Why do the Horizontal components cancel in E-Field
The discussion focuses on understanding why the horizontal components of the electric field cancel out in the presence of two charged planes with uniform charge densities. The user attempts to derive the mathematical proof by examining a single plate and integrating the contributions of small charge elements. They find that the y and z components integrate to zero due to symmetry, leaving only the x component to evaluate. The user successfully derives the final electric field equation, concluding that the electric field intensity in the region X<0 is zero. This exploration emphasizes the importance of grasping the underlying mathematics for better problem-solving in electrostatics.
iceman_ch
Plane X=0 has a uniform charge density, \rhos while plane X=a has -\rhos. Determine the electric field intensity in region X<0.
E=\frac{Q}{4\Pi\epsilon<sub>0</sub>R<sup>2</sup>}aR
I already know the answer to this question. What I'm trying to do is figure out a small part of the math behind it. Let's start by looking at one plate instead of two. How can I prove mathematically that all of the horizontal components cancel out leaving behind the component pointing away from the plate. I understand why but I need to understand the math behind it. This makes working problems so much easy when I can understand the math behind it easily. So here goes what I tried to do.
First I need to define a point to examine my e-field at. r=(x,y,z) next i need to define the different parts of the equation above. Best way to do this is to look at very very small peices and then adding them up.
dE = \frac{dQ}{4\Pi\epsilon<sub>0</sub>R<sup>2</sup>}
dQ = \rhosdS
dS = dY dZ
R = ?
I want to put that R=r-r' and that r' would the location of the very very small plate which would be (0,y',z') which would make R=(x,(y-y'),(z-z')) The y and z would stay constant because they are the point that we are evaluating E at. This is were I get lost. I know technically that y and z can be ignored because they will add to zero but, how can I prove this. If I keep going with my attempt the next step would be to find the magnitude of R and the unit vectors of R. I'm going to leave these out for now since they are long to type. So now I would put everything together and integrate. This is where everything gets messy. I know that if I put in a value for y say 4 and then integrate (4-y') from 0 to 8 the answer is 0. How can I write this out when even though y is constant because I don't know what it is I can't really prove that it ends up being 0.
I worked on the problem a little bit more and I believe that I've worked out the correct solution. First when you write everything out it takes up a lot of paper and it is somewhat complicated. So the first thing is to go ahead and integrate the y and z components since they are the horizontal components that should go away by the end of the solution. If you do this they do indeed go to zero. I'll write out the y component so that it's easier to understand what I'm writing.
ay=\frac{\rho<sub>s</sub>}{r\Pi\epsilon<sub>0</sub>}\int\int\frac{(y-y&#039;)}{(x<sup>2</sup>+(y-y&#039;)<sup>2</sup>+(z-z&#039;)<sup>2</sup>)<sup>\frac{3}{2}</sup>}}
This ends up equaling zero because the integral from infinity to negative infinity of (y') is 0. So this leaves the X component as the only one that has to be deal with. The X component is
ax=\frac{\rho<sub>s</sub>}{r\Pi\epsilon<sub>0</sub>}\int\int\frac{(x)}{(x<sup>2</sup>+(y-y&#039;)<sup>2</sup>+(z-z&#039;)<sup>2</sup>)<sup>\frac{3}{2}</sup>}}
First thing to do to evaluate this integral is to realize that X is constant and can be relabeled H to be a little less confusing. The next thing if you draw everything out you realize that converting to polar coordinates would be a whole heck of a lot easier. This changes the equation to look like
ax=\frac{\rho<sub>s</sub>H}{r\Pi\epsilon<sub>0</sub>}\int\int\frac{(1)}{(H<sup>2</sup>+\rho<sup>2</sup>)<sup>\frac{3}{2}</sup>}}\rho d\rho d\Phi
The limits of integration would be 0 to infinity and 0 to 2pi.
Integrating this will leave
\frac{2\pi}{H}
Which makes the final equation of
\frac{\rho<sub>s</sub>}{2\epsilon<sub>0</sub>}
Then going back to the original problem and noticing that H isn't involved in the final equation means that the e-field in the region X<0 is equal to 0. My textbook does point the final equation out but, I don't like using these equation without understanding how they were derived. Hopefully I did all of the work correctly.
  • · Replies 45 ·
