- 13,438
- 8,110
No calculus is involved. Just addition, subtraction, multiplication and division. No fancy formulas that you do not already know. The one useful insight is the one that @TSny gave in post #8.digalumps said:Or it could just be that I have not reached the place in my studies where I am ABLE to calculate what you are asking. If I could then I would. Everyone has to start somewhere.
This is a basic homework thread, not a masterclass in differential calculus.
Rather than considering a continuous exhaust stream produced from the starting speed to the ending speed (which does require calculus and leads to the Tsiolkovsky rocket equation) go back to post #8 and review.
Let me reproduce that idea here.
We will work with symbols. One could, instead, substitute in fixed values, e.g. "A 10 kg rifle shoots a 10 g bullet rearward at 500 meters per second relative to the recoiling rifle . The rifle begins moving at either 1 meter per second or 10 meters per second. Perform an energy analysis". In my opinion, the algebra is more clear with symbols rather than numbers. But some people feel more comfortable with numbers.
You have a large mass M, a small mass m and a massless spring between them. They are lined up on a horizontal axis. You are free to imagine carts with frictionless wheels, pucks on ice, boats on a lake, ships in space or a rifle and a bullet.
You have a massless cord tied around all three holding them together. The spring is compressed and contains a certain amount of potential energy. That energy is sufficient to result in a change in velocity ##\Delta V## in the large mass M. Of course, this will result in a change of ##\Delta v## in the velocity of the small mass m.
The entire assembly is initially moving together in a straight line with the M in front the the m behind. The initial velocity is ##V_i = v_i##. You cut the cord and examine the results.
Determine the final velocities ##V_f## of ##M## and ##v_f## of ##m##.
Determine the initial and final kinetic energy of just ##M##. What is the difference between the two? Does it depend on ##v_i##? [This is the part that you've done previously].
Determine the initial and final kinetic energy of just ##m##. What is the difference between the two? Does it depend on ##v_i##?
Determine the initial total kinetic energy. Determine the final total kinetic energy. Compare the two. What is the difference between the two? Does that difference depend on ##v_i##?
Can you perform the calculations to determine these results? How far can you get? If you show your work, we can help when you get stuck.
Edit: I've edited the above a few times to make the algebra simpler. I hope you did not begin work on one of the tougher-to-get-started-on versions.
