Why does (A×B)·C use sine instead of cosine?
15 replies · 3K views
student34
The question asks to calculate (AxB)·C, where A's magnitude is 5.00, B's magnitude is 4.00, and they are both in the xy-plane. B is 37° counter clockwise from A. C has a magnitude of 6.00 and is in the +z-direction.
(A×B) = ABsinθ = D; D·C = DCcosσ = R
(A×B) = 5×4×sin37° = 12.363 = D. D·C = 12.363×6.00×sin90° = 72.2 = R which is the correct answer. But doesn't the dot in (A×B)·C imply a scalar product in which case the last part should be 12.363×6.00×cos90°?
You mean to say that [itex]\vec{A} \times \vec{B} = (5)(4)(sin37°) \widehat{n}[/itex], where n-hat is the unit vector orthogonal to both vectors.
... and don't forget to use the right-hand rule to get the direction of the product in relation to the z axis sign.
gneill said:
Does the cross product yield a vector or a scalar?
I don't know. It just asks to calculate (A×B)·C with the values that I gave above.
We haven't seen that n yet, so I don't think we are suppose to use it in this question.
Mandelbroth just means n to be the direction that AxB points. You have to know that to find the angle between AxB and C. How is the direction AxB points related to the directions A and B point?
It would be in the positive direction, but isn't A×B perpindicular to C either way? And why does the answer seem to use sin90° instead of cos90°; doesn't the function (·) mean a scalar product?
What do you mean by positive direction? Which positive? C points in the positive z direction. Which positive direction does AxB point? I don't think they are perpendicular. If the answer says sin(90), it really shouldn't. That's misleading. The answer should contain a cos. cos of what?
By definition, AxB is perpendicular to both A and B. What does that tell you about its direction in relation to C?
Ah, I got it now. Oh ya, and the answer did not have sin90°, I just fudged that in there to try to make sense of it all, but I realize now that it is cos0° - thanks.
Thanks, I go it now.
OK, but just to check... why cos(0) and not cos(180 degrees)?
@Puky The question haruspex asked was directed towards the OP to check his understanding.
My mistake, I thought it was the OP who asked that question.
