temperatures and clean crystalline samples. At higher temperatures, you can assume that there are many phonons with a Maxwell Boltzmann distribution which is not considerably disturbed by the current. Hence the electrons scatter simply from the random distortions of the phonons which act at the same time as a heat bath and take up the energy.
ok it´s much clearer now thanks.
So if we consider a cold ~0K solid with some crystal defects, there will also be scattering due to the distortions to the wavefunctions from the aperiodic potential. and hence we have some resistance. right?
Exactly right. This is called the residual resistance. The purity of copper required for high conductivity applications is often specified in terms of its residual resistance ratio (RRR), which is the resistance at room temp (300K) over the residual resistance at low temperature.
EDIT: It's not just impurities, but also the quality of the crystal that counts. Even pure material can have imperfections (dislocations between atomic planes, skew dislocations, etc.) that cause scattering. This is why annealing a copper wire will reduce its resistance.
can I ask now, about AC and DC resistance.
If we have a perfect, infinite metallic crystal, and flow electrons through it, they travel with no resistance, theoretically, right?
Now if we shine some (lets say red) light on it, it is reflected due to the electrons repelling the light. Now if we keep increasing that frequency what happens? eventually it becomes larger than the plasma frequency of the electrons and can propagate through the metal.
but in reality it is not perfectly transmissive. if we have say, 50 eV photons and shine them on a piece of aluminium, some will be absorbed.
My question is; is the reason for limited DC conductivity in a perfect crystal the same as the reason for limited AC conductivity in a perfect crystal? i.e. is it due to the fact that crystal is not infact perfect?
thanks!
Even a perfect crystal will have finite conductivity due to electron electron and electron phonon Umklapp scattering.
For AC at near the plasma frequency, an important mechanism for resistance are interband transitions.
It can't be right at all!
We consider quite common topic: friction!
For electron gas in solids it is named as resistivity.
For helium 3 and 4 it is named as viscosity.
And what do we see?
Even for IMPERFECT solids and for more IMPERFECT liquids there is SUPERCONDUCTIVITY and SUPERFLUIDITY.
There is NO microscopic theory of superfluid helium and of high temperature superconductivity. Some physicists suppose that also BCS theory can't explain some evident EXPERIMENTAL facts (for example Chapnik Kikoin rule, that most of elemental superconductor have pozitive Hall coefficient
So the question: what is it friction ( resistivity/viscosity), does not have clear MICROSCOPIC answer till now.
And what do we see?
really? there is no microscopic theory of superconductivity at high temperatures?
Aside from that, I just wanted a kind of idea of the mechanism for light absorption in metals. Particularly at wavelengths above the plasma frequency, I guess there are inter band transitions going on in the conduction bad right? but is the absotpion happening because the light is shaking the electron and the electron is colliding with an imperfection or a phonon, or another electron?
are all these processes happening?
What about at 0K?
thanks!
thanks!
Well, I would say that this is quite a particular oppinion of Minich whose paper on that topic we all are awaiting eagerly. Also note that he refers more to superconductivity and superfluidity than to resistance in ordinary metals at higher temperatures.
For current state of microscopic theory of superconductivity at high temperatures i can advice the exellent review of Uchida
Forefront in the Elucidation of the Mechanism of High-Temperature Superconductivity
Shin-ichi Uchida
Department of Physics, University of Tokyo, Bunkyo, Tokyo 113-0033, Japan
Received August 4, 2011; accepted September 8, 2011; published online December 7, 2011
It is only 5 pages.
Can be downloaded from
http://jjap.jsap.jp/journal/JJAP-51-1R.html
OR with free YELLOW comments from Minich can be download from
http://frolih.narod.ru/
I don't think that Uchida knows particular opinion of Minich. I think Uchida doesn't know that any "minich" exists :)
The first sentence from abstract:
Uchida said:
The mechanism underlying the high-temperature (Tc) superconductivity of copper oxides has remained unelucidated and is one of the most difficult challenges of physics remaining in the 21st century.
So it is not my particular opinion that there is no microscopic theory of superconductivity at high temperatures :)
I will express my particular opinion in another post.
Yes, I agree that on HTSC we have no theory (or far too many). The sentence I really wante to object was the following:
"So the question: what is it friction ( resistivity/viscosity), does not have clear MICROSCOPIC answer till now."
I would say that we have a good understanding of how resistivity arises in most substances. although there are always substances where special mechanisms are at work that are not well understood.
What about at 0K?
thanks!
Let us see a solid at 0K. There is a ground state of a solid. When photon strikes a solid there are many channels to get solid in another (usually excited) state. So do photon's final states and electron(s) final states knocked out from the solid. The final state of the solid is not usually the stationary state of the solid and this state has probabilistic time evolution. Usually the solid is in contacts with many external sources of material world (other solids, electromagnetic fields and so on).
Such contacts as a rule are considered to obey probability rules. It means we name
such behavior as dissipation. For solids usually we have thermalisation processes.
If a solid has impurities the time evolution of the excited solid (as a whole) differs from that of excited solid without imputities.
At 0K we have no phonons.
There are too many possibilities.
Yes, You are quite right!
P.S.
As for Uchida review
Forefront in the Elucidation of the Mechanism of High-Temperature Superconductivity - Shin-ichi Uchida - COMPREHENSIVE REVIEW
I found, that Uchida has genius intuition.
He expressed one of the method to increase Tc with the help of pseudogap!
I am going to show how it can be achieved in my paper :)
Pseudogap insulator we can force to superconduct combining with overdoped superconductors at T near to pseudogap T* transition.
You can see the paragraph on page 4 near his reference to number 17:
17) S. Ideta, K. Takashima, M. Hashimoto, T. Yoshida, A. Fujimori, H. Anzai,
T. Fujita, Y. Nakashima, A. Ino, M. Arita, H. Namatame, M. Taniguchi, K.
Ono, M. Kubota, D. H. Lu, Z.-X. Shen, K. M. Kojima, and S. Uchida:
Phys. Rev. Lett. 104 (2010) 227001.
