Mentor
- 51,025
- 27,073
A-wal said:As you travel into more and more length contracted/time dilated space you have to constantly recalculate the distance between you and the horizon (which will be non-linear and always greater than you'd expect it to be without the relative stuff) and the time the black hole lasts for in your proper time.
Nope, this is wrong. The calculation I posted already takes into account all the "length contraction" and "time dilation" that takes place as you fall to the horizon. There is no "recalculating" necessary. I think you are mistaking the frame-dependent effects of length contraction and time dilation with the frame-independent, invariant "length" of a given worldline in spacetime, which doesn't change when your frame of reference changes. The calculation I posted, of the finite proper time it takes to free-fall to the horizon from a given radius, is of the latter sort: it's a calculation of the invariant "length" of a given worldline and its result remains invariant regardless of the free-falling observer's state of motion.
This comment also applies to the next quote of yours below, but I have an additional comment about it as well:
A-wal said:The time it will take to reach the horizon will always go up (from a distant observers perspective) forever (or to any given time) as you get closer, until the black hole dies.
As I noted quite a few posts ago, if you don't agree that the horizon can ever be reached for an "eternal" black hole that *doesn't* evaporate, then we're not even ready to discuss the case where the black hole *does* evaporate. I don't think you mean here to concede that the horizon of an "eternal", non-evaporating black hole *can* be reached, do you?
A-wal said:I know that free-fall is equivalent to being at rest (or moving freely I should say) as I've said before, but I think that tidal force acts as acceleration, meaning you can't have a straight line in free-fall. I was thinking of a curved line for free-fall before though, but from the perspective of a distant observer. A line that's curve is constant from this view would be the geodesics you're talking about. That curve would get sharper and sharper from this perspective as the object accelerates (not talking about accelerating up to terminal velocity because that's not true acceleration) while in free-fall. The falling object feels this acceleration as tidal force.
A-wal said:Not with an sensitive enough accelerometer they wouldn't!
Yes, they would. As I believe I've already noted, I think this misunderstanding on your part is a big factor in your misunderstanding of how a black hole horizon works. This claim of yours is *wrong*, pure and simple. Two freely falling objects that separate due to tidal gravity feel *zero* acceleration--not just "too small to measure without really sensitive instruments because Earth gravity is too weak", but *zero*. See next comment.
A-wal said:It's like if you accelerate two identical cars and give them both exactly the same amount of throttle, but one sets off just before the other. The first one to start will constantly pull away from the second one. Your example of tidal force is exactly the same accept it's strong enough to separate "solid objects". The front end of the object will be in length contracted/time dilated space-time relative to the back end. So the front will be trying to move faster than the back even though they both measure their own speeds to be the same, because the front thinks the back is moving too slowly and the back thinks the front is moving too quickly.
Nope, this is wrong, the two cases are *not* the same; they are not even analogous. I'm not sure why you think the two cases are the same, so I'm not sure how to explain why they're not, except to say what I've been repeating for some time now, that freely falling objects separated by tidal gravity are *freely falling*. That means there is no rocket attached to them, nothing to push on them, nothing to exert force on them--whereas in your example, the two cars *are* being pushed, by the force on their wheels. Or, in the more usual example of the "Bell spaceship paradox", the two rockets are each firing their engines, which is why they feel acceleration. For the examples I gave of freely falling objects affected by tidal gravity, there is *nothing* analogous to the car engines/wheels or the rockets in the Bell spaceship paradox; these objects have no "propulsion" mechanism, hence they are freely falling. I'm not sure I can say much more until I understand how you can possibly see a physical similarity between objects in free fall and objects being accelerated by a rocket (or a car engine/wheel, or any other propulsion mechanism).
A-wal said:Right, so the Schwarzschild coordinates are misleading and the time dilation and length contraction that the coordinates show are an illusion? Presumably it's always an illusion then, or does it suddenly become an illusion at the horizon?
The "distortion" of Schwarzschild coordinates gets larger the closer you get to the horizon, and becomes "infinite" *at* the horizon. Far enough away from the black hole, the distortion is negligible--it goes to zero at spatial infinity. The distortion on a coordinate chart does not have to be the same everywhere--for example, a Mercator projection gives zero distortion at the Earth's equator (I'm assuming the "standard" projection which is centered on the equator), and gradually increasing distortion as you get closer to the poles, going to infinite distortion *at* the poles.
