Why does gravity stay attractive if time runs backwards?
560 replies · 113K views · last reply
A-wal said:
If I was interested in learning maths then yes, that probably would be the best way of doing it.
Then at best you are only going to be able to get a shallow "pop-sci" understanding of GR, and even that is not likely.
A-wal said:
How can the horizon have a constant position in Schwarzschild coordinates
In Schwarzschild coordinates the horizon is the 3 dimensional surface given by:
[tex]r=\frac{2GM}{c^2}[/tex]
and so
[tex]\frac{d}{dt}\left( \frac{2GM}{c^2} \right) = 0[/tex]
therefore the horizon has a constant position in Schwarzschild coordinates.
A-wal said:
when ‘distance shortening’ means the amount of space you need to cover and the time it would take to cover the same distance would of course lengthen as you get closer to it?
The position of the horizon in Schwarzschild coordinates is clearly not a function of "distance shortening".
A-wal said:
When I said that light isn't subject to acceleration due to gravity I meant that it doesn't speed up like massive objects because it's already at the maximum speed that time will allow under any circumstances, c!
You've forgotten that light can change direction as well as speed. Yes, the locally measured speed of light is always c relative to a timelike observer, but that doesn't mean light isn't subject to acceleration due to gravity. Gravity can still change its direction, and can still tilt the light cones from place to place so that "moving at c" doesn't mean the same thing at different places.
A-wal said:
You could have a hovering observer at every point up until the horizon but not at or inside the horizon. That we agree on.
That's good. But it does *not* imply that...
A-wal said:
The speed that the in-faller would have to accelerate to relative to the hoverers would have to reach c in order to reach the horizon.
...because, as you just agreed, there is no hoverer at the horizon. More generally, there is no timelike observer at the horizon for the in-faller to "move at c" relative to. The only thing at the horizon that the in-faller moves at c relative to is an outgoing light ray at the horizon, and that's just because timelike observers always "move at c" relative to light rays (because light rays always move at c relative to timelike observers).
A-wal said:
That's exactly what I meant. A hoverer could accelerate away from the black hole as fast as they like and a free-faller would still always pass them at less than c. The same thing must happen with velocity at the horizon.
Not true, as I just explained above. There is no timelike observer at the horizon.
A-wal said:
When you try to approach c in flat space-time it slows down as you accelerate but you still can't ever reach it because the rate that it slows down relative to your acceleration decreases the harder you accelerate, and it gets faster overall so that once you've stopped accelerating it's increased its speed relative to your previous frame by the same amount as you have. When you try to approach an event horizon you can close the gap but you can't ever reach it because the rate that you close the gap decreases if you're free-falling, as you move into less "distance shortened" space-time relative to where you were. If you were able to reach it then it would be moving at c, which is why you can't reach it.
I see what you are getting at here, but it doesn't prove what you think it does. As I've said before, you can't just say "approach c" in the abstract; you have to say *what* you are trying to "approach c" relative to. It looks like what you are saying above is describing one timelike observer accelerating relative to another timelike observer (who is assumed to be "at rest"). If that's the case, it only applies in cases where there are two timelike observers with the required properties. At the horizon there aren't; there are no timelike observers "hovering" at rest at the horizon. So your analogy fails.
Also, I'm not sure why you insist on using the term "catch up to c". If you are trying to describe one timelike observer accelerating relative to another, then (by analogy with the Rindler horizon scenario) it would be better to say that a light ray emitted from a certain point can't catch up to the accelerating observer (as long as he continues to accelerate). If you really mean that the accelerating observer can't catch up to something, what is it? It can't just be "c" in the abstract, because that's not a physical object, it's just an abstraction.
A-wal said:
What do you think seems more likely?...You're the one who needs to prove it. You're making some outrageous claims but you feel safe doing it because it's the consensus view.
No, I feel safe in making the claims I'm making because I understand the standard general relativistic model that generates them, and how that model is both logically consistent and consistent with all the experimental data we currently have. The claims only sound outrageous to you because you don't have that understanding.
If you want me to "prove" that the standard GR model is the *only* model with those properties, then of course I can't. But when you ask "what do you think seems more likely?", you're basically invoking Occam's Razor, and to even apply that I would have to have another model in front of me that has both of the above properties. So *you* have to show me that your model, as an alternative to standard GR, has both of those properties, before I can even consider it. You haven't done that; you haven't even convinced me that your model is logically consistent (you keep assuming things that you are supposed to be deriving as conclusions in your model), and you also haven't even shown that your model accounts for all the data in the particular scenario we're discussing (the spacetime around a gravitating object), let alone *all* the data that GR accounts for.
A-wal said:
Both. Why do I have to pick one? The answer stays the same no matter how you look at it.
If you mean "the answer stays the same" in the sense that neither choice proves your case, I agree. But I don't think that's what you meant.
A-wal said:
Yes, the velocity of an outgoing light ray is always c locally. It slows down as it approaches an event horizon.
But if its velocity is always c locally, in what sense does it "slow down"? Relative to what? You need to unpack this statement further.
A-wal said:
I mean that if you measure the horizon to be a mile in front of you and then move a mile (as measured at this distance) forwards towards the horizon you'd find that you haven't reached the horizon because it's moved back.
How are you measuring the distance that you move through?
A-wal said:
The equivalent to a light ray (and therefore anything else) being unable to reach an event horizon in any amount of time for as long as the black hole exists.
And you *still* don't understand the scenario, even though I've drawn you a diagram. You even comment on the diagram later in your post:
A-wal said:
That graph could just as easily be used to show an in-faller approaching an event horizon.
What do you mean by this? Do you mean that the "free-faller" lines in the diagram (the dark magenta vertical lines) are analogous to the worldlines that objects free-falling into a black hole would follow? If so, then I agree, and you have just agreed that objects free-falling into a black hole *can* cross the horizon (because they certainly do in the diagram). If you meant something else, then you need to describe what you meant, because you aren't describing anything that the diagram shows.
A-wal said:
No one crosses a Rindler horizon. There is no Rindler horizon for the free-fallers. It's created by the accelerating observers.
In a sense, yes, the Rindler horizon is *defined* by the family of accelerating observers. But once defined, it is a perfectly ordinary lightlike surface in the spacetime, and all observers agree on which surface it is, and free-fallers can cross it (in the ingoing direction).
A-wal said:
The equivalent to a distant observer sending a light ray towards a free-faller approaching an event horizon and there being no way of the light reaching them before the black hole's gone. The black hole dying and the light ray reaching the free-faller is the equivalent of the accelerator stopping and the light catching up.
Nope, you've *still* got this backwards despite repeated corrections from me. I was talking about free-fallers sending *outgoing* signals. You are talking about distant observers sending *ingoing* signals. They're not the same.
A-wal said:
The equivalent of no free-faller being able to reach c relative to any observer at any distance from the horizon.
Incorrect. I already addressed this above.
A-wal said:
No, a free-faller not being able to send a light signal that can catch up with a Rindler horizon is equivalent to an free-faller not being able to send a light signal that can catch up with an event horizon.
Again, you've got this garbled. The Rindler horizon is the path of an *outgoing* (positive x-direction) light signal that can't catch up with any of the accelerating observers as long as they continue to accelerate. It is true that a free-faller, once *inside* the horizon, can't send a light signal that can "catch up with the horizon" in either scenario (flat spacetime or gravity present), but that's just because a light signal can't catch up with another light signal emitted earlier in the same direction.
A-wal said:
Give me a chance. You're talking as if I'd already disagreed with you and as far as I can remember I haven't done that once with flat space-time examples.
Even with the flat spacetime examples, you have repeatedly misstated things (some of which I point out above), and it's not clear to me that you have a good understanding of how those examples work in flat spacetime alone, even leaving out how they relate to the curved spacetime examples.
A-wal said:
I genuinely believe that the whole space-time is covered using just Schwarzschild coordinates/the light cones can't tilt to 90 degrees/you can't cross an event horizon because it's moving inwards/you can't reach c.
Yes, I know you do. And you've just stated a key difference between your model and the standard model. In the standard model, the horizon moves *outwards*, not inwards.
In more detail: in the flat spacetime scenario, the Rindler horizon moves outwards at c ("outwards" meaning "in the positive x-direction"). The standard GR model also has the black hole horizon moving outwards at c (but spacetime is curved due to gravity so "moving outwards at c" at the radius of the horizon means the horizon stays at the same radius). This leads to a pretty close analogy between the Rindler horizon scenario and the black hole horizon scenario, in which the diagram I drew of the Rindler horizon scenario also represents the black hole scenario (not quite exactly because of the curvature of the black hole spacetime, but close enough to answer questions like whether a free-faller can reach and pass the black hole horizon). In that analogy, the free-faller lines in the diagram (dark magenta vertical lines) are the worldlines of observers falling towards the black hole; the accelerated lines (blue hyperbolas) are the worldlines of observers "hovering" above the black hole at a constant radius; and the Rindler horizon (red 45-degree line going up and to the right) is the black hole horizon.
You have a model in your head in which the horizon is moving inward, not outward. That model certainly can't be described by the diagram I drew, so you need to draw your own diagram. And since you already agree that my diagram describes the flat spacetime scenario, your model certainly can't be analogous to the flat spacetime scenario I described in any useful way (since in that scenario the Rindler horizon certainly moves outwards, not inwards). So where's your diagram?
A-wal said:
Of course it's an ingoing null surface moving back in such a way that a free-falling observer could never catch up to it.
It's not "of course" at all. Your whole picture of this is garbled. See comments above, and further comments below.
A-wal said:
It's moving back at c because c sets the limit to how far you can get in a certain amount of time
Relative to what? Time according to what observer?
A-wal said:
, so the event horizon represents how close you can get to the singularity at the time that you're seeing it.
Seeing what? You never "see" the horizon unless you free-fall past it.
A-wal said:
When you accelerate in flat space-time c gets faster, not slower, relative to your previous frame which prevents you from reaching c.
This is all garbled. In flat spacetime, "c" never changes; in fact, lightlike lines (the paths of light rays) and surfaces are the most "constant" things there are in flat spacetime (since the light cones never tilt, so light cones everywhere are exactly "lined up" with each other). One could say that a particular light ray that's moving away from you will always move away from you at c, no matter how hard you accelerate towards it, but even that doesn't justify saying that "c gets faster"--at best, it justifies saying that "c stays the same".
A-wal, here's some more food for thought on the question of which direction the horizon moves (outwards or inwards). In both scenarios (Rindler horizon in flat spacetime, black hole horizon), there is a family of accelerating observers who are clearly accelerating outwards (positive x-direction in flat spacetime, positive r-direction with respect to the black hole). And yet both families of observers "hover" at a constant distance from the horizon (the specific distance at which each observer hovers depends on that observer's acceleration). Doesn't that mean the horizon has to be moving outwards, in order to stay at the same distance behind observers who are moving outwards?
The average speed of light between two points in an accelerating frame is always not equal to c except when the line between the two points is perpendicular to the direction of acceleration.
You raise an interesting point. The above statement is true provided we use "ruler distance" as the definition of "distance" for the purpose of calculating the average speed of light (we would of course use the round-trip light travel time, as measured by a given accelerated observer, as the definition of "time"). I'm using the terms as given in the Wikipedia article on Rindler coordinates:
http://en.wikipedia.org/wiki/Rindler_coordinates
But as the article notes, "ruler distance" is not the only definition of distance that can be adopted between accelerated observers in flat spacetime. If we instead use "radar distance", then the average speed of light *is* always equal to c (because radar distance is defined as the light travel time divided by c).
I assume that A-wal had in mind "ruler distance" when he said that "c gets faster as you accelerate". However, even then the statement as he phrased it is not quite true (at least as I understand his statement). What is true is the following: the ratio of "ruler distance" to round-trip light travel time does give an "average speed of light" greater than c for an accelerating observer, and how much greater does depend on the acceleration. However, for any *given* accelerating observer (i.e., for any given constant acceleration), the ratio (and hence the "average speed of light") is *constant*--it does *not* get larger as the observer continues to accelerate. This is because the ratio is a function solely of the "ruler distance" (h in the Wikipedia formulas) and the acceleration (which is in turn a function only of x_0 in the Wikipedia formulas--it is c^2 / x_0 for the "trailing" observer and c^2 / (x_0 + h) for the "leading" observer). So while it is correct, using this definition of "average speed", to say that "the speed of light *is* faster" than c if you are accelerating, it is *not* correct to say that "the speed of light *gets* faster" in the sense of continuing to get faster as you continue to accelerate (if your acceleration is constant)--by that criterion, my statement, that "c stays the same" is correct.
Regarding A-wal's statement that "c gets faster as you accelerate, so you can't reach c", I should also mention that he is conflating two different observations. The statement that "c gets faster as you accelerate" I unpacked and critiqued in my last post. The statement that "you can't reach c" doesn't even apply, really, to the accelerating observer, because (a) relative to himself, he just remains at rest; and (b) as I noted in my last post, for him c does not "get faster as he accelerates", it just happens that c is "faster" (in the sense of ruler distance divided by round-trip light travel time) than if he were not accelerating. The accelerating observer "can't reach c" only relative to an inertial observer, who sees his velocity increasing asymptotically towards c but never reaching it. And to the inertial observer, of course, the speed of light *is* always the same--c.
Let's make a pretty pattern. Try not to ruin it. Two accelerators, one free-faller. The first accelerator stays hovering one metre away from the horizon as measured by them. The second accelerator hovers one metre away and waits until the free-faller is also one metre away from the black hole as measured by both accelerators, then the second accelerator accelerates even more to move away from the black hole at .5c relative to the hovering accelerator. The same accelerator then uses the same amount of additional energy again to accelerate away even faster, but they're not now moving at c relative to the hoverer. They'll never be able to accelerate to c no matter how much energy they use.
The free-faller falls past the hoverer at .5c but when the free-faller has moved closer, where the strength of gravity is twice as strong (.75 of a metre I suppose), they're not now moving at c relative to the hoverer. They'll never be able to accelerate to c no matter how much energy they use. Whether it's from gravity or not makes no difference. The real velocity of the free-faller relative to the hoverer will be exactly the same as if they’d doubled their acceleration in flat space-time relative to an inertial observer.
Oh well. I'll just have to make do then.
and so
That's because Schwarzschild coordinates assume an everlasting black hole. A hoverer who's maintaining a constant distance from the horizon will be moving towards the singularity. How fast they move towards it depends on how far away they are, a bit like gravity itself really. They’ll get closer to the singularity as the event horizon gets closer to the singularity, as it looses mass. At the event horizon it’s losing the exact amount it needs for the event horizon to back at c. It’s the equivalent of an accelerator in flat space-time reducing their acceleration (the equivalent of the black hole loosing mass as it ages) to keep their Rindler horizon in the same place I suppose.
It clearly is. The horizon limits how close you can get. There’s a limit to how close you can get because of ‘distance shortening’.
Of course. I hadn't forgotten. That's just not what I was talking about. You’re so quick to disagree that you keep taking what I say out of context. I get the impression you've already decided that nothing I say suggests anything and you're working backwards from this premise.
There doesn't need to be a hoverer at the horizon. They don't have to be in the same place to have a relative velocity to each other. The hoverer could be arbitrarily close to the horizon, but even that's not necessary. They can also take any relativistic effects into account no matter how far apart they are when they measure their speed.
No there isn’t, but not for the reason that you think.
Of course there aren’t any time-like observers at rest at the horizon, because there can't be. If it were possible to reach an event horizon then it would obviously be possible to hover there. If one force can pull you in then it's not possible (and to be honest, completely ridiculous) to say that no amount energy can move you away. The analogy holds BECAUSE there's no time-like observers hovering at the horizon, because that would be the equivalent of accelerating to c in every frame.
Their own light waves, which would be stretched into a straight line in their direction of motion behind them (infinitely long wavelength) and a straight horizontal line directly in front of them (infinitely short wavelength). I'm using that term to show that you can't catch up to your own light. It doesn't work like sound. You can't catch it any easier using gravity than you can through conventional acceleration, but that's exactly what you would have done if you were able to reach an event horizon.
I really don't think it's logically consistent and just because I don't agree you doesn't mean I don't understand. It seemed to make sense to start with, until I actually thought about it. Then I realized just how stupid it was.
I think I have shown that it's logically consistent. Which parts are you having trouble with?
I mean that it's a little strange that you seem to be asserting that I can't change the parameters of a thought experiment to look at it in a different way. And the answer will be the same no matter how you look at it.
It slows down from the point of view of the observer who emitted the light. The light leaves them at c but slows as it gets closer to the horizon and gets more ‘distance shortened’. How sharply it slows depends on how close you are to the horizon when you emit the light. How would that work if you could reach the horizon?
By working it out based on the mass of the black hole and the energy expended so far, or by comparing yourself to a row of hovering observers for reference.
I meant it looks as if those lines wouldn’t cross the horizon and the angle they’re at looks like what you get when comparing an accelerators velocity with c, and that should be exactly the same as an object approaching an event horizon.
But accelerators can't. The same thing happens in curved space-time around a black hole. There will be a point when a signal sent from a more distant observer can’t reach a free-faller because the free-faller is being accelerated by gravity. The Rindler horizon gets closer to the free-faller as they accelerate harder due to the increase in gravity, just like it does when you use energy to accelerate in flat space-time.
No they're not. Your confusion is because you’re assuming the free-fallers are equivalent in both examples. They’re not. Think of the distant observer as being far enough away that the barely need to accelerate, or free-falling very far behind if you prefer. This observer is the equivalent to the “free-faller” in flat space-time. The in-faller is the equivalent to the accelerator because they’re being accelerated by gravity. You’re the one who keeps getting it backwards. I would have thought you’d have figured that out by now.
You addressed it yes. You've addressed a lot (still not all) of my points showing how you think it works without giving any explanation that actually shows why it works the way you think it does.
It's not garbled. It's the garbled way that you insist on looking at it that makes it seem that way. Acceleration in flat space-time pushes outwards and acceleration through curved space-time (gravity) pulls towards. That’s why the event horizon moves inwards and the Rindler horizon moves outwards, and why you’re getting muddled.
I know how they work in flat space-time.
What do you mean “not quite exactly because of the curvature of the black hole spacetime”? It’s the same situation in reverse.
What diagram? It’s analogous to the flat space-time scenario in a very useful way. The Rindler horizon appears because of acceleration. The event horizon appears because of gravity. Acceleration pushes everything away and gravity pulls everything in. You can't reach c in either case so you can't reach either horizon. Reaching an event horizon is the equivalent of your Rindler horizon catching up with you.
It’s not my picture that’s garbled! See this whole bloody thread!
Relative to anything according to any observer.
The event horizon is the closest any object can get to the singularity at that time. You can get closer over time but to cover the amount of space-time needed to reach a singularity before it's gone you would need to move at c, because the horizon is moving towards the singularity at c.
If you accelerate then light in your new frame is moving faster than c relative to your old frame (c + the difference between your new velocity and your old one), but not if you were actually in your old frame obviously. It has to to stay constant.
That’s a very small meal. The horizon is moving inwards at c but slower than that at any distance away because that’s how time dilation and length contraction work. You already said: "(but spacetime is curved due to gravity so "moving outwards at c" at the radius of the horizon means the horizon stays at the same radius)”. So you agree that time dilation is infinite at the horizon, and that even if an object could somehow be magically accelerated to c it would be frozen in time? So in what sense is it possible to be accelerated to c? It's curved inwards by gravity, not outwards.
Yes, c stays the same if your acceleration remains constant. If you increase your acceleration it slows down and if you decrease your acceleration it speeds up again.
The accelerator can’t reach c in the sense that c slows down as they accelerate but it can never slow to zero because the decrease in its speed itself decreases as they accelerate. That’s why adding velocities won’t let you reach c, whether it’s acceleration through energy or through gravity. It would even be the exact same formula for an object approaching an event horizon and an object approaching c if its acceleration were to increase to mimic the inverse square of gravity. Either way, the event horizon or c increases their velocity by the same amount as the other would as you approach them, which stops you from ever being able to reach them.
You think an objects can cross an event horizon but that's obviously not how it works, which I've shown, but you've got this stupid idea in heads that gravity isn't a real force when it obviously is, which is why you've got this messed up notion that it can ignore SR and accelerate an object to any relative velocity. I can see how it works because I'm not fumbling about in the dark trying to use equations as dimly lit torches. You've already decided how it works and anything that suggests otherwise is assumed to be misleading. This is pointless. I've had more constructive conversations with god worshipers. I give up. You win. Stubbornness triumphs over common sense. I hope you proud of yourselves.
I've decided no such thing. It's true that much of what you say makes little or no sense to me. Some of that is because you have a different mental model in your head than I do, but when you are able to describe the model coherently, I can understand it. Unfortunately, every time that's happened, I've pointed out an inconsistency in your model and you've backed off from it and lapsed back into vague hand-waving. This makes me suspect that the reason much of what you say makes no sense to me is that you don't actually have a single, coherent model; you have a patchwork of ideas but you haven't fit them into a single coherent picture.
Of course this is my perception, and it may be wrong. But I'm in the same position relative to your model, as you appear to be relative to the standard model. You don't understand how a single, coherent model could produce all the conclusions that I claim the standard model produces. Similarly, I don't see how a single, coherent model can produce all the claims you have made for your model. I've been trying to work back to first principles, to find *some* starting point that we have in common, and then work forward from there. But most of the time you keep on asserting conclusions, when we haven't even reached an agreed set of premises to start from. That makes it difficult to have a productive discussion.
They do in the standard model; in standard GR there is no meaning to the term "relative velocity" (at least, no *physical* meaning that allows you to say things like "the relative velocity has to be less than that of light") unless both objects are at the same event (more precisely, in the same local patch of spacetime, small enough that tidal effects can be neglected). If this term has a definite meaning in your model, what is it? How is it defined? How is it measured? Please be specific.
Why? In the standard GR model, this is a non sequitur. There is no requirement to be able to "hover" (in the sense of staying at the same radial coordinate) at every place. If this is a requirement in your model, why? What makes it a requirement? And how can you rule out, a priori, models that don't meet this requirement? Again, please be specific.
There's no "force" pulling you in. Spacetime is curved in such a way that freely falling objects move inward; since they're freely falling, they feel no acceleration and are therefore subject to no force. On what basis does your model assert that a force is acting, when it is not felt by the object it's supposedly acting on?
(I note also that here, as later on in your post, you are basically asserting that a freely falling object is physically equivalent to one feeling nonzero proper acceleration. I comment on that further below.)
I agree you can't catch up to your own light. But the only sense I can make of this in terms of "moving at c" serving as some kind of fixed point relative to which all motion can be judged, is by using the paths of light rays--i.e., the light cones. And in curved spacetime, they're tilted by gravity, so if you use them as your reference for motion, you will find that, as I said before, "moving at c" means different things in different places. So it's no longer the kind of fixed background you've been assuming.
I would say you haven't thought hard enough. For one thing, whenever I point out an assumption you've made (I pointed out at least two earlier in this post) and ask you why it has to be true, you have no answer. You just say "it's obvious" or something like that. Sorry, but it's *not* obvious; not if you've actually thought about it. The fact that you have failed to question all these "obvious" assumptions tells me that you haven't really thought about it; you may have spent plenty of time at it, but that's not enough.
But I'm not really interested in what you think is wrong with the standard GR model. I'm interested in trying to get to *some* set of starting premises that we can both agree on. Then I would like to see you build up your model of how things work from those premises. If the standard model really is wrong, this procedure ought to show us that at some point.
Um, the parts you haven't even given? Like, as I've said, getting to a set of premises that we can both agree on? Until we have that, you have no right to assume that you have established *any* of the claims you've made that contradict the standard model. You can't just assert them. You have to show how they follow from agreed premises. Since we don't even have the agreed premises yet, I don't see how you can think you've accomplished anything like this.
How does the observer who emitted the light find out that it has slowed down? Does he measure the slowdown somehow? If so, how? Or does he get the information from some other observer? If so, what information, and how does it tell him that the light has slowed down?
In other words, you believe that an observer who is in free fall, feeling *zero* acceleration (remember you agreed, after quite a bit of back and forth, that such observers do in fact feel exactly zero acceleration) is physically equivalent to an observer feeling *nonzero* proper acceleration. Well, here's another assumption that you are making that is different from standard GR. In standard GR, you determine whether observers are physically "equivalent" by the simple method of comparing their accelerometer readings. On what basis does your model claim that a freely falling observer is physically equivalent to an observer feeling nonzero proper acceleration?
Spacetime is curved *inwards* at the horizon just enough to make a light ray moving *outwards* (i.e., the horizon itself) stay at the same radius.
As I noted in my last post, why is this obvious? This "force" you speak of is not felt by the objects it is supposedly acting on; an idealized, point-like object moving solely under the influence of gravity feels exactly zero acceleration, as you agreed earlier in this thread. So how do you claim that this object, which feels no acceleration, is being subjected to a force?
I can understand why you're frustrated. You are operating with a set of assumptions that I (and DaleSpam and others) do not share. It's always difficult to have a discussion when the parties don't even share basic assumptions. I too have had such frustrating discussions with what you call "god worshipers", because I don't share their assumptions and I can't get them to even consider mine. But I'm willing to consider yours, *if* you can justify them, and then build up a coherent model based on them. What I can't do is talk about conclusions without getting clear about the premises first, when it's clear that the premises are different enough that they need to be specified explicitly.
The question I asked above is an example. You assume that there is a clear, obvious definition of "force" under which gravity is a force. What is that clear, obvious definition? Spell it out. Is it just standard Newtonian physics? Well, standard Newtonian physics is falsified by experiment. So that's out. What's next? What model is there that says gravity is a force, and still gives all the right answers?
Or, alternatively, suppose I offer the following definition: a "force" is any of the four fundamental quantum interactions: strong, electromagnetic, weak, or gravitational. So gravity *is* a force! But when we try to construct a theory of this force, starting from standard quantum field theory, as was done during the 1960's, this theory (or at least its classical limit) turns out to be--standard General Relativity. So there *is* a model that says gravity is a force, and gives all the right answers: standard GR! But of course, that depends on adopting the definition of "force" I gave just now. Is that your definition? If so, then we're good--you agree with standard GR, and standard GR predicts that a black hole horizon can be crossed. If not--then what *is* your definition?
Of course nothing *requires* you to answer these questions. I said quite a while ago in this thread that if you want to take the position that GR is, in your opinion, an approximate theory that happens to work in the Solar System, with binary pulsars, and so on, but which will be found to be inaccurate when we can make a close enough study of black holes, I have no quarrel. We won't know until the evidence is in. That's an empirical question, not a theoretical one.
But if we are talking about theory, then I'm sorry, but you have not shown what you think you have shown. All you have shown is that you don't understand how a consistent model can be constructed using assumptions that are different from yours. Maybe those assumptions are wrong; we won't know for sure until the evidence is in. But that won't make the model based on them inconsistent; it will just make it incorrect.
Agreed. An inertial observer free-falling across an event horizon will always remain timelike, never lightlike.
Can you derive any of this?
Hmm, for some reason I missed A-wal's other post.
I assume you mean by this "at the same distance from the horizon as the first accelerator", correct?
I assume you mean "until the instant that the free-faller is just passing both accelerators", correct?
Sort of true; the second accelerator could in principle accelerate hard enough that, by the time he reached an ultra-relativistic velocity relative to the first accelerator (or "hoverer"--I assume these refer to the same observer), meaning a relativistic "gamma" factor much, much larger than 1, the second accelerator would still be close enough to the first accelerator that tidal effects would be negligible over the distance between them, so there would still be a physical meaning to their "relative velocity". In this case, yes, the second accelerator could never actually reach c relative to the hoverer, no matter how hard he accelerated. But once the second accelerator gets far enough away from the hoverer that tidal effects are important, there is no longer a physically meaningful way to specify their relative velocity (where "physically meaningful" means "in a way that requires the relative velocity to be less than c").
Again, sort of true; for the free-faller's "relative velocity" to the hoverer to be physically meaningful, tidal effects have to be negligible over the distance between them. This can be done by making the hole's mass large enough for the hoverer's distance above the horizon to be small compared to the distance over which tidal effects are important. In that case, yes, as long as the free-faller is above the horizon, he will be moving at less than c relative to the hoverer.
As long as the free-faller remains above the horizon, yes, this is true, although I would put it in reverse, so to speak: the hoverer's velocity relative to the free-faller will be exactly the same as if the hoverer were accelerating in flat spacetime while the free-faller stayed at rest. This makes it clear which pairs of observers are "equivalent" in the flat to curved spacetime analogy, at least on the standard view. On your view, apparently the freely falling observer in curved spacetime (who feels zero proper acceleration) is supposed to be equivalent to the accelerating observer in flat spacetime (who feels nonzero proper acceleration). Which leaves me confused as to what observer in flat spacetime the hoverer in curved spacetime is supposed to be equivalent to.
When the free-faller reaches the horizon, light from the free-faller can no longer reach the hoverer, so the hoverer will never observe that portion of the free-faller's worldline (as long as he continues to hover). So the hoverer will never see the free-faller "move at c", or faster. Again, this is the standard view. I'm not sure what is supposed to happen to the free-faller on your view; I know you claim that the free-faller just continues to slow down indefinitely, but since you haven't explained how I'm supposed to relate the free-faller's "clock time" to the "clock time" of the hoverer, I don't know how you are determining this. You can't be using the standard GR relationship, because in standard GR the free-faller reaches the horizon after a finite time by his clock, not an infinite time.
And we established quite a while ago that even for this case, an everlasting black hole, you believe the horizon cannot be reached. So all this about a black hole losing mass is irrelevant.
Give me one example of when I've lapsed into "vague wand-waving", or even one example of when you've pointed out an inconsistency with anything other than the standard model. The "patchwork of ideas" are from the single coherent picture, not the other way round.
We agree on SR. The basic premise is that trying to reach an event horizon using gravity is the same as trying to accelerate to c in flat space-time.
That's like saying an inertial observer can't have a relative velocity to an accelerator in flat space-time. A difference in tidal force is the same as a difference in acceleration.
Because it's silly to say a finite amount of one force can't be overpowered by an infinite amount of any other.
On the basis that it affects the velocity of objects relative to other objects, diluted as the inverse square of the distance, just like the electro-magnetic force does. One curves in, one curves out.
No, not relative to a fixed point. I was talking about a free-falling observers own light and how light would stop behaving like light at the horizon. You would catch up, like a sonic boom. The light from in-falling objects ahead of you doesn't reach the horizon. So as you get closer, the light from you and everything else that's ever approached the singularity doesn't cross the horizon, ever! It is a fixed background in four dimensions and using the light cones doesn’t prove anything because the way you use them assumes what you’re trying to prove.
It is obvious. The fact that you can't see that tells me that you think memorising a model qualifies as thinking about it. I've spent more time writing this than I have thinking about it. I used to think about it a bit. Now I just think how to describe it.
What happens at the event horizon shows us that. It shows that the distance between the event horizon and the singularity is proportional to your distance from it (inverse square), in the same way that 'distance shortening' in flat space-time is directly proportional to your acceleration.
My right to assume that I've established a premise doesn't depend on whether or not I can get you to agree.
They compare notes with the accelerating hoverers of the riverbed as they free-fall past them.
A free-faller feels non-zero acceleration as tidal force. A point-like object wouldn't feel tidal force but it wouldn't feel acceleration in flat space-time neither.
So it would be curved by exactly the same amount it would be as if you had accelerated to c. Infinite time dilation keeping the light frozen in time. The ingoing light never gets frozen. It just keeps slowing down, like it does when you accelerate in flat space-time.
It's being accelerated relative to other observers who are also accelerating purely under the influence of the same force.
The premise is that gravity is a force that pulls instead of pushing, and it's weak because it's caused by mass rather than energy. Actually that's more of a conclusion than a premise, but it works both ways.
GR. It would give all the right answers if it was done right.
A force is anything that creates a curved line in space-time. You can effectively remove a force simply by not resisting it. Then the only way you know your being influenced by a force is your acceleration relative to other objects.
Theoretically it can't, and there's no reason it should work the way you're describing.
The model becomes inconsistent for lots of reasons as soon as an object is allowed to reach an event horizon. It moves inwards faster the faster you moving relative to it, like light.
But an inertial observer free-falling across an event horizon would become light-like.
The event horizon is how close you can get to the singularity at that time and you can move at c, and its radius is proportional to its mass.
Yes.
Yes.
Yes there is. Tidal force is the same as proper acceleration. The one accelerating away will be feeling less tidal force as the distance increases.
They'll be moving at less than c relative to the hoverer no matter how hard they accelerate. The 'distance shortening' when trying to reach the event horizon is the same as you would get in flat space-time trying to reach c relative to an inertial observer.
Well, it just leaves the inertial one. The hoverers gravitational acceleration is canceled out by conventional acceleration. They’re cumulative for ‘distance shortening’ but the hoverer is by definition at rest relative to the black hole.
Just make time dilation infinite at the horizon and work outwards to the hoverer using the inverse square of the distance.
Not really. It's accelerating objects towards it and the event horizon is how close you can get to it, so the horizon obviously moves inwards at c and its size is proportional to its mass. You could follow the horizon in at almost c and travel billions of years into the future. The equivalent of almost catching your own light in flat space-time.
Basically there's three hoverers, all the in the same place to start with. One of them stays at this radius the whole time (we'll assume the experiment doesn't take long enough for the radius of the event horizon/mass of the singularity/lifespan of the black hole to be important). This observer is to show that the two ways of accelerating are symmetric. One of the hoverers accelerates away from the black hole slowly at first and increasing their acceleration as an inverse square to their distance, while the other stops hovering and free-falls towards the black hole. From the perspective of the observer who's still hovering, the one accelerating away is starting to catch up to their own light. They'll never be able to catch it though because it becomes harder for them to accelerate relative to it the faster they go. Still from the perspective of the observer who's still hovering, the one falling in is starting to catch up to their own light. They'll never be able to catch it though because it becomes harder for them to accelerate relative to it the faster they go. The rate that the horizon recedes is exactly the same as the rate c recedes, depending on your acceleration. You can't reach either.
Most of what you say is vague hand-waving as far as I'm concerned, because you haven't established the basic premises that you're reasoning from. You just keep on asserting things that contradict the standard GR model, without justifying the assumptions you have to make to get to your assertions.
A-wal said:
...or even one example of when you've pointed out an inconsistency with anything other than the standard model.
You originally claimed that a point-like object moving solely under the influence of gravity would feel a non-zero acceleration. After I pointed out inconsistencies in this, you eventually backed off, agreed that a point-like object moving solely under the influence of gravity would feel zero acceleration, and then didn't follow that train of thought any further, for example, to explain how your model accounts for the fact that two point-like objects, both moving solely under the influence of gravity, can change their spatial separation, and the rate of change of that separation, with time even though both feel exactly zero acceleration. Instead, you went back to just asserting your conclusions without showing how you derive them.
And I've pointed out differences between the two cases that make this analogy fail, which you haven't addressed; you just keep on asserting the analogy.
How so? Instead of just making a vague statement like this, how about doing what I asked and giving your specific definition of what "relative velocity" means when the two objects in question are not near each other (so that the curvature of the spacetime in between may have a significant effect).
How so? Again, please give your specific definitions that lead you to this. As you should know by now, in standard GR this is false, for the reason I pointed out above: tidal gravity can be observed with two point-like objects, both moving solely under the influence of gravity, that change their spatial separation and the rate of change of that separation with time, even though they both feel zero acceleration. This is a key physical difference between tidal gravity and proper acceleration. How does your model account for this?
An object that is affected by electromagnetic force will feel a non-zero (proper) acceleration. It won't be moving solely under the influence of gravity. This is a key physical difference between non-gravitational forces and what you are calling the "force" of gravity. How does your model account for this?
How can you possibly catch up to light that starts out in front of you and is moving in the same direction as you? I don't understand how your model accounts for this. It certainly doesn't happen in the situation you claim is analogous, that of accelerating observers in flat spacetime. No accelerating observer in flat spacetime can ever catch up to a light ray moving in the same direction that starts out in front of him.
How so? The light cone structure of the spacetime is not an "assumption"; it's derived from the solution of the Einstein Field Equation subject to the appropriate boundary conditions. The only "assumptions" are those boundary conditions and the EFE itself.
Are you saying that in your model, the distance from the event horizon to the singularity is proportional to the distance of a given observer from the event horizon? Just clarifying to make sure I understand.
Maybe "right" was the wrong word. What I meant to say is that unless I see an actual valid argument, starting from premises that we both accept, I see no reason to accept your conclusions.
So in other words, you are claiming that, if I am freely falling towards the horizon and emit a beam of light, as I pass successive hoverers, they will observe the beam of light traveling more and more slowly? That each hoverer won't see the light beam passing him at the speed of light? How are you arriving at this result?
Do you mean proper acceleration? In other words, do you mean that if I subjected a point-like object to a non-gravitational force, such as a rocket, it would feel zero acceleration? What makes you think that? In standard GR, and even in standard Newtonian physics, the object certainly would feel a non-zero acceleration when subjected to a non-gravitational force.
If you mean "accelerated" in the coordinate sense, then yes. But not in the sense of proper acceleration, since all such point-like objects moving solely under the influence of gravity feel zero acceleration, as you've agreed. So how do you explain the fact that objects which feel zero acceleration can still "accelerate" (more precisely, as I stated it above, their relative separation and the rate of change of that separation changes with time) relative to one another? You are aware, I trust, that this can't happen in flat spacetime?
If you think this is a premise, you are mistaken. A premise is something that we can draw logical deductions from. What logical deductions can I draw from this vague statement? None as far as I can see.
LOL
Please give your specific definition of a "curved line". I have given the standard GR one several times now.
I don't understand how this relates to what I said.
How is it inconsistent? I understand that it's inconsistent with your particular assumptions (such as the assumption that there must be a "hoverer" at every point in the spacetime), but that just means your assumptions are not necessarily true. If you want to claim it's inconsistent period, you have to show that your assumptions *must* be true. You haven't.
As I've pointed out a number of times now, in the standard GR model the horizon moves *outwards*, not inwards. Please explain how your model has it moving inwards.
Why? The horizon is an *outgoing* null surface. The free-faller is moving *inward*. He's moving in the opposite direction to the light ray. So he can remain timelike just fine.
Not in standard GR it isn't. I've already pointed out a number of times the key physical difference between the two. How does your model account for that?
So let me get this straight. You claim that the free-faller in curved spacetime is equivalent to the accelerator in flat spacetime. But you claim that the hoverer in curved spacetime (who sees the free-faller moving *inward* relative to him) is equivalent to the inertial observer in flat spacetime (who sees the accelerator moving *outward* relative to him). I don't understand how this analogy can possibly work.
Here's a suggestion: post a diagram showing how you think your model works. Show the worldlines of the hoverer and the free-faller, the horizon, paths of light rays, etc. Your verbal descriptions are just not getting your model across. Maybe a picture will help. It's not that a picture will necessarily convince me that your model is right; it's just that based on your verbal descriptions, I can't even make sense of your model at all.
This doesn't really clarify anything. How about giving an actual specific calculation?
Can you draw a diagram of this? And can you actually calculate the worldlines of the three observers (and the light rays you mention), instead of just waving your hands and assuming they will look the way you claim they will look?
Bollocks!
I don’t see how a point-like object could feel anything. If you take away the dimensions they can’t feel a curve.
You haven’t given a single good reason for why this analogy fails. You’ve just kept on making the same flawed arguments.
It means exactly the same thing as it does in flat space-time when you compare the relative velocity of two objects accelerating at different rates.
It accounts for it because exactly the same thing would happen with two point-like objects accelerating at different rates in flat space-time.
It assumes the people it’s being explained to are paying attention.
No he can’t can he! So he can’t reach the horizon either can he! If he could then he would have caught up with his own light! An accelerating observer in flat spacetime approaches the speed of their own light and they can get as close to it as they like, but they can never reach it. Sound familiar?
It’s an assumption that they’re not relative and can go past 90 degrees.
Length contraction is proportional to the distance of a given observer from a massive object because their acceleration is increased, so yes!
Then we’ll be waiting forever because you’ve already made up your mind and I could give the most complete and well written description ever produced on any subject and you’d still refute it. That good though. It’s forcing be to define it much tighter than I would bother to do on my own. Keep asking questions.
No that’s not what I meant. The hoverers would observe the beam of light traveling at the speed of light. The time it takes for their light to reach the hoverers takes longer the further they fall.
It what sense would they "feel" it?
Accelerated in the coordinate sense? I don’t see the distinction in this case. All accelerators are accelerated in the coordinate sense.
Look harder!
PeterDonis said:
LOL
Well you must have figured out that I think either it hasn’t been done properly or the theory’s completely wrong. If it was done right it would show gravity as the equivalent to acceleration in flat space-time but it doesn’t, so it’s not been done right.
Acceleration, curvature, gravity, even spin are all basically the same. Any time you feel a force.
An object can’t reach an event horizon, even in theory. It doesn’t make sense.
There can never be a point when you can’t hover any more because that would require infinite energy. You can’t reach c in flat (using energy) or curved (using mass) space-time.
Because gravity pulls inwards. When you try to reach c in flat space-time the horizon moves outwards.
What would that have to do with anything even if it were true?
What key difference? Point-like objects feel proper acceleration but not tidal force? I don’t see how.
I don’t know what you mean. Both the hoverer and the inertial observer see the accelerator/free-faller moving outward (away). If you mean the curvature relative to its source then yes, mass curves inwards and energy curves outwards, but you said the free-faller is moving inwards relative to the hoverer which doesn’t make sense.
No equations! No diagrams!
Wtf do you call that then?
From the hoverers perspective light from the free-faller and accelerator moves slower than c when it leaves them and its speed increases as an inverse square of the distance, to reach c when it reaches the hoverer. How slowed the light is to start with depends on the rate of acceleration of the free-faller/accelerator.
From the free-faller and accelerators perspective their own light leaves hem at c and slows down as an inverse square of the distance, to reach 0 at the event horizon/c.
They increase their acceleration as an inverse square of the distance to the hoverer and the light moving towards the horizon/c is decelerated relative to them at a faster and faster rate as their acceleration increases, but they’ll never be able to catch up.
So you don't think an idealized point-like object subjected to a non-gravitational force would feel acceleration either? If so, this is a huge physical difference between your model and standard GR. It would also explain a lot of your confusion about points like this one:
I have pointed out repeatedly that tidal gravity can be observed with idealized point-like objects moving solely under gravity and feeling zero acceleration, while proper acceleration can only be observed with idealized point-like objects that feel non-zero acceleration. But if you don't believe that an idealized point-like object can feel non-zero acceleration, then obviously your model is different from standard GR and makes different physical predictions. So we're back to the empirical question; we'll find out who's right when we are able to do enough experiments close to black holes. And there's no point in my responding to all the other times in your post when you make the same kind of claim, because you're simply starting from a different premise. (But see a further comment below to one particular place where you raise this exact issue again.)
Meaning, in other words, that it requires the assumption of a family of observers, all mutually at rest with respect to each other for all time, that covers the entire spacetime. So if that assumption fails (as it does in GR with the spacetime around a black hole), this definition no longer works.
Um, I was responding to this statement of yours:
You were the one saying that the observer *would* catch up to his own light, just as an aircraft that goes supersonic catches up with its own sound. At least, that's what your reference to a sonic boom appears to mean. If you meant something else, then once again your verbal description has failed to convey your meaning, and it would really help if you would draw a diagram.
(I suppose I should also note that, in standard GR, if you free-fall towards the horizon and emit a light ray inward, you do *not* catch up to it in any sense; it continues to move away from you, it is always moving inward faster than you are, and it crosses the horizon before you do.)
No, that's also derived from the solution to the EFE. The only assumptions are the EFE and the boundary conditions.
Ah, ok.
Not if you adopt a system of coordinates in which the accerating object is at rest. You are proper accelerated sitting at rest on the surface of the Earth, but you're not coordinate accelerated with respect to coordinates that are fixed to the surface of the Earth. (You *are* coordinate accelerated with respect to coordinates in which an object freely falling downward is at rest.)
I understand that that's what you *think*, yes.
In standard GR, you don't need to reach c to reach a region of the black hole spacetime where you can't hover. You can just float at rest, freely falling into the hole. So this supposed "logical deduction" assumes premises that are not valid in standard GR.
Oncea again, it would *really* help if you would draw a diagram of how you think this is working. See further comments below.
If the free-faller and the horizon are moving in opposite directions, it's perfectly possible for the free-faller to remain timelike and still cross the horizon, just as you can easily remain timelike in flat spacetime and still pass a light ray moving in the opposite direction.
Yes, that's obvious (see my comments at the start of this post). But that's not an argument, just a statement of your state of mind.
I could suggest looking at it as a limiting process (the idealized point-like object is a limit of smaller and smaller real objects, and the proper acceleration it feels is the limit of the proper acceleration felt by the smaller and smaller real objects), but that would require math, which you're allergic to. However, such a limiting process would show that, in the case of objects moving solely under the influence of gravity, the limit of "felt acceleration" goes to zero as the object's size goes to zero, while in the case of objects moving under a non-gravitational force, the limit of "felt acceleration" goes to a non-zero value (the object's proper acceleration) as the object's size goes to zero. That's the long-winded way of stating what I've been saying. And it still points out a key physical difference between objects moving solely under gravity, and objects moving under a non-gravitational force. If you agree with that difference, then you need to explain how your model accounts for it while still claiming that tidal gravity and proper acceleration are somehow "the same". If you *don't* agree with that difference, then we're back, as I said above, to the empirical question; your model and standard GR make different physical predictions, and we'll just have to wait and see who is right.
Once, more, it would *really* help if you would *not* take the following position:
Let me re-quote the statement of mine that prompted your comment above:
You were referring to my diagram of the flat spacetime case; the "free-fallers" in that diagram are the blue vertical lines, and the "accelerators" are the hyperbolas that accelerate *outward* (in the positive x-direction) relative to the free-fallers. Yet you are claiming that the free-fallers in the curved spacetime case are equivalent to the accelerators in the flat spacetime case, and the "hoverers" in the curved spacetime case are equivalent to the *free-fallers* in the flat spacetime case. But in flat spacetime, the free-fallers are *inward* from the accelerators, while in curved spacetime, the hoverers (which you say are equivalent to the flat spacetime free-fallers) are *outward* of the free-fallers (which you say are equivalent to the flat spacetime accelerators). So it looks to me like you have somehow flipped things around. If you were to draw an actual diagram, showing how you think the free-fallers, the hoverers, and the horizon move in your model in curved spacetime, it would really help to clarify what you are saying.
You were referring to this earlier statement of yours:
Since you refuse to write equations, I have no idea what you mean by "work outwards using the inverse square of the distance". If you mean that the time dilation should go like the standard GR formula,
[tex]\sqrt{g_{tt}} = \sqrt{1 - \frac{2 M}{r}}[/tex]
so that a value of zero for [itex]g_{tt}[/itex] at radius r = 2M corresponds to what you are calling "infinite" time dilation at the horizon, then that makes sense, but (a) it doesn't use the inverse square of the distance, just the inverse distance (and takes the square root of that), and (b) it applies to the *hoverer* at radius r, *not* to the free-faller going past radius r. I was asking how you think the proper time of the free-faller works; it can't possibly be the same as the hoverer's, because the free-faller is moving relative to the hoverer.
From the free-faller and accelerators perspective their own light leaves them at c and slows down as an inverse square of the distance, to reach 0 at the event horizon/c.
As far as I can tell, this is mostly the same as the standard GR picture, except that in standard GR, the free-faller (and the accelerator who is moving inward) will eventually cross the horizon, and then they will be able to see that the light beams they emitted ahead of them did *not* slow down and stop at the horizon.
Yes, but I don’t see how the assumption could fail. I don’t see how it could be possible for no amount of energy is enough. It doesn’t work. It doesn’t make any kind of sense. It’s stupid!
I was saying that’s what would happen if an object were allowed to reach an event horizon because you can’t see light reach the horizon no matter how close you are.
90 degrees represents c, and you can’t reach c. That’s why I said to use light cones in flat space-time. They’re relative. Whether they’re tilted because of mass or energy is irrelevant.
PeterDonis said:
Ah, ok.
"The time it takes for their light to reach the hoverers takes longer the further they fall"...and not just because the distance has increased, unless you’re defining the distance after you’ve taken ‘distance shortening’ into account.
Yea it disappears if the coordinates follow the curve.
They would have accelerated to c relative to anything outside the horizon. They’re being accelerated by gravity. They would have freely fallen to c relative to everything outside the horizon.
Are you sure? If something’s on the other side of an event horizon then it’s light-like.
I still don’t know what you mean by “But in flat spacetime, the free-fallers are *inward* from the accelerators, while in curved spacetime, the hoverers (which you say are equivalent to the flat spacetime free-fallers) are *outward* of the free-fallers (which you say are equivalent to the flat spacetime accelerators).” It’s from the hoverers perspective to show that the two ways of accelerating are the same. In flat space-time the hoverer becomes the inertial observer with two accelerators moving in opposite directions. It’s the same. It doesn’t matter that there’s a black hole pulling the free-faller towards it. That’s just the method of acceleration. Gravity pulls everything closer so it becomes cumulative making space-time seem curved, but if everything was accelerated in the opposite direction in the same way as the observer moving away from the black hole then space-time would seem curved in that direction as well, but energy pushes instead of pulls so it’s affect weakens instead.
Is that supposed to be the simpler way? Seems much more complicated. Since I presume neither of us are Egyptian, let’s just stick to words. The hoverers proper time is the equivalent to the proper time of an inertial observer in flat space-time because they’re at rest relative to the black hole. The black holes lifespan could be calculated by the hoverer and that would be that. The free-faller on the other hand is constantly accelerating towards the black hole so its lifespan and its size (in other words the four-dimensional sphere that it covers) gets smaller and smaller at a faster and faster rate as they get closer at a faster and faster rate.
How would that work? You’re approaching the horizon and no light reaches it until you do, and then it suddenly jumps ahead of you as if it had never been slowed down? This is what I meant about the contradiction. There’s two DIFFERENT versions that you keep switching between, but they can’t possibly both be right. In one version the free-faller notices nothing special and merrily passes the event horizon. This is the wrong one. In the other version the free-faller starts to catch up to their own light as the gap between them and the horizon shortens, just like an observer accelerating in flat space-time because you can’t see light cross the horizon no matter how close you are to it. This is the right version.
What inwards accelerating observer? There’s a hoverer, a free-faller, and an accelerator who matches their velocity relative to the hoverer with the free-fallers. You could have an observer accelerating towards the black hole using the same amount of energy as the one accelerating away and an equivalent observer accelerating away from the black hole using twice the energy of the first one. That shows that using energy or mass to accelerate is equivalent and you can even mix them together on the same observer. It makes no difference. They’re equivalent.
No it doesn't. A free-falling observer remains timelike as it crosses the event horizon. A free-falling observer follows a geodesic, geodesics parallel transport their tangent vector, and parallel transport preserves dot products.
So, if its mass remains constant then this doesn't apply. You have asserted earlier that it is not possible to cross the event horizon even of a constant-mass "eternal" black hole. Are you now revising that opinion? Do you now agree that an observer could cross the event horizon of a constant mass black hole in a finite amount of proper time?
Again, I understand that this is what you think, but it's not an argument, it's just a description of your state of mind. Can you think of an actual logical *reason* why the assumption *cannot* fail?
In flat spacetime light cones don't tilt at all. So "use lightcones in flat spacetime" really means "no tilting" period. But gravity *has* to tilt the light cones, because it bends light; so in the presence of gravity light cones *do* tilt, and 90 degrees no longer "represents c".
I'm not sure what you think this means. We agreed many, many posts ago that you can't change the physics by changing coordinate systems.
Your definition of "relative velocity" doesn't work, so this statement has no meaning. In terms of standard GR, the free-faller continues to move inside the light-cones, so he certainly hasn't "freely fallen to c". Can you find a definition of "relative velocity" for objects at different radial coordinates that implies a valid constraint on that relative velocity to be less than c?
Nope, you stay timelike if you free-fall inside the horizon, just as you stay timelike after you've passed a light ray going in the opposite direction.
Well, the second accelerator isn't anywhere on my diagram; I'm just trying to understand how you think the hoverer plus the free-faller falling inward (or the inward "accelerator" in your terminology) correspond to worldlines on my diagram, since you said those two were the two that had a correspondence. If you would just draw a diagram of your own we wouldn't have to go through all these gyrations.
Also, if you say that "the hoverer becomes the inertial observer" then you are saying that the hoverer crosses the horizon (because the inertial observer in flat spacetime does). I don't think you mean to say that, which means that your diagram can't possibly correspond to my diagram. So again, why can't you just draw a diagram of your own instead of saying that there's a correspondence to my diagram, and then basically refuting any such correspondence when you try to describe it?
LOL.
But the hoverer's proper time varies with distance from the black hole. The inertial observer's proper time in flat spacetime (for inertial observers all at rest relative to each other, which I assume is what you mean) is the same everywhere; it doesn't vary in space. So again, you are asserting an analogy that simply can't work. So much for words.
Where did I say that? I said the opposite: I said the light reaches the horizon *before* you do.
Nope, this is the right one, and it's the *only* one I have been asserting. Anything else is just you not understanding, or refusing to accept that the assumptions you are making can be violated.
Not sure what part of my post you were responding to here, but you were the one who called the free-faller in curved spacetime an inward accelerating observer (accelerating relative to the hoverer). You said that the hoverer, not the free-faller, was analogous to an inertial observer in flat spacetime, and the free-faller was analogous to an accelerator in flat spacetime. (Though as I've pointed out, this analogy does not work when I actually ask for more details.)
I’ll take your word for it on this occasion.
NO NO NO! ANY given amount of time won't be enough to reach the horizon, just as no amount of time in flat space-time is enough to reach c no matter how much energy you use. If no amount of energy is enough then it doesn’t matter how much time there is to apply that energy. They’d just keep on accelerating. It doesn’t make sense for an object to reach an event horizon!
Because the methods of acceleration are equivalent. It’s very self-evident that they’re equivalent. You haven’t given a good enough reason to show this premise is wrong. Not even close.
Acceleration bends light in the same way. Just treat it in the same way you would for the curvature of gravity. I’m not sure why you think you can’t compare velocities properly when it’s gravity that causing the acceleration, as if that makes a difference.
Of course. When you follow an object with a different relative velocity, that velocity disappears. When you free-fall you’re following the curve, so it disappears. You don’t river the river current because you’re moving with it. Etc.
If the gravitational source was accelerated to match the current velocity of the free-falling object then the strength of gravity would remain constant for the free-faller, so you could compare their relative velocity with a more distant observer. Or you could just do what you do for a continuously accelerating observer in flat space-time.
Hmm. If it made sense for the horizon to move outwards I suppose that would make sense.
No the free-faller is equivalent to the hoverer. I never said that. The hoverer is equivalent to an inertial observer in flat space-time. The free-faller is equivalent to an accelerator in flat space-time. All three start off as hoverers so that the two types of acceleration cancel each other out and they become the equivalent of inertial observers in flat space-time. One of them shows this by accelerating away at a faster and faster rate but never reaching c relative to the hoverer. The free-faller does exactly the same thing.
You’re diagram has the event horizon moving outwards, so if an observer were to hover relative to the singularity then they would cross the horizon.
It’s not the words thought that you’re going out of your way to misrepresent them to prove a point. The hoverers distance from the black hole doesn’t vary. They’re hovering.
But it can’t. No light can reach the horizon until you do?
But this isn’t what someone free-falling across an event horizon would experience, if it was possible. Light can’t reach the horizon until you do. So if you’re right it must suddenly jump in front of you when you reach the horizon?
Yes it does. Ask away. The free faller is accelerating inwards towards the black hole yes, but from the hoverers perspective they’re both accelerating away. You could remove the black hole and the acceleration of the hoverer to make the hoverer an inertial observer and the free-faller now just accelerates away at the same rate as before and it’s the same.
I have repeatedly pointed out that objects being "accelerated" by gravity feel zero acceleration (as measured by an accelerometer), while objects being accelerated by "energy" (in your terminology) feel nonzero acceleration (as measured by an accelerometer). I even clarified how a limiting process makes sense of these statements when applied to idealized, point-like objects. I'm not trying to prove that your premise is wrong; I'm simply showing that it is false in GR, whatever its status is in your theory, and therefore it does not *have* to be right. I've even said that if you want to maintain that these statements, as physical facts, are *not* true, that's your prerogative: you simply have a different empirical theory than GR, and the decision which is right will be made by experiment, not argument.
Because acceleration due to "energy" does not invalidate the premise of SR that objects which feel no acceleration must have constant relative velocity to each other for all time. "Acceleration" due to gravity does. That's the key difference.
So basically you are denying that the "curvature" in question is a physical invariant; you are saying that "curvature" can always be transformed away by changing coordinates. This is not true for the GR definition of curvature, either of a worldline (what you are calling "acceleration due to energy" and which I am calling proper acceleration) or of spacetime (tidal gravity). Both types of curvature are physical invariants and are present regardless of the coordinate system. (They are *different* physical invariants, but they are both physical invariants.) Can you give a specific definition of curvature in your model such that it always *can* be transformed away?
If by accelerating the gravitational source, you just mean changing coordinates, then this is simply false; the two objects (the source and the free-faller) will move towards each other regardless of what coordinates you use. If by accelerating the source you mean adding a new source of energy to the problem (like attaching a huge rocket to the Earth, say, so that it moves away from an object falling towards it), then you are changing the problem and we'll need to start from scratch in analyzing it. I'd rather not do that since we don't even have agreement on the simpler problem where the Earth doesn't have a rocket attached to it.
And if this is supposed to be an analogy to the diagram I drew, the inertial observer in flat spacetime crosses the horizon, so by your analogy the hoverer should cross the horizon. So the above statement simply can't be a proper description of whatever analogy you think there is between the hoverer in curved spacetime and the diagram I drew for flat spacetime.
The hoverer is hovering relative to the horizon, not the singularity. My diagram is drawn in flat spacetime, remember; in flat spacetime there is no singularity, so there is no such thing as "hovering relative to the singularity".
In the curved spacetime equivalent to my diagram, which would be a Kruskal diagram, the singularity is a hyperbola up in region II (the region where t > 0 and x < t, on the opposite side of the horizon to the hoverers), and it makes no sense to ask "how far away" it is from the hoverers since it's not a timelike surface, it's a spacelike surface--i.e., a surface of constant "time", not a surface of constant "position", so asking how far away it is would be like asking how far away next Tuesday is. The question doesn't make sense. It does make sense to hover relative to the horizon, and that's what the hoverers are doing in curved spacetime. (In the standard GR analogy, of course, hoverers are analogous to, um, hoverers.)
I'm not misrepresenting your words; I'm simply pointing out that they can't possibly express a valid analogy between anything in curved spacetime and the diagram I drew for flat spacetime. If you stop asserting such an analogy in terms which are obviously not valid, I won't have to comment on such assertions. And if you would just draw a diagram of how things look in your model we wouldn't have to go through all these gyrations of you trying to describe how you think your model relates to my diagram and me pointing out that what you're saying makes no sense if I try to interpret it as expressing any such relationship.
Nope. The free-faller sees the light moving away from him in much the same way he would if he were floating at rest in flat spacetime. Locally, there is no way he can even tell when either the light or he himself crosses the horizon; he has to use observations of distant objects to tell that.
So if an observer cannot cross the event horizon of a constant-mass black hole then your previous responses are not relevant.:
A-wal said:
DaleSpam said:
In Schwarzschild coordinates the horizon is the 3 dimensional surface given by:
[tex]r=\frac{2GM}{c^2}[/tex]
and so
[tex]\frac{d}{dt}\left( \frac{2GM}{c^2} \right) = 0[/tex]
therefore the horizon has a constant position in Schwarzschild coordinates.
That's because Schwarzschild coordinates assume an everlasting black hole. A hoverer who's maintaining a constant distance from the horizon will be moving towards the singularity. How fast they move towards it depends on how far away they are, a bit like gravity itself really. They’ll get closer to the singularity as the event horizon gets closer to the singularity, as it looses mass. At the event horizon it’s losing the exact amount it needs for the event horizon to back at c. It’s the equivalent of an accelerator in flat space-time reducing their acceleration (the equivalent of the black hole loosing mass as it ages) to keep their Rindler horizon in the same place I suppose.
So again, the event horizon has a constant position in Schwarzschild coordinates, as I proved above.
Okay, you haven't given a good enough reason to show why the standard GR version is the right one. There’s plenty to suggest that it’s not right.
Well it shouldn’t.
On Earth we’re accelerating up, but it doesn’t really seem like it (although it feels like it) because the coordinate system is defined by us. We’re at rest and we’re being pulled down.
(: Fair enough. I basically just don’t see the problem with comparing velocities in curved space-time because it’s the equivalent of comparing observers with different amounts of acceleration in flat space-time. In fact it’s easier because you can always predict exactly how much gravity they’ll feel as they fall.
If the inertial observer crosses any horizon then it’s not from the inertial observers perspective. It must be from the accelerators. From the free-fallers (accelerators) perspective the hoverer (inertial observer) doesn’t cross the event horizon. What you’re describing is not equivalent to a free-faller crossing an event horizon.
Congratulations. You’ve just managed to "transform away" a curve by changing coordinates.
The distance to the singularity would be the distance to the horizon plus the diameter/radius (whatever, I can never remember) of the black hole.
Thought? Fault! There not even similar, they just sound similar. I'm definitely a bit dyslexic, or a bit something.
But light can’t reach an event horizon from the outside. You see the light continuously slow down but never reach the horizon.
It's not irrelevant. That's why an observer cannot cross the event horizon of a constant-mass black hole, because it's moving inwards at c.
Its distance relative to a hoverer obviously remains constant, but not its distance relative to the singularity.
As I have pointed out ad nauseam, it is observed physical fact that objects moving solely under the influence of gravity (like the Space Shuttle while in orbit, for instance) are weightless, while objects that are *not* moving solely under the influence of gravity (like you or I standing on the surface of the Earth, or a rocket in space while the engine is on) feel weight. You don't consider this a good enough reason?
A-wal said:
Well it shouldn’t.
LOL
How exactly does this relate to curvature and whether it can be transformed away by changing coordinates? What definition of "curvature" is this supposed to support?
But in GR these two are *not* equivalent, because of the key physical difference I keep pointing out. In GR an observer that feels weight simply can't be physically equivalent to an observer that is weightless.
The horizon is just a particular line in the spacetime (the line t = x in the diagram I drew), and whether or not a given observer's worldline crosses it is a physical invariant, independent of whose "perspective" is being used. It is true that defining that particular line as the "horizon" is done *because* it is the asymptote of all the hyperbolas that the accelerators are following, but that doesn't change the fact that once that line is defined, the free-faller's worldline crosses it.
If it isn't, then the hoverer is *not* analogous to the inertial observer in the diagram I drew. So you are basically admitting that the analogy you were trying to make is bogus.
How so? I specified that my diagram was drawn in flat spacetime. "Flat" meaning "not curved". And that spacetime has stayed flat all through everything I've been saying.
I also described the analogue to my diagram in curved spacetime, where the horizon appears as a hyperbola, specifically (I didn't give this equation before because you're allergic to math, but I'll give it now to be specific) the "upper branch" (i.e., in the upper part of the plane, where T > 0 and X < T) of the hyperbola T^2 - X^2 = 4M^2 (where M is the mass of the black hole in geometric units). In that diagram (the Kruskal diagram), the horizon is again the line T = X (I've capitalized T and X in this case to make clear that they are the Kruskal T and X coordinates), and the "hoverers" travel on hyperbolas (in the right half-plane, where X > 0 and T < X) X^2 - T^2 = r^2, where r > 2M.
So the horizons and the hoverers in both cases are analogous, in the sense that their curves look the same and have the same equations in the corresponding sets of coordinates. How does any of this "transform away" any curvature? It's just an analogy that can help to understand how some aspects of the curved spacetime case work. But I'm certainly not trying to claim that you can transform one spacetime into the other just by changing coordinates.
See my comment below on your comment to DaleSpam's post about this.
The hoverer does (for an appropriate sense of "see"). But the free-faller does not. He sees what I have described. At least, he does if standard GR is correct.
I know this was in response to DaleSpam, but it contradicts what you said above in response to me (which I quoted). Which is it?
I understand the relevance of the argument, what is irrelevant is your justification that followed. If you believe that something applies to a constant-mass black hole then you logically must have a justification that is not based on a variable-mass black hole.
So again, you have claimed that the event horizon is moving inwards at c for a constant-mass black hole. In 451 I derived the fact that the position of the event horizon is constant in Schwarzschild coordinates for a constant-mass black hole. Do you have a relevant objection? I.e. one that is based on a constant-mass black hole.
The Schwarzschild coordinate r is the coordinate distance relative to the singularity. If r is constant then the distance to the singularity is constant.
Tidal force is the difference in the strength of gravity between two points of the same object. What you feel when you accelerate is the difference in the strength of acceleration between two points of the same object. If every atom were individually accelerated at exactly the same rate then they wouldn’t feel a thing, or if the acceleration increased evenly as an inverse square in the direction of the source of gravity then it would be exactly the same as tidal force.
A curve isn’t really a curve if you’re following it. You feel it, but only in the sense that you feel tidal force.
'Feel weight' is a loose term.
Yes. Just like when a free-falling observer reaches a point when no signal sent from the hoverer will ever be able to reach them, as long as they keep free-falling.
No, your ‘event’ horizon is bogus.
You said in curved space-time there’s a singularity and in flat space-time there isn’t.
My brain hurts.
I didn’t mean you’re trying to transform one space-time into the other just by changing coordinates. I meant curvature isn’t a physical invariant.
It can’t be. Whether or not an object reaches the horizon is a physical invariant. When would this magical separation happen? At the event horizon? That doesn’t work. The light would have to jump back if they started hovering and jump forwards when they reach the horizon.
Radius!, ?
Yes, the correct term is: non-geodesic. Or equivalently non-zero covariant derivative of the tangent vector, which we have discussed before. As PeterDonis points out, a non-geodesic observer cannot be equivalent to a geodesic observer. One is inertial and the other is not.
What makes you think so? What you feel when you feel proper acceleration is the force of whatever is causing the acceleration (a rocket engine, the surface of the Earth, etc.) pushing on you. The push could be exactly uniform and you would still feel it.
This indicates to me that you do not think curvature is a physical invariant. You confirm that later in your post; see my comment on that below.
Weight can be measured directly by an accelerometer. An ordinary bathroom scale is an example of a (cheap and not highly accurate, but accurate enough for everyday use) accelerometer. There's nothing "loose" about it.
There is no such point. A signal can always be sent from outside the horizon to inside, from the hoverer to the free-faller. The horizon only keeps signals from the free-faller once he is inside, from reaching the hoverer outside.
Yes. So what? I never claimed the two spacetimes were identical. I only described an analogy between certain aspects that can be helpful in understanding those aspects.
A-wal said:
My brain hurts.
Sorry, I forgot you were allergic to math. :eek:
In standard GR it is. If it isn't in your model, then your model must be using a different definition of "curvature" from the standard GR one. What is that specific definition, and what justifies using the term "curvature" to describe it?
I agree.
What separation? I've never said there was any "magical separation". I said that the free-faller sees the light beam moving away from him, just as if he were floating at rest in flat spacetime.
A-wal said:
Radius!, ?
Um, here are the two things you said:
A-wal said:
The distance to the singularity would be the distance to the horizon plus the diameter/radius (whatever, I can never remember) [it's radius--PD] of the black hole.
A-wal said:
Its [the horizon's--PD] distance relative to a hoverer obviously remains constant, but not its [the horizon's--PD] distance relative to the singularity.
The first statement quoted above implies that the distance from the horizon to the singularity is the radius of the hole, which is constant (it's equal to 2M, where M is the hole's mass in geometric units, and we're talking about an "eternal" hole whose mass is constant). That is obviously inconsistent with the second statement quoted above. Which is it?
No sorry, I misunderstood. If it has a constant mass then it would have a constant horizon. But then I suppose you would be able to reach it, which doesn’t make sense. It’s paradoxical to have a constant mass black hole, like it is to accelerate to c under any circumstances.
Yes I see what you mean now.
Hmm.
I’m reaching. Makes sense though, if a point-like object can’t feel a force.
This is heading towards semantics. The curve’s always there unless you go with it, a bit like the river model.
Would you class tidal force as ‘feeling your weight’?
I’m not talking about the event horizon. This is your flat space-time horizon using gravity. Are you sure there wouldn’t be a point when no signal sent from the hoverer will reach the free-faller? I’m fairly confident there would be a Rindler horizon equivalent.
Oh okay.
I’m not allergic to math as such, but I have real trouble when it’s used to describe reality.
It’s relative, just like velocity. You have to accelerate relative to something else.
PeterDonis said:
I agree.
And reaches the horizon from an accelerators perspective, so it can’t happen.
Then what if he starts hovering? Does the light turn round and come back? It would have to if it moves away from him as it would if he was at rest in flat space-time. It would have to slow down as he free-falls and the light moves into relatively more ‘distance shortened’ space-time, glaven.
I was talking about a real life black hole. An eternal one doesn’t make sense. You can always move towards it. In fact it’s encouraged.
