Why do we use Radian measurement for Time?
  • Context: Undergrad
  • Thread starter Thread starter physicsdreams
    Measurement Time
Radians are essential for accurately representing angular measurements in trigonometric functions, particularly when modeling periodic phenomena like the rotation of a ferris wheel. The discussion emphasizes that radians are dimensionless units that simplify calculations for arc length and area, making them preferable over degrees. When using time as a variable, it is crucial to multiply by angular frequency (ω in radians per second) to ensure the sine function receives a pure radian value. Ultimately, while degrees can be converted to radians, using radians directly avoids complications in formulas and calculations.
  • Understanding of trigonometric functions and their properties
  • Familiarity with angular frequency (ω) in radians per second
  • Knowledge of unit conversion between degrees and radians
  • Basic concepts of periodic functions and their graphs
  • Learn about angular frequency and its applications in trigonometric functions
  • Study the relationship between radians and degrees, including conversion techniques
  • Explore the small angle approximation for sine in radian measure
  • Investigate the implications of using radians versus degrees in physics and engineering problems
Students, educators, and professionals in mathematics, physics, and engineering who require a solid understanding of angular measurements and their applications in trigonometric functions.
physicsdreams
I had a problem where we had to write out the sinusoidal function for the rotation of a ferris wheel. My teacher said that because the rotation was a function of time (x-axis was time), we had to use radians and not degrees.
Could someone explain to me if/why you need to use radian measurement for time when calculating things like the period and frequency, or can you just as easily scale the graph for degrees. Thanks!
Radians are actually dimensionless units. They are chosen so that sector area and arclength have the simple forms: s = r\theta and A = \frac{1}{2}r^2 \theta. If you used degrees these would be "messy".
I teach my students that "we always use radians" we just hide the fact. Treat the degree symbol as a number (pi/180). Thus e.g. 360^o = 360 \cdot \frac{\pi}{180} = 2\pi. The only problem with this is that calculators do not explicitly show the degree symbol so there you have to be careful about modes.
As for using time units, you should never have bare time units inside a trig function. The time unit should be multiplied by an angular frequency unit \omega (radians per second ) so that \sin(\omega t) is evaluating sine of a pure radian value.
Now you actually could work with "degrees per second" angular frequency but that too makes for bad formulas, e.g. speed (v) of a point rotating on a circle is v = r \omega provided \omega is radians per time unit.
As far as graphing goes if it is a function of time then it should be scaled in time units. If you would post the format of the question I might better understand what your teacher is insisting upon.
The main thing is that radians are the natural units of the trigonometric functions. (for example there is a small angle approximation sin(x) ~ x for small values, but only when you're working in radian units!) Get used to working in radians and converting between degrees and radians (and decimal cycles i.e. 360deg = 2 pi radians = 1 cycle).
You don't need to scale the graph, since you're plotting sin() versus time, but as previously posted, you'd need to specify the rotation of the ferris wheel in terms of radians per second or degrees per second and convert to the type of angle that the sin function uses.
Assuming that a sin function only takes radians as an input, you'd need to convert degrees to radians anyway:
For degrees, if the ferris wheel rotates d (degrees / second), you use
sin(t seconds x d (degrees / second) x (π radians / (180 degrees)))
For radians, if the ferris wheel rotates at ω radians per second, you use
sin(t seconds x ω (radians / second))
In either case, the graph of sin(t ...) (y axis) versus time (x axis) will be the same.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 19 ·
