- #281
castlegates
It's amazing what you can make out of nothing ... isn't it? :-)You're making up poetic fiction based on nothing, literally.
castlegates said:It's amazing what you can make out of nothing ... isn't it? :-)
BINGO!Now you're calling brain tissue and how it functions "nothing"?
Langbein said:Why is there anything than rather nothing ? - Why is there sometning than rather nothing ?
Why does anything exist at all ?
Why is it like that ?
That's almost right. Actually there are only twos, two by two, where time is the something twos are not composed of. The brain works by pairing up these twos two concepts at a time, which makes the whole thing nothing. There, I fixed it for you and I'm sure everybody gets it now. :rofl:castlegates said:In our universe, there are only Ones, one at a time, where time is the nothing Ones are composed of. How the brain functions is a matter of interaction of these concepts of one..
out of whack said:That's almost right. Actually there are only twos, two by two, where time is the something twos are not composed of. The brain works by pairing up these twos two concepts at a time, which makes the whole thing nothing. There, I fixed it for you and I'm sure everybody gets it now. :rofl:
olliemath said:p.s. I've purposely skipped around the issue of whether the concept of nothing is logically consistent as that's already been heavily debated)
At least somebody gets it to some degree. I might add that the ones are composed of nothing at the risk of repeating myself. It is not the composition we need to concern ourselves with, for it doesn't exist, but the form of the composition that puts on the show. All things on all scales are understood through the same process. A baseball, a stop sign, a fundamental unit, a planet, a monitor, are all understood to be things under the same premise. You see a thing..like your monitor and the procedure is - nothing inside it, and infinitely nothing outside it. This is the geometric reality of the monitor (The conceptual understanding of one, and the form of it).A two is like the brain in that it is composed on ones.
granpa said:certainly that's true. but does time itself have a beginning?
This is about where I stand in the issue. On the fundamental level, reality is reduced to the wave function, buttressed up against non-existence as the necessary contradiction to make the show.2. For those of you that don't like 1.. We need not assume that our paltry logic holds outside the universe as we know it. For instance both nothing and something might easily exist at the same time (I also liked the complementary argument earlier, but that's a different matter) - like superimposed wavefunctions
On the contrary "nothing" can't be anything but a concept.baywax said:The concepts surrounding the idea of nothing have not even been touched. If they had there would be no discussion because "nothing" implies "no concept".
So time is an invention of man?As for the romantic notion of "the beginning of time"; this cliche is nothing more than a description of the first sun dial, or the first human record of a passing season. These accomplishments were the "beginning of time" as we know it.
Well which is it, an invention of man, or the sentence above, or both?Everything else, was/is/will be "change" or "transformation" and nothing more.
You lost me here. How can the value of each of those ones be different or varied? How is a (one) different from a (one), regardless of scale?If you look at the universe as 1111111111111111 I think there might be a basis for this being true. However, the value of each of those 1s is different and varied... unless you remove the effect of "scale". 0 can only enter the series when you need "emptiness" for the 1s to exist... however... as soon as "emptiness" or "0" is considered an effect... it becomes a "1".
Hmmm :-)Dismissing anything at all is always a mistake and leads to worse mistakes. When someone dismisses the brain as "nothing" they probably consider the universe "nothing". This exemplifies someone who has not appreciated the intricacies of neuroscience and who could be experiencing severe depression or a bout of emotionalism such as is found in the nihilistic persona.
castlegates said:On the contrary "nothing" can't be anything but a concept.
My differing opinion is that the concept of "nothing" is "something" (brain waves)... what the concept attempts to describe is "nothing" (a lack of such things as brain waves).
No one else has invented measurement systems such as "time" that I know of.
You lost me here.
Ditto.
I think you're using the number "1" in the wrong way. There is no qualitative value to it... only a quantitative value. So, to imagine "1" as a quality such as "energy" may be a misinterpretation... or, at best, a very new way of seeing the number.
Unthinkable said:Time is a measurement of space. Any number is a measurement; doesn't have to be one or zero.Therefore any number is of space; and therefore space could not exist if it was missing any number; and any number could not exist without space.
Space is infinite; and infinity is not a measurement since it has no beginning or beginnings and it has no ending or endings. Space is everything that happens at once; and everything that happens at once is always different than it was before.
While time is a measurement and it happens over a period of time; it has "beginning" which is created and it has an ending, time has an order like cause and effect; the order is the beginning before the ending and the effect after the cause.
Unthinkable said:Forget everything that you know about time and space for a second. And start with these simple logical deffinitions.
The time that changes.
And a measurement of time.
Both deffinitions are correct.
Now call the time that changes "space" and a measurement of time "time".
Aparrently time does not exist..and that which does not exist can not be made of energy.
2foolish said:Where do concepts come from and what are they made of?
That doesn't answer the question. The question was - What are concepts made of.Concepts are a result of brain tissue interacting with the environment.
Your expectation seems to be that if nothing exist, that we or anything else cannot exist at the same time. I could never show you the existence of nothing, without first giving it form. The definition of nothing uses a thing to convey the absence of it.Could someone please produce evidence that "nothing" exists"?
castlegates said:That doesn't answer the question. The question was - What are concepts made of.
I am a firm believer that to exist, one must have form. Any thing else and you may as well be talking about a ghost. My expectation here is three dimensional, and the various shapes of form constitute what would be different concepts, and these forms are composed of nothing at all, wherein the form itself carries the concept, such as an apple verses a rabbit, two diferent forms, two different concepts.
It conveys nothing within the boundry of form. A fundamental entity must be made of nothing. I.E There are no parts.
out of whack said:A lot of nothing is tossed around here. The last page or two show a sore lack of intellectual rigor. I read that what doesn't exist is relevant. I read that physical concepts we can all confirm don't exist. I see gratuitous inferences from vague statements presented as proof. Point them out and you receive a "you don't get it" followed by a repetition of the same idle claims. Reason has left the building. This thread has sunk to downright goofy levels.
True. But I plan no such demonstration, I can't possibly pick apart the overabundance of vague speculations posted recently. This is it from me, I'll step away until I see well-founded propositions to address.2foolish said:If you have beef with someone(s) you have not demonstrated your case.
out of whack said:True. But I plan no such demonstration, I can't possibly pick apart the overabundance of vague speculations posted recently.
