Saw
- Messages
- 631
- Reaction score
- 18
JesseM said:(…) time-reversal symmetry can be seen to support the philosophical view known as eternalism, where spacetime is viewed as a whole with time as just a dimension in spacetime and every event in it equally real, no preferred set of events in "the present" which is flowing forward as in presentism (the relativity of simultaneity is also often taken to support eternalism over presentism). And eternalism may make the idea of time travel easier to understand, since there is no objective sense in which the past has "ceased to exist", it's just that historical events are at a different position in spacetime than we (the ones remembering them) are. But there's no way that believing in eternalism suggests we should believe time travel is possible; that depends on whether the laws of physics allow it, as Deutsch says in chapter 12 (…).
Well, that’s what I meant when I said that time-reversal symmetry (TRS) is sometimes used as a way to “prepare the reader’s mind to accept time travel” (TT). It’s not that the authors who reason that way think that one thing inexorably leads to the other, but they do suggest that the former is a pre-condition for the latter: just by having TRS you do not get TT, but if you do have TRS then it’s “easier to understand that” some other phenomena (eg: wormholes) make TT possible. One could put it this way: TRS is not the only law of physics that is necessary to discuss on TT, but it’s one of the laws of physics that make the very discussion about it intellectually acceptable. The same would apply to the relativity of simultaneity.
JesseM said:A good way of thinking about time reversal symmetry is that if you take a movie of a system and play it backwards, there should be nothing in the fundamental laws of physics that prevents the existence of a separate system which, when viewed in the normal forward direction of time, behaves precisely like the reversed movie of the first system. In the Standard Model of quantum mechanics, time-reversal symmetry is replaced by charge-parity-time symmetry, which basically means that if you take a movie of a system and play it backwards while also reversing the labels of particles and antiparticles (relabeling each electron in the original system as a positron in the reversed movie, for example) and taking the mirror image of the movie along all three spatial axes (flipping left for right and up for down and forward for backward), then the resulting backward/relabeled/flipped movie should describe a physically allowable forward time-evolution for a different system.
I agree with this definition. But if TRS means only this, then we would be obstructing the logical path for making the above mentioned connection with TT. I mean, with this definition, the result of TRS is always new events, which have happened later, in a subsequent time. However, those who make the (weak) connection mentioned above between TRS and TT suggest that the same original past events, thanks to TT (eg: wormholes) are recovered and this is easier to understand in the light of the eternalism somehow supported by TRS, because those events have “not ceased to exist”, they are somewhere waiting for us in the “block universe”, even if (to avoid damage to causality) we have to place this “somewhere” in another world or universe. But this TRS that supports eternalism that supports TT, isn't it another TRS having nothing to do with your precise definition?
